Question about HP LaserJet 1020 Printer
Repair Kit for HP 4MV Printer - Pick Up Rollers
Thanks for your suggestion and information about buying a "repair kit" for my HP 4MV printer. Can you tell me approximately how often the paper "pick up rollers" have to be replaced? I read that this is one of the things included in the "repair kit". Although my printer is old, I really haven't used it too much over the years. I think I've only replaced the toner cartridge once or twice in all these years. So it's hard to believe that the "pick up rollers" could need replacing so soon. But perhaps they just don't last very long?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 24 Answers
The ruber tyres on the pick rollers can harden with age, even if you are not using it. Try applying gum turpentine to rubber tyre with Q tip. This is used to keep a printer picking up untill replacemant rollers can be fitted.
Posted on Dec 23, 2008
Hp laserjet 1536 dnf MFP. How can I repair document feeder?
how to fix and repair the adf doc feeder Q5997A hp laserjet ...
? 1:36
https://www.youtube.com/watch?v=lpTj4jiLaY8
Dec 12, 2011 - Uploaded by BrokenPrinter1
Parts Available @ BrokenPrinter.com how to fix and replace the rollers on a hp laserjet 4345 mfp and color ...
Fixing Paper Pick-Up Issues - HP LaserJet Pro M1212nf ...
? 5:40
https://www.youtube.com/watch?v=ZXtAhSDYqyU
Jan 23, 2013 - Uploaded by HP Printer Support
Learn what to do if your HP printer does not pick up or feed paper from the ADF when you do have paper loaded, and a Doc feedermispick error message display... ... FIX YOUR PRINTER: ERROR: Printer Does not Grab Paper fromTray ... Kit m3027 mfp- Kit Hp m3027 mfp - Kit Mantenimiento m3027 mfp ...
'Document feeder mispick' Message Displays on the Control ...
Dec 13, 2015 | HP Office Equipment & Supplies
4mv won't pick up paper
The feed rollers need to be replaced. The squeak is the worn rollers sliding over the edge of the paper.
Mar 25, 2014 | HP LaserJet 4mv Printer
P4015n maintenance kit replacement
This maintenance kit consists of a fuser, pick up rollers, transfer rollers. On this model you can also reset the maintenance count by entering the service mode and sometimes by scrolling down to the config menu until you see resets.
Mar 04, 2013 | HP LaserJet P4015N Printer
HP Laserjet M2727 Printer picks up too many pages at once
You have worn pick rollers. This is an easy fix and you can install the new rollers yourself. You need a preventative maintenance roller kit part number RK-P2015. You can get them here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_70&products_id=128
The kit has all of the rollers and separation pads to replace the worn ones in the printer to restore proper operation.
I hope this helps,
BuddyMc
Jul 20, 2012 | HP Laserjet M2727nf Multifunction Printer
The sprinter gives a message cleaning the paper path
Check* was paper physical length is matching to selected length? *check Maintenance kit interval. * check which tray you are getting this message? tray/tray 2 check pick up rollers are warn out? * clean paper path sensors.
Sep 30, 2011 | HP LaserJet 4250n Printer
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
Auto feed will not pick up paper, makes a loud clicking sound.
Sounds like you need a paper pick up repair kit
Go to hp.com
support, put in your machine and something like repair paper rollers
And it will kick back a kit number.
Then go to the WEB, to one of the reseller or even ebay and put in the kit number and watch what happens.
They are about 10 bucks for the smaller printers, color could be more
Feb 08, 2010 | HP LaserJet 8500 Color Printer
I need to purchas one maintenance kit for HP 5100 laserjet printer. what contents should be there in manitenance kit. I got no authorised information about this on hp site
To ensure optimum print quality, the printer will prompt you to perform printer maintenance every 150,000 pages. When the PERFORM PRINTER MAINTENANCE message appears on the control panel, you will need to purchase a printer maintenance kit and install the new parts. To check the number of pages the printer has printed, print a configuration page.
To print a configuration page:
1 Press [Menu] until INFORMATION MENU appears.
2 Press [Item] until PRINT CONFIGURATION appears.
3 Press [Select] to print the configuration page.
To order the printer maintenance kit, contact an HP authorized service or support provider. (See the telephone support flyer included with the printer.)
The kit includes:
fuser assembly
transfer roller
feed rollers
necessary instructions
For more information on installing the printer maintenance kit, see the instructions that accompany it.
Sep 07, 2009 | HP LaserJet 5100 Printer
I can only print by manually feeding in each page -HP 4MV Printer
Good old 4MV.
paper jam is just the way the printer i stelling you "something" wrong with paper feed".
you need to locate a "4MV repair kit" , they are not cheap. but, if you wan to keep the printer, it is worth it.
http://www.fixyourownprinter.com/kits/hp/K78 cost of the ket is $50
includes Instruction CD rollers, and other repairable parts.
Dec 15, 2008 | HP LaserJet 4mv Printer
MAINTENANCE KIT
There is no maintenance kit per sey. To do a maintenance on these, you only need the fuser, and the 2 rollers in the ADF.
Total cost for all the parts is about $90
I've done these kits a number of times, and they run like new after. I've never had to change the pickup rollers in the drawer yet.
Apr 28, 2008 | Dell 1600n All-In-One Laser Printer
HP LaserJet 1020 Printer Logo
181 people viewed this question
Clive
Clive
