Question about Toshiba TP50H50 50" Rear Projection Television
Scrambling for first 15 mins
Hey, About a month ago i started noticing that when i turned my tv and was watching tv through my cable box it was scrambling at the top of the screen, but after about 2 mins it would clear up and be just fine. Now its 10 times worse and the whole screen is scrambled and has lines all over, but now it takes about 20 mins to clear up and it doesnt even clear up all the way.
  • jbirner Nov 11, 2007
    so how do i fix the scrambling
  • carman131 Apr 10, 2008
    My Toshiba 60 inch starts off fuzzy for 15 min or so, then seems to "warm up" and clears up. It seems to be taking longer and longer as time goes on. Any solutions suggestions?
That is the exact problem I am currently having with my toshiba 50 in. I did some reading and it sounds like there is a temperature drift across one of the capacitors on the board and it takes longer and longer to warm up. Havent fixed it yet...
Posted on Aug 23, 2007
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
When I turn the TV and cable box on the TV will turn itself off and on for about 20 min before staying on. If I turn the TV on alone, leave it for 15 min, then turn the cable box on it's ok, Why?
The cable box is having trouble talking to the television using hdmi. This could be an upgrade issue or compatibility issue with HDMI versions.
Oct 04, 2015 | Televison & Video
DVR-R10 stops recording with 10-15 mins left
If it's your cable box DVR, you need to call your cable provider to reset your cable box.
Apr 16, 2014 | Directv R10 TV Receivers and DVRs
Car wil not start will not turn over at all. the radio and lights work fine, battery was replaced about 2 months ago
check the battery cables are not loose at both ends. when the battery was replaced you may have loosened the cable at the starter end or the ground end?
Dec 15, 2013 | 2006 Hyundai Sonata
Hi, I have a LN52A850 which i purchased over a year ago. The 1 year warranty has expired. Almost a month ago i spotted a pink thin horizontal line on the middle of the screen while watching it. It stays...
The display is controlled by the T-CON board. You may have faulty contacts on the connector for this board or a bad board. If the connector is cleaned it may improve. Sometimes disconnecting and reconnect the cable can solve the problem. The heating/cooling cycle from turning on the set can make the contacts loose.
IF you know how to work on electronics you can do it yourself or if you have a friend with working knowledge of electronics.
Feb 10, 2011 | Samsung LN52A850 52 in. LCD HDTV
Watched tv last night without any problems.
if you have the right video inputs and your cable box is working then your tv is shot .
sometimes your cablebox is outputing excess poxer that can affect your tv .also get your cable tv company involve.
Aug 24, 2009 | LG 42LC2D 42 in. LCD HDTV
TV shut off after 10 min.
it souds like the cooling fans arent working correctly. if the tv is staying on long enough to warm up and then shutting down i would look at the cooling fans
Jan 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Can't get orion 27 inch tv to turn off with cable remote
you can buy the original remote from these site they have it....good luck and rate me
Dec 30, 2007 | Orion STV2763 27" TV
Philips FTR 9964 Receiver Problem
The problem is in your cable connection on the back of your monitor or Box. I had the same problem and solved it by reattaching the VGA cable that was loose.
Nov 14, 2007 | Philips FTR-9964 Tuner/Receiver for Plasma
65 Inch Samsung Projection TV- Shaky Picture
have a tech look at your tv it needs to be repair checks can be made in the power circuit,or the IF CIRCUIT.good luck.
Apr 01, 2007 | Samsung HCN653W 65" Rear Projection...
Toshiba TP50H50 50" Rear Projection Television Logo
145 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
