Question about Nikon N50 35mm SLR Camera
Sessions ended Hi, I was in the middle of a trouble-shooting question, but my expert logged there anyone that can assist me?
0 characters
1 Points
Talked to two experts yesterday - the first one talked to me about a camera that isn't even the one I have, he spoke of Canon instead of Contax, and the second one's advice didn't do the...
First, try removing the batteries and then reinstalling them. If the problem persists, you may wish to try a new battery. If this doesn't solve the problem, you will need to send this camera in for repairs. Parts for this camera are hard to find so you will want to have an experienced Contax repair company to repair your camera, like TOCAD.
TOCAD is the only repair company for Contax in the United States that I know of. Here is there site:
Jul 11, 2011 | Contax NX 35mm SLR Camera
What is the fastest write speed? I have noticed the camera does take a while to write when shooting several rapid succession in raw mode. I am shopping for a better SD card. Is it worth it to pay the extra...
Although a good SD card is worth considering it's not the only thing that determines the speed. In fact the shooting light has more to do with it then the memory card. The Rebels although not Pro cameras are pretty darn fast with the differences immeasurable in most cases with Pro cameras.
The Rebel will show the burst rate in the right corner of the viewfinder and if you noticed this rate changes with the light and shutter speeds. Sow the shutter speed down and that burst rate will drop as well. The size of the image file also dictates how fast you can burst in frames per second. You are shooting RAW and no doubt jpg's so the camera is doing double duty with some pretty impressive files size. If you want speed shoot jpg's and set your camera correctly for white balance, shoot for the end use. If you are looking for speed you aren't shooting portraits or landscapes where you have time to calculate your shot so the need for a BIG print isn't necessary so drop your image quality.
The Rebel's processor is very impressive and it has a large buffer where it writes the file as you are shooting so in fact the camera is writing to the buffer at the same time it's writing to the memory card. That's why when you stop shooting it takes several seconds for the camera to catch up.
If you are looking for speed keep your shutter speed up, reduce the image file size, shoot jpg, class 6 works nice (I use this type) I have only one class 8.
On a personal note the Canon Digital Rebel has put so much power and performance in the hands of entry level photographers and they are using that power to come up with some darn nice photography and in the right hands it's putting the hurt to some long time pro shooters.
Jan 02, 2011 | Canon EOS Rebel XS 35mm SLR Camera
I have trouble taking indoor (low light) photos. pictures come out blury and the camera does not snap the picture properly i have a nikon 35 mm n6006 camera
Hi Rebecca--
The hardest thing about low light photography is balancing your available shutter speed to the amount of action you're trying to capture.
Here are a few things to try:
1) Try using a tripod. Steadying your camera during long exposures will greatly improve your image clarity.
2) Buy a faster film. You may need to increase your film's ISO setting. Try 400 to start, then go up from there. Remember, faster film always produces grainy images, and it usually costs a little more to process. If you're stuck with 100 ISO, you can always "push process" the film, where a given ISO is let to sit in its developer longer than usual--This will cost you more too!
3) Invest in a good flash system. Nikon has tons of hotshoe flash systems that rarely compromise the ambient light-mood of a given situation. Look for one that lets you aim the flash in different directions, and try to find one that will meter a light situation on its own.
4) Turn on the lights. If you're ok with losing some of the romance of an image, turn on some more lights to give you some more flexibility when making your exposure choices.
5) Open up your aperture. You may find that a lot less in depth of field will give you a lot more in image clarity and exposure flexibility. Shooting at f2.8 with only a birthday cake lighting your subject will grant you many more valuable shutter stops that shooting the same with f5.6.
Remember, Rebecca, if you're shooting handheld, you must do everything in your power to shoot with the quickest shutter speed available. This will cut down on the blurriness of your indoor images.
--Hope this helps.
Oct 06, 2010 | Nikon N6006 35mm SLR Camera
How do i rewind the film on the nikon n60?
The camera should rewind the film when it reaches the end of the roll. If it doesn't, or to force a rewind in the middle of a roll, press the mid-roll rewind button with a pointed object. The button is on the bottom of the camera, toward the left end (away from the handgrip), and marked with a roll of film.
Sep 04, 2010 | Nikon N60 35mm SLR Camera
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
C Amera turns on, focuses, but will not fire.
The shutter may be damaged and need service. Look at the shutter if they look misaligned or even out of track tat is the problem. A repair tech could trouble shoot the camera, but repairs may exceed the cost of replacement.
Oct 24, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Putting film into nikon f60
It is fairly simple. Insert the film canister with the hole side (not the projection) down. Insert the spool of the camera into this hole and slide the canister inside the chamber. Now pull the film out slightly so that the leader (the narrow portion at the end of the film) aligns with the orange mark at the lower right end of the film chamber. Make sure there is no slack in the film. Close the door and turn on the camera.
Mar 13, 2009 | Nikon F60 35mm SLR Camera
What does A ERR mean?
There are several situations when this message happens and the camera locks up, and almost none of them has anything to do with the cause stated in the camera manual: film DX coding error. (If it is truly a DX-coding error, manually setting the ISO speed of the film should solve the problem. This could happen in cold weather.) Scenario One: when using Alkaline batteries and the batteries are almost exhausted, and yet one continues to shoot. The battery may not have enough power to complete the shutter firing operation (which usually includes: mirror up, close down diaphragm, shutter fire, mirror down, open diaphragm, advance film, and charge the shutter for next frame). The camera could be lock up in the middle of the operation, left with a dimmed viewfinder. Usually an indication appears quite early if one pays attention: when the batteries are almost exhausted, the film advance becomes noticeably slow. In normal situation film advance is very fast and one cannot distinguish it from other noise such as mirror flipping. When the batteries almost exhausted, the film-advance could take almost 1 second, and the noise of film advancing has been mistakenly identified by some as "beep". I think those is the result of over-adjustment for the Premature Battery Indication problem. This scenario is particular to using alkaline batteries, due to the peculiar behavior of the alkaline battery: even when its power is almost exhausted, it still has a pretty high voltage. Solution: replace the batteries and fire the shutter once should solve the problem. I am pretty sure this is normal, since it happened to me several times, and I once deliberately repeated this happening. Scenario Two: At the end of a roll, when the remaining film is too short for one more frame but long enough to fool the camera, the camera could end up with "Err" message. Solution: rewind the film and load with the new one, and possibly fire the shutter once could solve the problem. (This has never happened to me, but summarized from other’s reports.) Scenario Three: I've heard of two reports: happened in the middle of a roll, with sufficient battery power. I have no idea what’s going on. (Could be really a DX-coding problem, which does not necessarily occur just at the beginning of a roll.) Solution: probably should send the camera in for a check. (Also, both reports of this problem occurs while using Kodachrome films.)
Oct 15, 2008 | Nikon N90S 35mm SLR Camera
Canon k2 manual
Hi- here is a link for your manual. If this solved your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
May 07, 2008 | Canon EOS Rebel K2 35mm SLR Camera
Camera locked up and won't work
Hi , set camera to auto /replace button battery lr 44 x2 pieces .
donot set camera to lower shutter camera will stuck .
Feb 18, 2008 | Nikon F80 35mm SLR Camera
Nikon N50 35mm SLR Camera Logo
14 people viewed this question
Top Nikon 35mm SLR Cameras Experts
Ric Donato
Bart Pulverman
Are you a Nikon 35mm SLR Camera Expert? Answer questions, earn points and help others
