Question about Oster 12-Bottle Wine Cellar - Black
I followed the instructions sent to me to obtain a refund on my non-working Oster 12 bottle wine refrigerator. My case was referred to as H03262008-1046. I mailed the a/c cord with the proof of purchase and serial number on July 21,2008 to Oster Appliance Support,R142-757 West Hastings STreet,Suite 617,Vancouver BC V6C 1a1a Canada. I received no feedback. Another reminder was mailed with copies of everything on October 16,2008 again with negative results. This was a gift from my son and has been a big disappointment from your company. Please respond in a timely fashion.
  • Oster Master
  • 5,569 Answers
This message and (perhaps previous ones), is misaddressed - this is a repair forum and has only links to vendors that are not connected with this forum. No products are sold from here and, to my knowledge, no physical items accepted for repair. This is probably the only reply you will receive and it is only a courtesy-
Posted on Dec 15, 2008
I have an Oster 12-bottle wine celler model OWO912H6H that was a Christmas gift in 2007. I just noticed the temperature is 98 degrees and I cannot get it to come down with the down button. I am very...
Hi, could be faulty thermostat, can you check compressor, is compressor running (working), listen to compressor for clicking sound, unplug it(switched off) for about 20 minutes, replug and let it run (work) for another 20 mins. see if temp. drops, what about temp. inside bottle (wine) cooler, is it 98 or colder, more info. could be valuable. check thermostat, check to see if compressor operates, if cooler temp. 98. remove you products, to another cooler, call mechanic.
Aug 12, 2009 | Oster 12-Bottle Wine Cellar - Black
Wine Cooler Does NOT get cool.
Here is the web site to locate your closest oster service center. They should be able to tell you what their charge will be up front so that you can compare that charge to the cost of a new one.
Now days, sadly, many of these items are too costly to repair so they go to the landfill..
http://www.oster.com/CustService.aspx?content=center
May 21, 2009 | Oster 12-Bottle Wine Cellar - Black
Oster 12 bottle wine frig, how to set temp instructions please
I suggest you return that puppy as fast as you can.
The company that makes them took bankruptcy and warranties are no good.
To top it off the fans usually **** out in 6 mos or so.
May 15, 2009 | Oster 12-Bottle Wine Cellar - Black
Don't cool-no refund/satisfaction from Oster.
Ok, fist problem was unit quit working..if it quit cooling yet lights still worked inside and still had power readings on door is not power coord. If the unit stoped cooling is probably fuse and there are two of them in back of unit. One fuse clearly can be seen, the other is coated with a black shrink fit coating and is not well seen. This second fuse is the problem, you will need to replace it. I have same unit and this is what I had to do to get it cooling again.
Jan 21, 2009 | Oster 12-Bottle Wine Cellar - Black
No response from company on Oster 12 bottle wine refrigerator
just replace the 5amp fuse on circuit board with a 6.3amp. tada!
use an exacto knife to remove the shrink wrap on both ends of old fuse. heat ends with a soldering iron and pull away old fuse. solder new 20mm in line fuse holder from radio shack to both poles insert 6.3amp fuse and done. at least mine works again! $6.00 total cost!
Dec 15, 2008 | Oster 12-Bottle Wine Cellar - Black
Fast start option does not work
I'm not sure how you ended up under this classification;
All Products > Oster > 12-Bottle Wine Cellar - Black > Troubleshooting
but your problem with an undescribed brand and model will not likely ever get a response.
I think your question is in regards to a microwave oven. Try reposting it with the correct brand and model #.
Nov 06, 2008 | Oster 12-Bottle Wine Cellar - Black
Oster 12 bottle wine cooler
You must remove the fuse from the circuit board to check it. More than likely it's blown. A continuity test while in the circuit will always show the fuse as being good due to feedback through the circuitry.
Aug 09, 2008 | Oster 12-Bottle Wine Cellar - Black
Oster 12 bottle wine cooler not working, no fan temp running high. What could be the problem?
Well... the best solution is use it for parts and toss the rest in the trash. Go to any web site that sells it and has reviews, read the reviews, and you will see why I came to this conclusion. I got one free on FreeCycle.org. After reading reviews decided it was not worth fixing. She had dropped the one I had, door broke. Basiclife.com
Jun 21, 2008 | Refrigerators
Broken door...
Buy a dented unit on eBay and take off the hinges
May 12, 2008 | Oster 12-Bottle Wine Cellar - Black
Oster 12-Bottle Wine Cellar - Black Logo
93 people viewed this question
Top Oster Furniture Experts
Steve Allison
Steve Allison
Pieter Vleeshouwers
Pieter Vleeshouwers
Rob Sinbad
Rob Sinbad
Are you an Oster Furniture Expert? Answer questions, earn points and help others
