Question about Toshiba Satellite A135-S2276 Notebook
Application error when running recovery disk
Hi - I am trying to restore my computer Toshiba Satellite A135 and used the disc Toshiba Recovery & Applications/Drivers DVD. When I ran the disc an application error came up and this is exactly what it said:
Application Error 29005
Write sector failure,result=1,drive =128,sectors 88711 to 88775.
My computer also said
  • Anonymous Dec 17, 2008
    really bad help restor
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 163 Answers
Hi
Did you create any partitions on the HDD?
Obviously the HDD or some partitions on the HDD are corrupt.
In my opinion, you should firstly try to format the whole HDD and delete also whole partitions.
Then insert the recovery CD and try to install the Toshiba image
villival
Posted on Dec 15, 2008
How to restore a toshiba satellite a135-s2286 notebook without cd?
the f8 function is only to try and remedy boot problems. the recovery option you're getting is to restore if you have already made recovery discs.
if you have a recovery partition on your hard drive you should be able to access it when you boot up. before starting your laptop press and hold 0(zero) key and power on the laptop. once it starts you should get a screen with 3 options then choose option 1 to get back to factory restore.
Nov 11, 2012 | Toshiba Satelite A135-S2286 Notebook
Have tried to completely restore laptop by running dvd recovery disks. Inserted disk 1 ,after a while got message "bootmgr missing" Any ideas?
There are corrupted files from the recovery disc which the computer cannot read. Use another recovery disc.
Hope this helps.
Jun 12, 2011 | Toshiba Satellite Pro L300 Notebook
I want to restore factory settings to my toshiba a135 2276 laptop but i dont have the restore disk. Can you walk me through it?
Rapidly press F10 when you first start up. Your recovery options should come up. If it doesnt come up then youll need to order a set of recovery discs from Toshiba.
Mar 23, 2011 | Toshiba Satellite A135-S2276 Notebook
Error : 10-FC12-0570 when i try to reinstall with the cds
Error 10-FC12-0570 on Toshiba satellite This error message means that the recovery utility was not able to read the data from the disc correctly, or wasn't able to write it to the hard drive.
The problem could be with the disc, the CD/DVD drive or the hard drive.
Solution:
Try copying the second disc using another system. If it's impossible: order for a new disc. If you can copy it, try using the copy to do the restore.
Try using a third party disk checker to verify the problem, is or is not, with the hard drive.
The best way would be to load the Windonws Vista discs, format the pc and reinstall.
(Vista Recovery Boot Cd is available free by Microsoft). Download it burn the Image .iso and run that disc. That disc will not restore the OS: run diagnostics on the HDD; once disk check is completed and repaired, proceed with the Recovery disks that you have.
Nov 22, 2010 | Toshiba Satellite A215-S7422 Notebook
How do i wipe my toshiba satellite a135 with my 2 disk recovery/drive app disks?
Place disk ! into the DVD drive and turn the laptop on. It will boot into recovery mode and just wait for the prompts.
It will restore your laptop to its original state.
Hope that helps.
Nov 10, 2010 | Toshiba Satellite A135-S2276 Notebook
I cant fint my system recover drive, i want to reinstall visat on it, its toshibe satellite A135-S4427 please help
Most Toshiba computers do _NOT_ come with a set of "System Recovery" disks.
Instead, there is a program installed on the computer that you use to write your own set of CD/DVD diskettes, using your "blank" disks and your CD/DVD burner. Run the program to create a set of disks.
Or, when you restart your computer, look for displayed text like "press Fnn to start System Recovery". Press the named key.
Jan 27, 2010 | Toshiba Satellite A135-S4427 Notebook
I am coming up with error 10-fc12-0570 on the toshiba satellite a215-s7422 i used the both recovery disk and this was the error code
The error message is telling you that the recovery utility was not able to read the data from the disc correctly, or wasn't able to write it to the hard drive. The problem could be with the disc, the CD/DVD drive or the hard drive.
but usually error 10-FC12-0570 is pertaining to a bad HDD or memory
First, try copying the second disc using another system. If you can't copy it, order replacements from Toshiba Customer Assistance: 1-800-457-7777. If you can copy it, try using the copy to do the restore.
You can try using a third party disk checker to verify the problem is or is not with the hard drive. But since the system is under warranty, you're going to have to arrange to have it repaired anyhow, so it may not be worth the effort to verify whether it's the hard drive or CD/DVD drive. It's probably not the CD/DVD drive since you got all the way through the first disc. Contact a Premier (not regular) ASP for service from here: http://pcrepair.toshiba.com
The best way would be to load the Win Vista discs n format the pc...and reinstall...iam telling this because u have a tried the recovery disk as well....
I know most users will not have the Vista CD with you but the Vista Recovery Boot Cd is available free by Microsoft just google...
Download it burn the Image .iso and run that disc. Since that disc will not restore the OS all it does it lets u run diagnostics on ur HDD and allows u to install the OS. Once disk check is completed and repaired, proceed with the Recovery disks that you have.
thank you
have a nice day
Jul 08, 2009 | Toshiba Satellite A215-S7422 Notebook
I need the hardrive drivers mk1637gsx 160 HD SATA
Theres no such thing as Hard Drive Drivers
Restore disks are created to only work with the default hard drive that came with the laptop. Even if you bought an exact replacement it still wouldnt work as the restore discs looks for the unique serial number of the hard drive and therefore prevents people from using the recovery discs on other toshiba systems or non toshiba systems.
Id suggest borrowing another windows installation disc and using the key on the certificate of authencity on the bottom f the laptop to activate.You might have to ring microsoft to activate it but just explain whats happened and it should all go ok.
If you found this helpful , please rate my solution below
Kind Regards
1234s282
Jul 02, 2009 | Toshiba Satellite A135-S4427 Notebook
Used Recovery Disk and I have an application error
It seems like your hard drive has some bad sectors.
You need to run some disk manager software to check/fix tour disk.
The best choice would be to download the "ultimate cd" from here
Boot from the cd, go to "hard disk tools" and select a disk manager (better to select the one from the same manufacturer of the disk).
Run a scan, and fix the drive (if it is possible). Then rerun your system restore cd again.
If the hard drive can't be fixed, you'll have to replace it before running the system retore.
Dec 15, 2008 | Toshiba Satellite A135 Notebook
Toshiba Sat A135-S2386 System recovery downloads??
i guess that the computer has installed vista ultimate and the creation of recovery cd option has gone with it. the new recovery cd will solve all your problems.
Nov 27, 2008 | Toshiba Satellite A135-S2386 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
341 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
