I set up a voice recording and followed all the setup instructions as best I could. There all no messges on the answering machine. I erased all of them. the handsets and base unit all show > new voice mail - how do I get this message off the units.?
SOURCE: greeting was somehow erased
Hi Sherrie, I am sorry to hear about your husband, I will do what I can to help. I am fairly confident on that model that if you push the greeting button, then delete it will erase the message for good. Also, if the memory power failed, then it would reset to the default greeting and erase all messages and greetings. However, if the unit has options for multiple greetings (ie. default greeting, greeting 1, greeting 2, etc., then perhaps the default greeting may have been selected, while your husbands greeting is still there but is recorded under say greeting number 1. If that is the case, you can select it to play his greeting instead of the default greeting to have it play. I would find out for you but my computer is having trouble opening the manual on the Panasonic site, so here is the link. Look under "greetings" in the index. Hope I helped. Thanks, CG http://service.us.panasonic.com/OPERMANPDF/KXTM150B.PDF
SOURCE: Panasonic Auto-Logic 2line syst dual standard cassette needs help
If the unit answers reliably but isn't recording, it probably just needs new cassettes, new drive belts and a good head cleaning. If you can find a service shop that works on cassette decks, they could
probably look at the machine for you. These are the same things you need to do to a stereo deck occasionally.
On the other hand, if the machine is not picking up at all sometimes, there may be electronic problems and you might have to check Panasonic's website for service options. Parts availability for something this old could be an issue.
SOURCE: how do i record a answering message on my panasonic answering m/c
Hello jmkraus,
To record a greeting message on the Panasonic Panasonic KXTG1855.
(2 minutes and 30 seconds max.):
1 Press [OK]
2 Press up/down [^]/[V]: 'Answer System' : [>]
3 Press up/down [^]/[V]: 'Record Greeting' : [>]
Hold the handset about 8 inches away and speak clearly into the microphone.
4 Press [OK] to stop recording.
5 Press [OFF]
Here's the Panasonic KXTG1855 manual download link:
http://phone.manualsonline.com/manuals/mfg/panasonic/kxtg1855.html
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
SOURCE: panasonic kx tg8231cb. The screen
Press and hold the "mute" button until you hear a beep. That should clear your screen!!
