Question about JVC SR-VS20 Mini DV/S-VHS VCR
JVC SR-VS20U Program and Menu button not responding
I've had this VCR for a few years and it's always work great. Recently I changed from 12 Bit Mode to 16 bit Mode and while in this menu I went into the Output Settings mode, and when I clicked on "Output 1", I must have changed it from "Auto" to something else because the screen on my Sony NTSC monitor went static, and I can no longer access my Program button or Menu button on my remote, They are both non-responsive. All other buttons seems to responded fine. Please advise.
  • Maurice Coffee Mar 22, 2007
    Solved myself. After several attempts at getting these buttons to work again, I found success with unplugging the VCR, removing the batteries from the remote. Re-installing the batteries then plugging the VCR back in. Once I turned the system back on using the power button on the VCR, everything was back to normal.
    Top Expert:
  • JVC Master
  • 76,016 Answers
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Posted on Jun 06, 2017
jomaru
  • 337 Answers
SOURCE: Can't see menu to programme VCR
Try unpluging the unit from the wall for about 5 minutes then plug back in and turn it on,this will reset the brain and go back to normal.
Posted on Oct 05, 2006
  • 275 Answers
SOURCE: How to hook-up my VCR to NTSC TV?
Zohar, You must remember that various regions in the world have different Broadcast systems. TVs and VCRs are manufactured for playback and Recording in different regions. But, while the JVC HR - J 437MS is a Multi System VCR as far as Playback is concerned, It has only a PAL Tuner. So , while you can watch NTSC Tapes, you cannot tune a NTSC Broadcast through its tuner, and watch on your TV. You will only get a B&W picture. To atleast view NTSC Tapes, use the Remote of the VCR, and set System to AUTO or NTSC. Again, there are 2 versions of NTSC - the 3.58 and the 4.43 ones. Certain regions of the US broadcast in NTSC 3.58, and some in NTSC 4.43. So select carefully, Similarly, bring up the TV menu, and select AUTO or NTSC for TV reception. Now you will be able to view American broadcasts in color.But I suggest you set System to AUTO, as then you can watch your earlier Tapes collection from Europe also. As for connections, it is fairly simple. I am uncertain if your VCR has a 21 pin euroconnector (SCART)but it is unlikely. You will be having Audio L and Audio R out ockets at the rear of the VCR, alongwith Video Out socket. Just connect suitable RCA cables from these OUT sockets to the Video and Audio IN (L) and Audio IN (R) siockets on the TV. select AV input, and you are ready. check it out. 99% it will be work out.
Posted on Jun 21, 2007
SOURCE: Hr-J437MS VCR
This Multi standard machine will play back NTSC 4.43 and 3.58 with no problem
Posted on Jan 17, 2008
SOURCE: Cannot bring up my VCR's On-Screen Menu
You'll need to unplug the unit, wait a minute and then plug it back in. This happens to me on occasion.
Posted on Jan 19, 2008
  • 579 Answers
SOURCE: vcr does not respond to tv/vcr button on remote
You will not know from looking at the VCR if it is in VCR mode or TV mode. This is more likely a TV issue of whether the TV is monitoring the VCR or not. Make sure you have the TV selected so that it is monitoring the VCR.
That VCR/TV button has caused more confusion for the average person than anything else.
Hope Ya Fix It!
Posted on Jan 25, 2008
Monitor changed from 32 bit to 16 bit
go into video mode screen and check on your video driver for the video card.
Jan 30, 2014 | Computers & Internet
Error message unsupported 16 bit application
16 bit software is not compatible with 64-bit engines.
The lowest number of software bits, called bit width, a 64b system can sometimes run if lucky, is 32b.
16 bits is the equivalent of 1 byte.
64 bits is therefore 4 bytes wide.
This means that the 64b system reads digitally coded instructions 4 bytes at a time, as one function to perform.
So if it tries to read all 4 bytes of a 16 bit 1 byte program it just sees meaningless garbage.
In fact, the header of the program file will ID it as 16 bits so that the 64 bit system knows not to even try to run it, as random weird instructions could corrupt or damage the computer.
Dec 04, 2017 | Activision Hyperblade for Windows
How can I find out if my SD card reader would take SDHC?
According to the specs it takes MMC and SD cards, so I would say it does not take SDHC cards. If it does, the marketing department would certainly have said so.
SDHC cards are electronically different and will only work in devices specifically designed for them. Older devices designed to work only with SD cards will not work with SDHC cards, no matter how much the firmware is updated.
Oct 26, 2012 | Panasonic PV-GS400 Mini DV Digital...
How to Run Turbo Pascal Full Screen mode on Windows 7
Now that's a program I've not worked with in a while ;-) I haven't used it since my early high school days in the 1990s. Turbo is a really old application that has been around for ages- unfortunately, being as such, it is only capable of developing 16-bit DOS applications, which has, for better or worse, gone the way of the dinosaur. In the x64-bit versions of Windows Vista and 7, all 16-bit native support has actually gone out the window in favor of 32-bit and 64-bit application development. This is why DosBox was invented- it is a true 16-bit DOS environment (much like command.com and CMD.exe used to be) that is capable of running all the older DOS programs that are no longer compatible with Windows.
