Question about Intel D915GVWB Motherboard
Not Booting I am using D915GVWB motherboard with 3.0Ghz P-4 processor with 512MB RAM.and 80GB HDD& CD ROM both connected with IDE bus. After pressing the start butten in a second PC hangsup (stop) at a code display ''5A'' ,after someany times pressing restart & start button it boots normaly. I even changed my boot options and had a trial but same problem, system stoping at boot screen with code 5A.
  • 58 Answers
Hi, This is an old board trying to run a hungry CPU. From the symptom you describe the poor thing may be wearing out right in front of you. Anyhow, - In order of likelihood your problem(s) are probably:
1 - Defective motherboard. PC chips is well known as a maker of cheap mobos. When run even a little hot they have a short lifespan. A 3Ghz Pentium Prescott needs a lot of power. A faulty part may not always kill a session but it can ruin your life. Try running the PC underclocked at ~2Ghz. See if the prob goes away. If so, better cooling the support chips may help. Best solution is replace this old warrior with a new mobo. You will also need a new PSU & CPU if this is the problem. Except for playing games, even slow dual core CPUs will perform better than a single core unit.
2 - Bad PSU. These also wear out, especially if run hot. Best solution is new PSU. If you do this, get a modern model that will handle a mobo upgrade should that also become necessary. Many options & prices here - be careful.
3 - Bad PCI card or RAM. If you already haven't - try removing all unnecessary hardware... then test for problem. Switch your DDR2 RAM in & out to test for defect.
4 - Bad CPU. Not likely but possible. try running the PC underclocked at ~2Ghz(if this mobo lets you). See if the prob goes away. If so, better cooling might be the hot tip
Posted on Dec 17, 2008
  • oloo Dec 17, 2008
    Mmm, that's what i get for multitasking. Of course the D915GVWB is not a PCchips board but it is still a pretty old board.
Can i use 2.8ghz cpu for my p4s533-e?
this is what asus says:
arrow-org.gif Latest P4 CPU Support
The latest P4S533-E motherboard supports Socket 478 Intel® P4 processors, which utilize the most advanced 0.13um process technology to provide frequencies up to 2.53GHz
Mar 23, 2010 | ASUS P4S533-E Motherboard
Hard Drive Upgrade to Dell Dimension 3000
Try this Boot to the BIOS
press ALT+E (single Beep)
ALT+F another beep
ALT+B system will reboot and re-detect drives
once done, you should be able to install XP on HDD
Dec 30, 2009 | Dell Dimension 3000® Pentium® 4...
Hmmm.... mainly you have:
-20 or 24-pins connector, that is unique and goes directly to motherboard (powers motherboard and its components)
-4 or 8-pins connector that powers CPU
-the rest would be connectors for ROM (CD/DVD/BlueRay) and HDD devices (there are: molex and sata power conectors)
If you totaly unshure, there is manual:
Illustrated How to Replace an ATX Power Supply
Sep 05, 2009 | Computers & Internet
Finding Intel 845GVSR & 915GLVG Compatible Motherboard & Proc
you can use intel dg41 mbd , dualcore processor,1 gb ram,160 gb hdd or use intel atom for support contact 91-9645071021
Aug 11, 2009 | Intel D845GVSR Motherboard
Computer starts up then shuts off
make sure you pushed the ram ships in all the way.also make sure that you didnt unhook anything from the mobo when you opened your computer.
Feb 19, 2009 | MSI P4MAM2-V Motherboard
Windows won't load or instal
Freezing of computers occur mostly due to shortage of RAM. But in ur case, 1GB is quite enough for XP. Since ur computer is freezing b4 even starting up, thus it could be a problem of disk drives.check if more than 1 drive have been alloted MASTER (Primary) or otherwise same priority. If u have more than 1 HDD, then the one in which the Opering System is installed should be given the Master Primary and the other as Cable select/slave. Likewise do it for the CD/DVD ROM or RAM (the CD/DVD RAM should be alloted the master and ROM as the slave). It can be done by the JUMPERs on the back of the Drives. See the exact setup on the drive surface.
Oct 09, 2008 | MSI K9MM-V Motherboard
Moterboard problem...............
hi buddy!
1. check the monitor if working normal & the wire
2. check the video card also and try to clean
3. check the ide cable or sata connected to the HDD
4. try to chance another cd-rom or use a paper clip to open a emergency eject button, you see to your cd-rom have a small hole ok thnx
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Jun 24, 2008 | Intel Motherboard
Mobo only one ide connection socket for HDD & CD-Rom
yes you can add both your HDD and CD-ROM Drive with the same IDE, get a IDE data interface cable (BUS) atleast three connection point. Add 1 to mobo, second to HDD and top 1 one to CD-ROM drive. Just connect and dun wrry m sure it will
If any problem just Ask me
Apr 07, 2008 | Computers & Internet
New Installation P5N32-E SLI
There is also a 4 pin power connector cable for the processor to connect onto the motherboard. Make sure that is plugged in. IF that still doesn't help, disconnect hard drive, video card, cd rom drive and floppy drive and any other pci cards in the system. Try booting it again at least to the bios. See if that helps.
Mar 27, 2007 | ASUS P5N32-SLI Deluxe (890552603794)...
Intel D915GVWB Motherboard Logo
162 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
