Question about Toshiba Satellite A135 Notebook
Used Recovery Disk and I have an application error
Hi - I am trying to restore my computer Toshiba Satellite A135 and used the disc Toshiba Recovery & Applications/Drivers DVD. When I ran the disc an application error came up and this is exactly what it said:
Application Error 29005
Write sector failure,result=1,drive =128,sectors 88711 to 88775.
My computer also said that I have missing files or corrupted files.
I have no idea where to go from here. Do I need to take it to a shop or maybe I can fix it on my own. Any help would be greatly appreciated. Thank you!!
  • gscg2 Dec 15, 2008
    Thank you mantelo 17. it is worth a shot!
  • 81 Answers
It seems like your hard drive has some bad sectors.
You need to run some disk manager software to check/fix tour disk.
The best choice would be to download the "ultimate cd" from here
Boot from the cd, go to "hard disk tools" and select a disk manager (better to select the one from the same manufacturer of the disk).
Run a scan, and fix the drive (if it is possible). Then rerun your system restore cd again.
If the hard drive can't be fixed, you'll have to replace it before running the system retore.
Posted on Dec 15, 2008
2 Suggested Answers
  • 163 Answers
SOURCE: Application error when running recovery disk
hi
Did you create any partitions on the HDD?
Obviously the HDD or some partitions on the HDD are corrupt.
In my opinion, you should firstly try to format the whole HDD and delete also whole partitions.
Then insert the recovery CD and try to install the Toshiba image
villival
I need to reboot windows xp on my toshiba satellite laptop
The Toshiba Satellite A10-S169 includes several utilities to improve the performance or security of the computer, and to reconfigure the system's settings. Toshiba Satellites running Windows Vista 32-bit and Windows XP come with the Toshiba HDD Recovery Utility, which allows you to create a recovery CD of your system and applications. The recovery CD will allow you to restore your system and its settings in case your hard drive fails.
Click "Start." Click "All Programs." Expand "Hard Disk Recovery Utilities." Click "Recovery Disc Creator." Select "CD" as the type. Check "Recovery and Applications." Insert a CD into the disc drive. Click "Burn." The Toshiba A10-S169 will begin writing the recovery content to the CD. Follow the on-screen prompts to burn your recovery files to disc. Hope this helps.
Jan 10, 2013 | Microsoft Windows XP Professional With...
How to restore a toshiba satellite a135-s2286 notebook without cd?
the f8 function is only to try and remedy boot problems. the recovery option you're getting is to restore if you have already made recovery discs.
if you have a recovery partition on your hard drive you should be able to access it when you boot up. before starting your laptop press and hold 0(zero) key and power on the laptop. once it starts you should get a screen with 3 options then choose option 1 to get back to factory restore.
Nov 11, 2012 | Toshiba Satelite A135-S2286 Notebook
I want to restore factory settings to my toshiba a135 2276 laptop but i dont have the restore disk. Can you walk me through it?
Rapidly press F10 when you first start up. Your recovery options should come up. If it doesnt come up then youll need to order a set of recovery discs from Toshiba.
Mar 23, 2011 | Toshiba Satellite A135-S2276 Notebook
How do i reset my toshiba satellite A135-S4427 to when i bought it
This should work on every recent Toshiba laptop (). - Start with you laptop turned off.
- While holding down the 0 (zero) key tap the power button.
- When you hear a beep, release the 0 key.
- select Yes to continue with the system recovery.
- Select Recovery of Factory Default Software and Next.
- Select Recover to out-of-box state and Next.
WARNING: the procedure will delete all data on your hard drive!!
Feb 28, 2011 | Toshiba Satellite A135-S4427 Notebook
I have the same problem the toshiba recovery disk i get error message 10f8060017.its a toshiba A105-2194 win xp media edition. i have tried everything wiped the disk to all 0's. Used a win xp original disc...
You have tried all possible solutions and troubleshooting.
My Suggestion is to check the Warranty of the Hard Disk and get it replaced. this possible shows a mismatch between the Laptop and hard drive.
Feb 15, 2011 | Toshiba Satellite A105 Notebook
Error : 10-FC12-0570 when i try to reinstall with the cds
Error 10-FC12-0570 on Toshiba satellite This error message means that the recovery utility was not able to read the data from the disc correctly, or wasn't able to write it to the hard drive.
The problem could be with the disc, the CD/DVD drive or the hard drive.
Solution:
Try copying the second disc using another system. If it's impossible: order for a new disc. If you can copy it, try using the copy to do the restore.
Try using a third party disk checker to verify the problem, is or is not, with the hard drive.
The best way would be to load the Windonws Vista discs, format the pc and reinstall.
(Vista Recovery Boot Cd is available free by Microsoft). Download it burn the Image .iso and run that disc. That disc will not restore the OS: run diagnostics on the HDD; once disk check is completed and repaired, proceed with the Recovery disks that you have.
Nov 22, 2010 | Toshiba Satellite A215-S7422 Notebook
I am trying to do a factory reset on my toshiba satellite A135-S4527 and i can figure out how
You will need the Operating system recovery disk to format and reinstall windows..
Without the disk you cannot perform an reset.
Sep 19, 2010 | Toshiba Satellite A135-S4527 Notebook
I am coming up with error 10-fc12-0570 on the toshiba satellite a215-s7422 i used the both recovery disk and this was the error code
The error message is telling you that the recovery utility was not able to read the data from the disc correctly, or wasn't able to write it to the hard drive. The problem could be with the disc, the CD/DVD drive or the hard drive.
but usually error 10-FC12-0570 is pertaining to a bad HDD or memory
First, try copying the second disc using another system. If you can't copy it, order replacements from Toshiba Customer Assistance: 1-800-457-7777. If you can copy it, try using the copy to do the restore.
You can try using a third party disk checker to verify the problem is or is not with the hard drive. But since the system is under warranty, you're going to have to arrange to have it repaired anyhow, so it may not be worth the effort to verify whether it's the hard drive or CD/DVD drive. It's probably not the CD/DVD drive since you got all the way through the first disc. Contact a Premier (not regular) ASP for service from here: http://pcrepair.toshiba.com
The best way would be to load the Win Vista discs n format the pc...and reinstall...iam telling this because u have a tried the recovery disk as well....
I know most users will not have the Vista CD with you but the Vista Recovery Boot Cd is available free by Microsoft just google...
Download it burn the Image .iso and run that disc. Since that disc will not restore the OS all it does it lets u run diagnostics on ur HDD and allows u to install the OS. Once disk check is completed and repaired, proceed with the Recovery disks that you have.
thank you
have a nice day
Jul 08, 2009 | Toshiba Satellite A215-S7422 Notebook
hi
villival
Dec 15, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Sat A135-S2386 System recovery downloads??
i guess that the computer has installed vista ultimate and the creation of recovery cd option has gone with it. the new recovery cd will solve all your problems.
Nov 27, 2008 | Toshiba Satellite A135-S2386 Notebook
Toshiba Satellite A135 Notebook Logo
157 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
