Question about Brother Multi-Function Center MFC-665CW All-In-One InkJet Printer
I have a Brother MFC-665CW printer/fax machine. It jammed with paper and once I had cleaned it up the screen now reads, Unable to print 30. I can't do anything. Does anyone know how I can fix it please? Thanks.
    President:
  • 8,637 Answers
Normal 0 In most cases it works. Worth a try.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
How can we fix when a mesage says unable to print 50?
paper jam or some sensor problem, clear the paper jam, or clean the sensor under the pump.
Jul 30, 2014 | Brother MFC-665CW All-In-One InkJet...
Unable to init. 50, Unable to Init 30,
paper jam or some sensor problem, in error 30, clean the strip encoder located at the top of the printer head, his color is transparent.
Jan 04, 2014 | Brother MFC-665CW All-In-One InkJet...
Im getting unable to print 50 error on my brother mfc 665cw
The paper jam you had probably lifted the long, thin, plastic encoder strip out of its slot. It is making the printer think paper is still jammed. Try gently pushing the strip back into the slot. You might have to use a screwdriver or other thin instrument to get to the strip.
Be sure printer is off when you do this.
Sep 18, 2011 | Brother MFC-665CW All-In-One InkJet...
Will not print or shut off comes up unable to print 50
I had this same problem and it is an easy fix. It is similar on all brother printers but mine was a 5860CN.
Lift the lid on your printer and at the back you can see the opening where the print head is.
With the power off, use your finger to move the print head into the middle.
Now feel under the lip of the cover at the front of the gap and you will find a plastic strip that runs from one side to the other. This is the encoding strip and it what the print head uses to read where it is. This encoding strip is easily pushed out of position when a paper jam occurs and all you need to do is to get it back into position. Using both hands use a finger on either side of the print head and lift the encoding strip upwards slightly and move slightly towards the back of the printer. This will locate it back into the correct position in the print head when you release. You can feel this with your fingers. Power back on and the problems will be gone!
Remember and be gentle so as not to damage the encoder strip!
Nov 27, 2010 | Brother Multi-Function Center MFC-665CW...
I'm getting an error saying Unable to print 30
  1. Clean all feed wheels and guides with methylated spirits.
  2. Look for any switch or guide that may be bent or out of place. This could have been damaged when a jam was removed.
  3. Look for any small piece of paper or staple that may have lodged in the paper path somewhere.
  4. Ensure the paper is dry. Not stored in a cupboard in the kitchen or the printer is not setup infront of an air vent.
Nov 17, 2009 | Brother MFC-665CW All-In-One InkJet...
Unable to print 30 or 50
the encoder strip is probably out of its socket. its a long mylar strip that goes from one side to the other, and goes underneath the printhead.
Jun 25, 2009 | Brother Multi-Function Center MFC-665CW...
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
I have a brother mfc 665cw printer, had a printer jam, cleared the jam and now recieve unable to print 50 error, unable to copy or print. Have found some information about the encoder strip but I have no...
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Jan 05, 2009 | Brother Multi-Function Center MFC-665CW...
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
Brother Multi-Function Center  MFC-665CW All-In-One InkJet Printer Logo
160 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
