Instructions for voicemail from a Panasonic KX-TS208w corded phone?
SOURCE: CHANGING THE RINGTONE
Depending on your model system, it may or may not be possible. I included the two different methods to change the ring tone below depending on your system. Give it a try.
KX-TDA Systems
KX-TD Systems
Press PROGRAM
Program Press the CO Line key you wish to change
Press the same key again, enter the tone number (01 through 30)
You will hear the tone associated with the tone type number. For example, if you press 02, you will hear the tone associated with tone type 22. Press each number (01-30) until you hear the tone you desire.
Press STORE
The tone is now stored for that line on that phone only.
Press PROGRAM 99 (or PAUSE 99 if you do not have a PROGRAM button
Press the same key again, enter the tone number (1 through 8)
You will hear the tone associated with the tone type number. For example, if you press 2, you will hear the tone associated with tone type 2. Press each number (1-8) until you hear the tone you desire.
Press STORE
SOURCE: Panasonic KX-T7730 corded
If you can provide the phone system type I will try to help as this is a system wide setting and there are a lot of different Panasonic systems out there. ......Mike
SOURCE: Hi, How do you change the time on a Panasonic
There are several way that may adjust the Panasonic phone clock, please try the following suggestion method:
Method 1:
1) Press PROG soft button, follow by HOLD button.
2) LCD show direct the time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press END or HOLD to end the setting.
Method 2:
1) Press PROG soft button, follow by HOLD button, follow by # button.
2) LCD show time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press again # button to select between AM and PM mode.
4) Press again STORE to save the setting.
5) Press END or HOLD to end the setting.
Method 3:
1) Press PROG button, follow by key * * 1 2 3 4.
2) Press key 0 0 0 to display the day/time setting.
3) Press |> or SP-PHONE button if u wish to change the date.
4) Press |> or SP-PHONE button to change the time.
5) Press CLEAR or TRANSFER button to change current hour entry.
6) Press |> or FWD/DND button to change current minutes entry.
7) Press |> or FWD/DND button again and AUTO ANS button to change between AM or PM.
8) Press STORE to save the setting.
9) Press END or HOLD to end the setting.
Hope these help.
YBC (/\)
SOURCE: Time Change
It can be changed from any phone that lets you into programming. We usually give everybody access to make changes like this, but by default, the phone designated as the Manager or Operator is usually given that access. Try ext 101.
When you get there, press PROGRAM **1234. If your display reads SYS-PGM No?, then it will work. Dial 000 and STORE. You will see the Date. Press SP PHONE! Now you will see the time. Dial the new time and press STORE. Press HOLD and PROGRAM to exit or just pick up the handset and drop it back down.
If for some odd reason you can't get into programming from ext 101, then you might have to search for the manager's phone, or call your installer to make one or all of the phones have access to programming.
They can allow you access to other programs, or even give you the installer password to get into all the programming.
Carl
Testimonial: "Thanks, great help"
SOURCE: HOW DO I CHANGE THE TIME ON A PANASONIC KX-T7730
If you are using the KX-T7730 phone with a Panasonic KX-Txx 308/616/824 system. From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle press Program * # followed by the system password ( default is 1234). Now press 000 and then Sp-Phone.Enter the year and then scroll to the month with the right scroll key (located at the right bottom corner of the phone). To change the month use the AUTO ANS / MUTE button. Now scroll right again and change the date and day. To change the day again use the AUTO ANS / MUTE button. Now scroll right again and the time will appear. Set the time. To change am/pm scroll to it and again use the AUTO ANS / MUTE button. Press Program to exit program mode and you are done.
Please rate this answer if it was helpfull.
Thank you.
