Question about ASUS P4S533-MX Motherboard
Upgrading RAM from 512MB to 2 GB
My Pentium 4 with the motherboard mentioned in the title was running too slow with 512 Mb UNB PC2700 CL 2;
So I bought 2 sticks 1 Gb Samsung PC2700 DDR333 6NS CL2.5 to tune up. When I put in 1 GB Windows XP starts up normally; when I put in the second stick, Windows doesn't start at all and gets turning in circles. The board is installed in 2003 and can have a max of 2 Gb.
Should the BIOS be modified and/or updated and how do I do this?
  • leyman_h Dec 16, 2008
    My motherboard is a Asus P4S533-MX
  • Mike Fish
    Mike Fish May 11, 2010
    try the other stick by itself to check if its faulty, if the other stick is infact good, what is the brand/model of your motherboard and i will be sure to link you to the bios update
  • 104 Answers
Please click below and on the right side where it says general download in product select motherboard, in series select socket 480 and in the tab below select P4S533-MX then click search, it will then ask you of your operating system just select which corresponds to what you have installed, then click the + symbol next to bios, go down to version 1006 and click global, and save that file somewhere, ok now i want you to click the now - symbol next to bios and go to bios utilities, you will need to download Aflash V2.21, if at all possible you will have to make a bootable floppy disk to flash your bios, do this step by step please
go to this website
http://bootdisk.com/bootdisk.htm
look down the list until you see Windows 98 Custom, No Ramdrive and click Mirror1 download this and insert a blank floppy disk and then run the program it will make a bootable floppy disk, now you will need to take a second floppy disk and extract the Aflash program and the bios zip file to.
Now Restart the computer and press F12 to bring up your boot menu and select the bootable floppy
ok now insert the other disk with the extracted files on it.
4. In DOS mode, type A:\AFLASH <Enter> to run AFLASH.
5. Select 1. Save Current BIOS to File from the Main menu and press <Enter>.
The Save Current BIOS To File screen appears.
6. Type a filename and the path, for example, A:\1006mx.awd and then press <Enter>.
Posted on Dec 16, 2008
  • 1 more comment
  • Mike Fish
    Mike Fish Dec 16, 2008
    SORRY THIS IS THE ASUS WEBSITE YOU NEED TO GO TO FOR BIOS
    please click below and on the right side where it says general download in product select motherboard, in series select socket 480 and in the tab below select P4S533-MX then click search
    http://support.asus.com/download/downloa...
  • Mike Fish
    sorry DONT SAVE THE BIOS AS THAT NAME MAKE IT SAY SOMETHIN LIKE BIOS.AWD BECAUSE YOU WILL BE LOADING THE NEW BIOS AS 1006mx.awd
  • Mike Fish
    3. At the A:\ prompt, type AFLASH and then press .
    4. At the Main Menu, type 2 and then press .
    The Update BIOS Including Boot Block and ESCD screen appears.
    5. Type the filename of your new BIOS and the path, for example, A:\XXX-XX.XXX, and then press .
  • 35 Answers
.Yes you should update the bios. The asus support website has everything you need to do this also they will have step by step instructions to do so.
RAM chip sets
It is OK to mix chip (SODIMM) capacities in the 2 slots in your notebook.
The best system performance will be when you have 2 x 512MB but for now if you install 1 x 512MB, you could even leave the old chip in the other slot, it'll be fine.
Oct 19, 2007 | IBM ThinkPad R31 2656 Notebook
I am going to upgrade ram to 1 gb. can i use ddr2 1 gb ram to upgrade .motherboard is microstar model ms-6526 ver: 2 . present ram is ddr1 400 MHz, 512 MB
If your computer has two RAM slots on the motherboard, i would recommend trying it. The computer will run on the 512MB stick alone and just not recognise the other stick. And if it works it works.
I have searced for support documentation and came up with none for the original MS-6526
I run my original version MS-6526 on a 512MB PC2300 (DDR1) and a 512MB PC3200 (DDR1) and it runs just fine for games and videos.
Personally I would recommend trying the DDR2 first and if that fails, return the card and get a DDR1 card. They are expensive, but at least they work.
Oct 08, 2010 | Intel Microstar MS-6526 Pentium 4 ATX...
Not recognizing memory.
The Asus P4S800-X MB can use Dual channel DDR memory and single channel memory. The dual channel memory which comes in matching packs. (Normally 2 DIMMS per pack) is the faster memory.
In other words if you are installing, 4- 512MB DIMMS of PC3200 all memory should be matched,
or you're MB may not see all connected DIMM'S.
See page vii in you're manual. If you're running windows XP, Home or Pro edition the bios will show up to 4GB of memory installed but windows XP 32bit will only show 3GB of memory. As mentioned above all 4 of you're 512MB of memory should be dual channel and run at the same speed. You can run both single channel and dual channel but you must follow Table 1 in you're manual. (1-9).
Example; PC3200 400MHz.
Or 4-512MB PC2700 333MHz. See page 1-9 for memory configurations and the QVL list supported.
Check out Asus FAQ's; http://support.asus.com/faq/faq.aspx?SLanguage=en-us&model=P4S800D-X&product=6&os=17
This should help you configure the memory.
Mike
May 09, 2010 | ASUS P4S800D-X Motherboard
No memory
OS Vista minimum want 512 mb ram for run. & yiur only 512 mb ram which is used for your all program. So incres your ram Atleast
1 GB. 2 GB is best.
Jan 30, 2010 | Acer 4220-2346 Notebook
SLow running of Crazy Taxi 3 on PC
friend.
you should have ram with up to 2 gb .
although your processor is good but u need more video memory.
Mar 27, 2009 | Sega Crazy Taxi 3 for Windows
Acer Aspire T-180 Memory Upgrade question
Hello, You might be able to add 2GB more. 1GB per slot. You need to get the model # off your motherboard and verify what the maximum amount of memory it will support. 1GB per slot would be 4GB total but some Operating systems will only support 3GB. So some might be wasted if that is the case. You would need to use the same memory type. So if existing is PC2-4300, use the same. Hope this helps.
Mar 05, 2008 | Acer Aspire™ T180 PC Desktop
ASUS P4S533-MX Motherboard Logo
171 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
