Question about Brother SE-270D Computerized Sewing Machine
Sewing machine slows down - Brother SE-270D Computerized Sewing Machine
  • 3 Answers
Have you tried moving the little side to side lever that increases the stitching speed?
Posted on Dec 16, 2008
3 Suggested Answers
riclap
  • 3 Answers
SOURCE: tacsew lu-563 sewing machine
Generally going to have to be addressing the drive motor, either substituting a lower speed clutch motor for the existing one, ie if you have 3000 rpm motor, then going to a 1725 rpm motor. Alternatively, selling the clutch motor and buying a servo motor instead, which should be available with a variable maximum speed control. The Sewquiet 4000 can select different speed ranges with the flick of a switch. If you already have a servo motor and it does not have a variable max speed, then switching the drive pulley on the servo motor to a smaller size should help
A more convoluted solution would be building a support under the table for a layshaft with different pulley sizes so that the motor could drive one pulley and then a smaller pulley on the shaft would drive the sewing machine. Not a bolt on solution but pretty cheap to do if you are good at fabricating.
Posted on Jan 01, 2009
  • 980 Answers
SOURCE: why does the sewing machine slow down on it's own.
Either it is lacking oil, or the motor may be at fault.
Posted on Apr 10, 2010
Brother serger slows down
it could be the motor or the power cord or the foot pedal,
check to make sure the power cord and the
foot pedal are connected correctly to the machine.if they are
then the machine and power cord and foot pedal need to be
checked
Nov 13, 2012 | Brother 1034D Serger Sewing Machine
Sewing machine stops sews a minute slows down or stops then starts up
I suggest having the machine checked at a sewing machine shop
to see if there is something wrong with the motor, or the foot pedal
but first check to make sure the power cord & foot pedal are
connected correctly
Aug 20, 2012 | Singer Sewing Machines
Pfaff 1540 sewing machine shaft is slow and doen't come down all the way
it's possible that something in the machine is broken or come loose or worn out. only a sewing machine repair shop can tell you what is wrong with the machine
Jan 24, 2012 | PfaFF Sewing Machines
Sewing slows after use
The manual: http://www.singerco.com/uploads/download/446_5040_5050.pdf
Jan 08, 2012 | Singer 5050 Mechanical Sewing Machine
Why does the sewing machine slow down on it's own.
Apr 10, 2010 | Singer 6038 Mechanical Sewing Machine
Machine slows down,stops, starts again. Foot control problem?
Yes it does sound like a faulty foot control. The power cord is probably fine, you just need the controller. Ebay is a good source for parts.
Feb 02, 2009 | Sewing Machines
Sews and then slows down. will not thread bobbin
make sure you are running you thread around the bobbin to get it started start slow when winding, is there something under your sewing foot(on the floor) when you are sewing if it's slowing down sounds like something may be holding it back, only other thing that may cause something would be internally if not the feed dogs. let me know hope this helps amy
Jun 25, 2008 | Brother LS-2125 Mechanical Sewing Machine
Whining also
ASAP....please it might just need service....how old is the machine?
Jan 20, 2008 | Singer CE-200 Quantum Futura Computerized...
Brother SE-270D Computerized Sewing Machine Logo
74 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