When you run Turbo from the DOSbox program, press ALT-ENTER and it will fullscreen whatever you're working with.
Hope this helps,
- Vern
Mar 24, 2012 | Computers & Internet
At 1440x1200 resolution the monitor (719Sw) visualizes fine, but a window appears saying "input not supported". Does my cpu not support this monitor. Its a P4, 32.99 ghz 504 mb ram machine
Restart the computer
2 While the computer is loading, press "F8" key on the keyboard right before the
computer reads the hard drive or press the "F8" key multiple times in 1 second
interval until the "Windows Advanced Options Menu" appears on the screen
3 Under "Windows Advanced Options Menu", using the arrow key on the
keyboard, select "Enable VGA Mode" then press Enter. Select "Windows 2000
or Windows XP" for your operating system.
4 Wait while the computer is loading and once the computer finishes loading,
5 Right Click anywhere on the blank area on the desktop then click "Properties"
6 Click on "Settings"
7 Click on "Advanced"
8 Click on "Adapter"
9 Click on "List All Modes..."
10 We recommend that for 15" LCD's select 1024x768, True Color (32 Bit) 60
Hz or 1024x768, High Color (16 Bit), 60 Hertz; For 17" & 18" LCD's select
1280x1024, True Color (32 Bit), 60 hertz, or 1280x1024, High Color (16 Bit)
60 Hertz, or
640x480, 256 colors, 60Hertz or 75Hertz
640x480, High Color (16 bit), 60Hertz or 75Hertz
640x480, True Color (32 bit), 60Hertz or 75Hertz
800x600, 256 Colors, 60Hertz or 75Hertz
800x600, High Color (16 bit), 60Hertz or 75Hertz
800x600, True Color (32 bit), 60Hertz or 75Hertz
1024x768, 256 colors, 60Hertz
1024x768, High Color (16 bit), 60Hertz
1024x768, True Color (32 bit), 60Hertz
11 Additional Valid Modes for use only with 17" & 18" LCD Monitor
1280x1024, 256 colors, 60Hertz
1280x1024, High Color (16 bit), 60Hertz
1280x1024, True Color (32 bit), 60Hertz
May 17, 2011 | AOC 917Sw 19" LCD Monitor
Do I set the audio to 12 or 16 bit? in the settings
More bits equals better sound but more data, so you need to decide if you have enough storage space to get better sound with 16 bit audio, or if space is more important and you need to save as much as possible by using 12 bit audio. Try them both if you aren't sure and see if 12 bit is good enough. If it is, you could probably set it to that and leave it.
Apr 26, 2009 | Audio Players & Recorders
How do I use 2 mics for the XL2 simultaneously?
Hi, on the left side of the camera you can set 'audio monitor'. Default is channel 1/2. You can choose to listen to 3/4 or 1/2 and 3/4 simultaneous.
In the menu of the cam you can set between 12 bit audio recording or 16 bit. 16 bit only records on channel 1/2 (the front mic). In 12 bit mode you can record audio on 4 channels.
hope this answers a bit of your question
Mar 17, 2009 | Canon XL2 Mini DV Digital Camcorder
I just bought a 64 bit operating system Vista Home Premium Computer and it won't load a 16 bit software application. Is this normal? Is there anything I can do to my computer to change it from a 64 bit...
You can try running the 16 bit app in compatibility mode. Right click on the app's exe, click on properties, and select compatibility, then tick the box labeled "run in compatibility mode", then select Windows 98 from the now available drop down box.
Dec 25, 2008 | NewTek Video Toaster 2.0 (512 MB) Graphic...
Can't transfer dubbed audio (secondary sound) using firewire.
Audio Dubbing on DV: Here's how you do this: Play your tape on the TRV-9 and feed the signal into the TRV-900, using the Firewire connector. Set the TRV-900's audio option to record in the 12-bit mode. When this is done, you will have the video re-recorded on the TRV-900 and the audio laid down on the primary 12-bit audio channel. Then, you can run the tape back through for a 2nd pass in the TRV-900, with the recorder set to the audio-dubbing mode. The audio you put into the TRV-900 this time, will be recorded on the secondary 12-bit channel. You can select either 12-bit channel when you play the edited tape back or you can mix both stereo channels into the output. Once you record on the 16-bit channel, you can't dub audio back onto that recording, without erasing the original channel, as the recording space for both 12-bit channels is occupied. You can't selectively re-record just audio onto the 16-bit channel either, without the video being re-recorded along with it. Both video and audio are sent over the same Firewire connector, so you can't input them from mixed sources, as you can with analog recordings. Only the secondary 12-bit audio channel can be used in the audio-dubbing mode. You can't dub onto the 16-bit channel or onto the primary 12-bit channel. The primary 12-bit channel can be used only when you're recording video along with it.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
JVC SR-VS20 Mini DV/S-VHS VCR Logo
97 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
