Question about Car Audio & Video
Clarion DXZ385USB installation
Installing it in a 92 protege and i was wondering what wires are necessary to hook up? the wires in question are a 15a fuse connected wire, and a 3a fuse connected wire.
4 Suggested Answers
SOURCE: How to install the wires for a Clarion DXZ375MP
there shold be a "hot at all times" wire in the dash where the old deck came out of, that is what you want to wire them too.
Posted on Dec 24, 2007
HitWizard
  • 67 Answers
SOURCE: Clarion DXZ785USB - Connecting Fused Lines
You will definitely need to connect the Yellow Wire Memory Back-Up Lead, since this is the connection from the radio to the battery that stores the time and your presets. If it is not hooked up, you can use the radio, but all your settings will return to default once you turn off the car. The Yellow Wire Bus Power Lead sounds like it would be for powering an auxiliary unit like a Sat Radio or HD Radio add-on. You will not need to connect this unless you have an add-on such as one of these.
Posted on Jan 29, 2009
  • 239 Answers
SOURCE: I need a wiring diagram for a clarion DB186MP head
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
Posted on Aug 19, 2010
Wiring hook up for clarion DXZ585USB
yellow battery
red accessory
black ground
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
pls rate people arnt rating hope this helps
Apr 22, 2010 | Clarion DXZ385USB Car CD/ MP3 Player
I need to know what wire is for my dimmer
orange/white wire.
if you mean in the vehicle - the make/model/yr is required.
CLICK HERE for your manual - at the end is the installation wire guide.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 01, 2010 | Clarion DXZ385USB Car CD/ MP3 Player
I having problems getting my subs to play through the cd player!!
More than likely you have hooked up the power anttena wire as your remote turn on. So hook up the OTHER blue wire to feed your amplifier, and problem solved.
Aug 07, 2009 | Clarion DXZ385USB Car CD/ MP3 Player
Just installed my dxz385usb. powered up and got
Check to make sure that the speaker negative and positive leads are not touching. I had the same issue on a 97 maxima, and found the rear speakers so damaged that the (bare) leads on the speaker itself were touching the basket of the speaker, shorting the whole thing out. I disconnected the rear speakers and it started working.
Jul 04, 2009 | Clarion DXZ385USB Car CD/ MP3 Player
I need the wiring diagram for my new Clarion dxz385usb
Brown wire-Phone mute Yellow 3A-Bus power lead Yellow 15A-Memory backup lead Red-Power lead Blue/White-Amp lead Black-Ground Orange/White-Illumination lead Blue-Auto antennae SPEAKERS(black strip is -ive) gray+gray/black-front right white+white/black-front left purple+purple/black-rear right green+green/black-rear left
Jul 02, 2009 | Clarion DXZ385USB Car CD/ MP3 Player
My clarion dxz385usb has no sound.
Check to make sure exposed wires aren't grounding themselves out. I just had this problem and after 2 days of re-wiring and re-checking almost every wire I finally found the culprit. The Remote wire from my amp has become exposed and grounded itself out. Unit worked fine, same problems you are having.
Jun 13, 2009 | Clarion DXZ475MP CD Player
Clarion DXZ385USB will not play from the usb input
It is not compatible. I had the same receiver and mp3 player. according to the Clarion website, an "ERROR 5" is the message for a compatibility problem. You probably got an "ERROR 2"(format problem) when you had the player plugged in and then cycled through the sources(that's how I received the error).
I have since bought an Ipod and the USB input works just fine. Clarion says the deck is MTP compatible, but it will not run a lot of MTP devices. Only Ipods and certain memory sticks. The Creative Zen Vision M is read as an MTP device when it it plugged into anything like a computer, Xbox 360, and the Clarion USB receivers. The Clarion units even attempt to read it as an MPT device, but will not play. It is not an issue with the receiver or the MP3 files. The Creative Vision M is not a compatible device, sorry.
May 29, 2009 | Clarion DXZ385USB Car CD/ MP3 Player
I just got a Clarion DXZ385USB deck installed, but the screen does not appear blue as in the product pictures. It is dark and barely readable. Dimmer is turned off. Any ideas?
I didn't have to connect the illumination lead. If you have the battery wires(yellow) connected, the screen will light up pretty bright. When I connected the illumination wires(orange), I got the same dim screen light effect.
Apr 17, 2009 | Clarion DXZ385USB Car CD/ MP3 Player
Nov 28, 2007 | Clarion DXZ375MP CD Player
Car Audio & Video Logo
327 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
