Question about Frigidaire FRT21H8 Top Freezer Refrigerator
Water leaking onto top shelve of fridge
How do i clear my drain line it is all ice
  • 237 Answers
A steamer is what I use but you may not have that tool. VERY hot water can be poured into the cavity/drain hole over and over till it freely flows out the bottom to the tray or you can just turn off the refer for a day with the door open to let it thaw. To prevent freeze plug again you can hang a small copper wire on the heat element that dangles down into the first inch of the hole so when a defrost cycle turns on it will trasnfer heat and keep the hole from freezing up. A #10 or #12 copper wire usually transfers enough heat to keep the hole from freezing up.
Posted on Dec 15, 2008
Ice is building up at the bottom of the freezer. No drain at the bottom.
The drain hole could be behind the rear panel at the bottom. You will need to clear all the ice and make sure the drain line is clear.
Sep 10, 2017 | Freezers
Water leaking from bottom front, ice in bottom of freezer
Your drain line form the evaporator is clogged. Locate the drain under the back and use a wet/dry vacuum to unclogged drain. The drain line can be also blocked by excessive ice buildup from incomplete defrosting. Remove frozen foods and open door to freezer section and remove power and manually defrost unit. Once ice is stopped melting try vacuuming the drain line again. Sometime drain line gets clogged with debris such as garden peas, corn, wrapping and the like. Once drain line is cleared the water and ice on the freezer bottom should stop forming.
Hope this helps
Dec 12, 2014 | Refrigerators
Uline Echelon Ice Maker P1 error code
P1 is a indicator of a slow or clogged drain check to make sure that every thing is draining good if line is clear make sure pump is coming on to pump the water out of the bin. once all is clear unplug the unit for an hour then plug back in this will clear code unless you still have a drain issue.
Jan 17, 2014 | U-Line Icemaker
Subz 550 drain tube keeps freezing up, causing water to spill onto base of fridge and freezing
i know this is late but there's a heater kit made for this 4202160 is part number,you remove the shelves,you can put a mark under the shelf arm on the far outside where the shelves hook on so you can put them back in the same spot,then remove the light cover,the two screws and metal cover and then pull the wall off and set it to the side ,the drain heater kit plugs into the wire harness,the heater will heat up and keep drain from freezing,you can slide the tube off,stick a screw driver in to hold it down to the floor so you don't burn your hand and blow hot air into it with hair dryer to melt out ice,keep heat on for like 20 to 30 seconds then cold air or remove heat you don't want to mess the hose up from overheating wait a bit and hit it again until you melt out the ice,then i use a long plastic wire tie to stick into drain hose to clean it out,some nasty stuff in there,i use a steamer to clean the line out and then i have a piece of 1/4 inch plastic water line to snake into the drain,if this is the first time this has happened you don't need the heater kit,just clean out the tube and metal drain trough,also clean the back of the top crisper drawer shelf,crumbs and stuff can get in between the back wall and the top shelf and then will fall into the drain,if you keep that area clean you won't have to many issues and keep the fridge a little warmer so it doesn't freeze up the water in the drain tube,put the drain tube back onto the trough and pour hot water into it,if it drains down you're done if it's still blocked get a turkey baster and push hot water down into the drain tube to clear it,if it still doesn't clear remove the bottom kick panel,you'll see the drain pan and look at it because you have to get it back the same way in the clips then you can see the drain tube,stick a plastic tie up in there to clean it,sometimes there could be dust or something in the drain pan,when the water hits it it can get into the bottom of tube and block it but i've only had to do that once,hope this helps you out.
