Question about Maxtor USB 2.0 External Enclosure + Hard Drive 200GB /ATA133 7200 RPM 8MB 6Y200P0 Drive Case
Maxtor one touch usb hard drive
Hi . This thing won't switch on! . I've checked all fuses and they're ok but it won't budge. It's out of warrenty so I need to repair it myself. Please advise
    Problem Solver:
  • 51 Answers
I would remove the hard drive from the case and slave it to my primary drive inside the tower. If it is out of warranty then it is likely old and about to die. Maxtors do not exactly have a reputation for longevity. Your best bet would be to image it and restore the image on a new drive.
Posted on Aug 17, 2007
I had my Maxtor One Touch plugged in the USB of my computer this am. It has worked fine up to that point. I have 4 years worth of audio files saved on there.... When I went to unplug my Maxtor this am to...
Return or contact Maxtor. For a fee they have the equipment and processes (that are proprietary) to retrieve your data. Do not restore the HD because it will erase ALL information!
Jul 14, 2011 | Maxtor OneTouch III 500GB 7200RPM USB 2.0...
I cannot access my Maxtor external hard drive. My laptop will not start if the hard drive is attached. If I attach my hard drive after booting up my laptop the laptop freezes.
Your Maxtor HDD is Broken, or Jammed. thats why these hanging things happen. send it to the service center if you have any warrenty. i think they will fix this. if no warrenty then open the HDD casing and remove the HDD and put it in new casing and try backing up Date. best of luck...
Jan 26, 2011 | Maxtor Computers & Internet
Hi there i hav ea maxtor onetouch 4 mini 120 gb.
Remove the hard drive from the Maxtor case, purchase an USB hard drive adapter case, and install the hard drive inside this case. Then you can connect this to the computer's USB port and if the hard drive is OK then this computer will detect it as an external USB hard drive, then you can open the folders and files and back them up.
Jun 29, 2010 | Maxtor OneTouch 4 Mini 120GB External USB...
Computer won't recongize my Maxtor one touch
If plugged in the first time, the external drive needs to be initialized from your computer. Here are the steps.
1. Plug in your external drive to your computer's usb port.
2. Right click your My Computer and choose Manage.
3. Click on the Disk Management from the left. The list of available drives will show on the right.
4. Right click on your External drive and select create partition (primary partition).
5. After that you now you need to format the hard drive. Choose quick format.
6. Right click again on the partition you've just created, now select "Format" and select NTFS.
7. Click Ok and follow the wizard as it will guide you until it is finished.
Hope this helps.
Nov 18, 2009 | Maxtor 160 GIGABYTE USB2.0 EXTERNAL...
Windows vista states insufficient space on Maxtor One Touch drive
You could check that the backup software settings are pointing to the correct drive. (I've made this mistake before).
Nov 03, 2009 | Maxtor OneTouch 4 Plus 500GB External USB...
Something Dopped on maxtor 500G, Now not reading - making beep
two thing could be the power supply in the external box or it could be the drive it self
go to maxtor.com and download the software to test the drive
Aug 11, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Drive won't mount
i had a maxtor one touch go bad and had to open the case and take it out of the external casing and put it into my computer as an internal drive. then it worked fine. it was a single drive.
just today i had a maxtor TB drive go bad, and since i think it has two drives inside it i am very worried that i will not be able to do the same thing.
May 25, 2008 | Maxtor OneTouch II external hard drive...
Maxtor one Touch 300GB no steady green light
The USB Isn,t supplying/providing enough Power to the device.
Search e-bay or similar for a 2 into 1 USB Cable.
Then power the unit with 2 USB Ports on the Computer.
2 x USB Into 2 x Sockets On P.C. 1 x Into Device Drive.
This will be enough power to operate the Device Correctly.
I,ve done this on several external Drives, never failed for Me.
Mike @ compurepair.
Mar 16, 2008 | Maxtor OneTouch II external hard drive...
Maxtor one touch mini doesn't appear to work.
The blinking light indicates something is happening to know open :
http://seagate.custhelp.com/cgi-bin/seagate.cfg/php/enduser/std_adp.php?p_faqid=1600
And check the power cord and try with the known good power cord.
You can check this :
http://seagate.custhelp.com/cgi-bin/seagate.cfg/php/enduser/std_adp.php?p_faqid=4996&p_created=1194886713&p_sid=SzkLKr3j&p_accessibility=0&p_redirect=&p_lva=1600&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTg0LDE4NCZwX3Byb2RzPTQxMCw0MjEsNDYxLDQ2NSw1MDgmcF9jYXRzPSZwX3B2PTUuNTA4JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTE*&p_li=&p_topview=1
Good Luck.
Live, Love, Laugh.
Feb 16, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
Maxtor one touch
Hi, You can try and use PowerQuest PartitionMagic. It will allow you to partition/format/check most HDs including USB connected. Choices/options are from FAT16 to NTFS and Linux. Another handy disk utility that is a freeware is HP's bootable flash utility at http://h18000.www1.hp.com/support/files/serveroptions/us/download/23839.html Hope this be of some help/idea. Post back how things are or should you need further information. Good luck and kind regards.
Sep 10, 2007 | Maxtor One-touch III Mini 40 GB USB 2.0...
Computers & Internet Logo
95 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
