Question about Panasonic KX-TG4000B 4-LIne Multi-Handset Cordless Phone System
The number 1 button will not work unless extreme force is used
I have to press REALLY HARD to get this button to work. That is the only button with the problem.
This is a very common problem with the KX-TGA400B and KX-TGA200B handsets. You need to replace the keypad or send it out for repair. Google "KX-TGA400B improved rubber keypad". Do not use the original factory keypad, the contacts are to small.
Posted on Dec 15, 2008
I have a 2002 ford explorer and sometimes its hard to shift to drive and the brake lights don't work unless I press really hard on the pedal.
*Hard to shift:
-Possible the shift cable need to be adjusted.
*Brake light is no working unless step(press really hard).
-Need to adjust the brake light switch. It's too closed or stuck.
Mai
Aug 09, 2013 | 2002 Ford Explorer
Kenwood excelon ddx 7015 car dvd password forgotten
You need to reset the system first by pressing the small button right next to using a ball point pen or something pointed... once it reboots, keep the button pressed till the display goes off, then while keeping the button pressed, press the button for 3 seconds, while keeping both of these pressed at the same time, press the small button next to the button using something sharp... this hard resets the system and it reboots to a blank screen, press the button once and you have all the options working.
Thank you and
good luck!
Dec 06, 2010 | Kenwood Excelon DDX-7015 Car DVD Player
Startup
TRY HARD RESET
1) Start->Settings->System tab->Master Clear->1234->ok
2)Press soft-reset for 15sec.
3)Remove the battery, Simultaneously hold volume(-) button and red hangup button, while still holding those keys, insert the battery and wait for the led to go out, release keys and device will hard reset
the 3rd option really worked for me
May 28, 2010 | i-mate Jama 101 Smartphone
My L and R buttons don't respond when I am playing a game that uses them. They will only respond when I push down extremely hard multiple times. Help?
Get a tissue and damp it a little bit with water but not to much, then drop some water in to the crack or the L and R button. But lift the buttons up first. the take a Q-tip and clean the cracks. Then blow really hard on both buttons cracks(Create a seal on lips first when you blow)Like you kissing it. Then press on them repeatedly then BAM!!. If that doesen't work then lift up both buttons gently and then take it up. Then you'll see a bar then a spring, take the spring off and just use it fro there. If you okay...., with your buttons not coming back up but the'll work fine
Oct 04, 2009 | Nintendo DS Lite Console
Help :(
hi,
if you use it stationary only, u may think about an external keyboard(make sure it has either a ps/2
jack in the back or usb-port to attach a usb-keyboard to)
if not:
-carefully dissamble the laptop ( see paper or data manual first!), try cleaning the buttons/pressing-compound( it looks very similiar to a calculator/mobile phone interior),
reassemble and try again.
when still facing the prob:
- check for the exact model number and see if there is a new keyboard available from the manufacturer, then u will have to (let s.o. else?) exchange the parts - this may work.
good luck
Aug 04, 2009 | Computers & Internet
27998GE6-C phone and buttons stick
The buttons got "sticky stuff" on the conductor pads. There is not much you can do unless you open the handset which I do not recommend unless you really know what you are doing.
If you do, or, are foolish or brave, open the handset, remove the rubber button pad and wipe the circuit board with rubbing alcohol. DO NOT USE ANY OTHER SOLVENTS.
Good luck.
Joequevedo@charter.net
Mar 16, 2009 | GE 27992GE5 Cordless Phone
When I press the shutter button, I have to apply more force.
I will use a q-tip with some denatured alcohol or isopropyl alcohol (91 percent or better) over Precision Cleaner any day. You should too, unless you just feel like blowin eleven bucks!
Thanks for coming to FixYa. If you liked my answer, dont forget to vote FixYa.
Rob
Feb 22, 2009 | Canon PowerShot G5 Digital Camera
Ps2 controller dual shock does not work properly with nascar 2009
it is in the nature of the game.... some games requires a hard pushing button to activate,,, for example the metal gear solid snake,... light press will aim the gun and pressing it hard makes the trigger and go for the fire...
Feb 12, 2009 | Sony PlayStation 2 (PS2) Console
Is there a way to "reset" the memory
This is the total reset process step by step i found it on
www.avicx1forums.com and it worked fine.
REMOVE DISK
HOLD RESET AND EJECT
RELEASE RESET BUT HOLD EJECT
SCREEN WILL GO BACK IN AND OUT-THEN SAYS PLEASE PRESS THE RESET BUTTON…DON’T
THEN WITH JOY PAD PRESS …
UP,RIGHT,UP,RIGHT,DOWN,RIGHT,DOWN,RIGHT…THEN OK (JOYPAD BUTTON INWARDS)
PASSWORD SCREEN WILL COME ON SCREEN BREIFLY
TEST MODE SCREEN APEARS-CLICK JOYSTICK TO RIGHT ONCE
SCROLL DOWN TO NUMBER 6-PROGRAM FORCED WRITE (OK)
FIND NUMBER 1 SYSTEM PROGRAM (INSERT DISK --CNDV 40/50/60?)
PRESS 1 SYSTEM PROGRAM (OK)
SELECT 2 DVD/CD ROM (OK)
SELECT LANGUAGE… (ENGLISH)
PRESS (VIEW –POS) BUTTON
SHOULD SEE SYSTEM PROGRAM GOING UP IN %
WHEN FINISHED PRESS (BACK)
FIND NUMBER 6 PROGRAM FORCED WRITE AGAIN (OK)
NUMBER 3 APPLICATION PROGRAM (OK)
SELECT 1 UK ENGLISH...THEN PRESS (VIEW – POS) BUTTON
SHOULD SEE SYSTEM GOING UP IN %
TEST MODE PAGE 1
SELECT 6 - CLEAR BACK UP MEMORY (OK)
SHOULD SAY FINISHED THEN ASKS FOR RESET BUTTON TO BE PRESSED
PRESS RESET ON FRONT OF UNIT
START SAT NAV AGAIN
ASKES FOR LANGUAGE PRESS NO (READ TEXT)
SYSTEM STARTS
BUTTONS
OK = JOYPAD INWARD
BACK = JOYPAD TO THE LEFT…NOTE THIS WILL BRING YOU BACK TO PREVIOUS PAGE
BACK = BAND BUTTON ….NOTE THIS WILL TAKE YOU BACK TO THE MAIN MENU
May 09, 2008 | Pioneer AVIC-N1 In-Dash DVD Multimedia AV...
Funny Keyboard
your layout change
Mar 21, 2008 | Acer NSK8458AN Keyboard
Lands Phones Logo
307 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
