Question about American Standard 2555.501.295 Satin Town Square Single Handle Pressure Bal
I have installed an AS 2555.501 Pressure Balance Vave and now the water pressure in the shower is low
    Scholar:
  • 44 Answers
This problem happens quite regularly as the valve will reduce the pressure but sometimes it will reduce too much, you can adjust it up, but you havent mentioned which type of shower valve it serves?
as the shower may not be suitable for the plumbing supplies it connects too , & how they are installed?
i am thinking its from the cold water main & that the valve requires storage feed instead of incoming water main supply? possibly thats why you installed a reducing valve??
Let me know?
Kindly
Richie
Posted on Dec 15, 2008
I have a moen shower faucet where the water mixture keeps getting hotter with very little cold coming through. the temp must be set nearly all the way to cold to prevent scalding.
Sounds like a pressure-balance shower valve. The pressure balance cylinder is stuck. With water off, remove knob and trim plate. Remove pressure balance cylinder (horizontal). May be hard to get out. Use emory paper to clean up cylinder and smooth it so it moves freely. Reassemble and you'll be happy.
May 28, 2017 | Moen Home
I have a problem with low hot water pressure can you help would an elec shower help
1) If possible, it is Best to solve pressure problem before installing new shower.
http://waterheatertimer.org/Low-hot-water-pressure.html
2) If the cold water has good pressure, then Electric shower could fix problem ... but shower would have to be connected to the cold water line and not the hot.
3) Seems the expense of adding a electric shower would be greater than having plumber fix low hot water pressure.
Assuming you have access to plumbing pipes, and this is not apartment building.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 05, 2013 | Water Heaters
Low water pressure from shower head with the shower head removed
If you have good pressure at the water faucet close to the shower and low at the shower then the shower valve needs rebuilt. If you have low pressure at all then start going down the line toward the water service coming into the house looking for where the low pressure starts in the distribution system and you should be able to isolate the problem.
Feb 08, 2011 | Delta Home
Mira mixer cannot balance temp.either scalding hot or freezing cold
I suspect you have gravity fed hot water system and the mixer cannot balance the high pressure of the cold mains against the low pressure of the hot water.
Either install a shower pump. Means installing electrical connections and quite a bit of plumbing
Or a mechanical pressure reduction valve on the cold input pipe to the shower
Apr 02, 2010 | Legacy Home
Low water pressure. New installation, replacement
The posi temp valve has a little system built inside to anti scald you when your taking a shower, they have little parts that move back and forth, they get easily clogged from sediment and minerals in the water and always get stirred up when the water is turned off and back on from doing work.
Mar 17, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Would like to increase water pressure
You will need the expertise of a Plumber, this is beyond the scope of this forum.
Jan 26, 2010 | American Standard 2000.502.002 Ceramix...
Low water pressure
When it was installed was there any copper sweating done? If so, the valve cartridge can get fried if not removed prior to the immense heat from a torch.
Jan 23, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Installed a new oak brook collection tub and shower faucet and no water comes out.
You may have to disassymble the faucet to see if there is something that is stuck in there or that the assymbly internally is stuck in the closed position.
Mar 19, 2009 | Ace Hardware OAKBROOK COLLECTION DESIGNERS...
Just installed shower and faucet in bath tub when you turn the water on the water comes out of the faucet and shower head. When you pull the lever for just the shower the water cuts off at faucet and comes...
Verify the height from the shower valve to the Shower head, the instructions specify the correct distance if it is too short the pressure could be getting up to the shower head.
Perhaps the water pressure it too high at the valve not allowing all the water down the faucet outlet, there are set screws on the sides of the shower valve to adjust the water allowed in the mixing chamber.
Something is restricting the water flow to the faucet, creating enough pressure to send some of the ater supply up to the shower.
I hope some of these ideas help
Mar 01, 2009 | Plumbing
Moen single handle valve tub/shower
The Moen Posi-Temp Valve is a pressure balanced valve and when not used for long periods of time they can stick causing only cold or hot water to pass through the valve.
A New Posi-temp cartridges can be purchased at most plumbing supply houses or big box outlets such as Lowes or Home Depot.
As long as you had cold water before, a new cartridge will solve the problem. In the future it would be wise to occassionally operate the valve at least a couple of times a month in order to keep the pressure assembly from becoming lodged in position. Just follow the instructions included with the new cartridge on the proper removal of the old cartridge and the installation of the new cartridge. a little silicone grease inside of the valve before installing the new cartridge will also help.
Be sure that there is no particles of the old cartridge left in the valve.
sanray
Dec 27, 2008 | Moen & Posi-Temp Single Handle Shower Or...
American Standard 2555.501.295 Satin Town Square Single Handle Pressure Bal Logo
208 people viewed this question
Top American Standard Home Experts
Mike
john h
hvd713
Level 1 Expert
Are you an American Standard Home Expert? Answer questions, earn points and help others