Nov 16, 2017 | Sub-Zero Bottom Freezer Refrigerator
Fan inside fridge not blowing
is the ice on the floor of the freezer?if so the freezer drain is blocked,ice is building up and the fan blade is jammed from the ice.when the machine gets cold ice forms on the evap coil in the freezer,when it goes into defrost the heater turns on and melts the ice and the water drains down a hole under the evap coil and the water goes down into a pan where it evaporates from the heat of the compressor and condenser coil but your drain is blocked and the water is leaking onto the floor of the freezer instead of going down the drain,i use a steemer to clear blocked drains but if you don't have a steemer you can use a hair dryer to melt out the ice,on your machine you can pull out the machine from the wall,remove the back bottom panel and unplug it first,then look at the right side,you'll see a plastic drain line with a wire tie around it,that's the drain line,you might have to cut the tie and then pull the drain line down and remove it,now go to the freezer,you have to remove the door and racks and then remove the back inside wall of the freezer,melt out all the ice that you see with the hair dryer,after you melt the ice go to the back and snake a long plastic tie like the one that's on the drain line or if you have a piece of 1/4 inch plastic water line or anything you can think of to snake through the hole where the drain line came off of,i would use plastic,if you use metal be careful not to damage anything,then pour hot water into the drain in the freezer,if it drains out the back hole you're done,if not keep hitting it with heat and if you have a turkey baster or anything that will push air down the hole to clear it and when you think it's clear pour more hot water into the hole until it drains.hope this helps and good luck with your machine.
Nov 15, 2011 | LG LFD25860TT Titanium French Door...
There is water dripping inside from the back ceiling of refridgerator. Also, freezing of food occurs on the top shelf.
next time send the model number,if the freezer is on top then you have a blocked drain in the freezer.unplug the machine or remove the bottom kickplate and you should see a tech sheet,it will tell you how to put the machine into defrost and the heater will come on to help you melt out the ice in the freezer or just unplug it.remove everything out of the freezer,remove the back wall and with a hair dryer melt all the ice,now you have to clear the drain,you'll see a hole under the evap coil,it has ice and junk in it,i use a steamer to clear out the line,if you don't have a steamer you can try a turkey baster or anything that will blow through the line to clear it out,you can open the fridge door and heat up the ceiling part in the middle to melt out the ice in the drain,when you think the drain is clear pour hot water into the hole,if it drains down you're donw if it doesn't keep heating it up until it's clear
Apr 10, 2011 | Kenmore Refrigerators
My Kenmore coldspot 71182100 which is almost 9 years old just started leaking water from the freezer onto the shelves in the fridge. I just cleaned out the freezer and got the ice out. There was not...
I have a Kenmore Coldspot Model #69207990 and have the same problem. Water from the freezer drains into the refridgerator onto the shelves and sheets of ice form. A repairman pointed out that the tube leading down from the freezer onto the drain pan was frozen. By pouring hot water down the tube, he reopened this drain line. Problem solved for six months and the drain line froze again. My question is how to stop this drain line from freezing up again.
Dec 16, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Water on floor from freezer side,ice build up on floor of freezer side
is it a side by side?if so you have a plugged drain,if you can remove the bottom draw or bin,if you can't shut down the machine and with a hair dryer melt out the ice,when you remove the bin look at the back wall at the bottom,there's a hole there,when the heater comes on the ice melts off the evap coil and the water should drain down the hole but it's not,you have to melt out the ice and clear the drain out,i use a steamer but you can use like a baster or try to snake something through the hole like a piece of the hose that they use for the water lines on the machine or a plastic wire tie,when you think the drain is clear pour hot water into the hole,if the water drains then it's unplugged,if like a half a cup of water doesn't drain down it's still plugged but you have to clear the drain,the line is made of plastic so don't go crazy sticking stuff in there that will cack the drain line or you'll really be in trouble.let me know how you make out
Nov 09, 2010 | Maytag Refrigerators
Water is leaking onto top shelf of fridge. It is a top freezer.
Sounds like you have a frozen drain in the freezer. You can remove the back panel of the freezer and take a turkey baster and run hot water down the drain line to clear it. Once its cleared you will want to dump an additional cup of water down to make sure that its clear. This will stop the defrost tray from overflowing when the unit goes into defrost. This is where the water is coming from.
Hope this helps _MJ_
Feb 16, 2010 | KitchenAid KSRA25ILSS Side by Side...
Why is ice continuing to form at the bottom of our GE frig?
these units have a defrost drain that gets plugged.
you need to remove the ice from the freezer section and try to use a "turkey baster" to force water into the drain hole. it may be frozen and need to run hot water to get water to flow thru the drain.
sometimes you have to remove the drain from the back underside of the unit to clear the line. try the hot water inside first and if you cant clear the drain, then go to the back and remove the restriction from the drain line.
Jan 08, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Frigidaire FRT21H8 Top Freezer Refrigerator Logo
122 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
