Question about Kenmore 15516 Mechanical Sewing Machine
Can't get the clutch to disengage so that I can wind the bobbin
I am trying to wind the bobbin but when I pull out the clutch *sears kenmore sewing machine model no. 385.19502" it doesn't disengage - the needle continues to go up and down and the bobbin does not wind. I have taken off the side and the belt appears to be fine. any suggestions?
  • Anonymous Jan 31, 2009
    I have a Singer 301a and I can't get the machine to (disengage) stop stitching, even with the smaller knob turned towards me.
Where is the model number on Kenmore machines?
Posted on Dec 20, 2008
3 Suggested Answers
  • 89 Answers
SOURCE: the clutch on my kenmore 1310 won't disengage when
May be one of two problems.
1st you should be able to turn the nob about 90-120 degrees. Not a full turn.
If this is not the case follow these steps.
Turn the small screw on the nob about 2 full turns
Carefully turn the nob all the way off.
Inside there is a round part with 3 small prongs on it.
spin that 180 degree and put everything back together.
2nd your clutch is gummed up
You will need to remove the handwheel and motor belt for this.
Remove the nob, small 3 prong part, and motor belt.
Pull the handwheel off (it may be stuck on and hard to get off).
Clean inside the handwheel and the machine main shaft.
Lubricate the Main shaft and put handwheel back on.
When you put the small 3 prong part back on it needs to have the prongs sticking away from the machine.
Hope this fixes your machine
Posted on Apr 06, 2011
  • 323 Answers
SOURCE: Sears Kenmore Sewing Machine Model 385. 1254180 Bobbin Won't Wind
On some of these machines when the bobbin winder is on it stops the rest of the machine from working. Push the bobbin winder mechanism to the left and see if your machine will work.
sewman7
Posted on Jan 23, 2009
How to get it off bobbin wind
This is covered in the user manual. If you haven't got one search online for "user manual + your make & model". You should get several decent hits like. http://homeappliance.manualsonline.com/manuals/device/sewing_machine
Aug 08, 2015 | Sewing Machines
1803 bobbin winder reset button
there is a part In the machine that work the bobbin winder that is not functioning like it should, a repair technican can tell you why
Apr 15, 2014 | Kenmore Sewing Machines
Disengage clutch kenmore sewing machine
http://www.shopyourway.com/manuals/9253 is the manual. Turn the center of the handwheel knob toward to you to disengage the clutch.
Dec 26, 2013 | Kenmore Sewing Machines
I can't get the bobbin winding to work. Am I missing something?
Do you have your manual? I don't know what model you have, do you have a clutch on the handwheel that has to be pulled out to disengage the needle shaft? Do you have the bobbin pushed to the right ? Do you have the thread running the right way? If, you have checked all that, take the machine to Sears and ask a salesman for assistance. And it is free. They usually are pretty good in the sewing machine department because they never know if you want to upgrade or not.
Dec 29, 2010 | Kenmore Sewing Machines
I have a kenmore sewing machine model #385.1249180. I cannot disengage the clutch knob from the hand wheel when I spin my bobbins, therefore the needle moves up and down as the bobbins spins thread. Do You...
Usually when you pull the clutch knob out it disengages the sewing machine needle shaft. At least, that is how my 2 Kenmore's work. You can always take your machine into Sears sewing department and ask the sewing machine salespeople for help, they are really helpful in my area and more than happy to help you for free. Good luck
Dec 23, 2010 | Sewing Machines
On my Kenmore 15250 sewing machine to wind the bobbin I need to release the clutch by turning clutch knob towards me, so says the instructions booklet. But the clutch knob does not move apart from the...
On my Kenmore I had to pull the knob out to release the clutch, then push it bak in. I don't know if that is the same for you. You can try it, if it doesn;t move, it was worth a try. You could just take to Sears, sewing machine department and ask the salesperson what to do, they should help you for free, our Sears is pretty good about such matters.
Sep 13, 2010 | Kenmore 15208 Mechanical Sewing Machine
Kenmore by sears model 1581457180 need a manual or a how to thread the bobbin
hi there,
on my manual 1581 kenmore show figure on how you thread your bobbins and upper thread.
to thread bobbin insert the thread on one hole of winder holding thread and rotate thread on counter clockwise rotation several times, loop the thread on tension thread and insert bobbins winder on winder shaftat top of your sewing machine push the latch to lock bobbin winder
pull the handwheel to disengage the clutch and to move the winder free rotation.
press the foot pedal to run your winder and thread your bobbins be sure on counterclock wise rotation.
if winder is full of thread this will automatically disengage the shafting winder from clutch.
4843169.jpginsert winder as in fig. check the thread direction
5d74924.jpg 153629c.jpg on figure hold and insert bobbins on shuttle race assymble.
on figure show upper threading.
3cba620.jpg follow the red thread on figure.
you can also check your manual on internet
search box type www.kenmore 1581
have a nice day,rate my fix,thank's a lot
Jun 12, 2009 | Sewing Machines
Bobbin won't wind
I also have the 15358. You probably forgot to "lock" the bobbin winder. After you put the bobbin case on it's peg, push the peg to the right until you hear a click. Then after you disengage the clutch, the bobbin will wind.
Sep 01, 2008 | Sewing Machines
Bobbin clutch just spins
Clutch is disengaged only for winding thread onto the bobbin.
When done, re-engage (tighten) clutch and with bobbin in bobbin case, hold needle thread, rotate handwheel until needle is top centre of it's motion then pull threads thru allowing approx 100mm (4") slack .....you are ready to sew.
If this isn't what you were asking, then I'm not sure why you have disengaged the clutch, so more detail please.
Feb 14, 2008 | Sewing Machines
Kenmore Sewing Machine model # c877.15
I have a Kenmore as well ,I hope that this will work for you ,too bad that I don't live close to you otherwise I would give a hand. This is the way I fill the bobbin on mine. Mine is located on the top right ,I put the thread into the bobbin hole leaving a small piece of thread hanging for me to hold when I begin the winding, I pull the wheele out to stop the needle from moving while winding, when I am done just push it back in .I run the thread from the spool into the top left it looks like a U turn with a screw go around that without winding just pull it into the bobbin hole. press the foot control and it will begin winding .
Jul 17, 2007 | Kenmore 15208 Mechanical Sewing Machine
Kenmore 15516 Mechanical Sewing Machine Logo
1,013 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
