Klipsch Synergy Sub-10 Subwoofer Speaker Logo
Anonymous Posted on Aug 01, 2012
My klipsch ten inch subwoofer is making a high pitch whinding sound when the sub is turned on
Its making a high pitch whinding sound when turned on
  • 2 more comments
  • Anonymous Aug 01, 2012
    Don't send anything anywhere! Just replace the cable to your amp and it will be fine. murf427
    Its connected to the computer part of the amp. Im not good with comptuer stuff.... Would Geek Squad be able to fix it or should i take it to a stereo repair place so I dont do any worse damage
    Only the cable connecting the two is bad. Just get a new cable & connect it the same way it is now. murf427
  • Anonymous Aug 21, 2012
    the wire is melted to the amp. how can i fix that ? or should i just cut the wire n leave about an inch of the existing wire and use a wire connector to attatch the new one ? ?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 18, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1384
Points
My fuse keeps poppin everytime i put a new one when i turn it on how can i fix dat?
  • Anonymous Aug 18, 2012
    my fuse keeps poppin everytime i put a new one when i turn it on how can i fix dat?
Anonymous
Level 3:
Master:
  • Master 336 Answers
  • Posted on Aug 01, 2012
Anonymous
Master
Level 3:
Master:
Answers
336
Questions
0
Helped
95012
Points
1052
You have a bad RCA cable to the sub out on your amp, causing a bad connection.
    How can I fix that without having to send it off ? I just looked & my Left/LFE conection wire is burnt a little ...
    can i replace part of the wire since it is saudered onto the amp ?
I have a klipsch r48, when the tv is off and even when the sub woofer is unpluged i periodically get a thump or bump thru the sub woofer.
https://community.klipsch.com/index.php?/profile/58706-swa99a/
A powered subwoofer can be connected directly to a TV's output jacks to boost the bass. An audio Y-adapter condenses the stereo signals into a single signal for the subwoofer to reproduce the bass frequencies. ... Subwoofers connect with a single 1/4-inch audio cable.
https://www.techwalla.com/articles/how-to-hook-a-powered-subwoofer-directly-to-a-tv
Asko repair melbourne
it's more likely the amp, which klipsch provides as a complete unit.
The Fuse blows as soon as I turn the Sub on
Maybe power amplifier end module broken this could be an powerpack ic or transistor output stage cause of shortcircuit or even bad capacitors.
No sound when playing music using klipsch sub
check your receiver settings and make sure subwoofer is enabled during 2 channel playback.
1helpful
My klipsch sw112 sub stop working and know when i turn it on it just makes a clicking sound the led light flashes on and off
The sub amplifier circuit is probably damaged and the protection circuit takes over. Have a qualified electronics technician take a look at it.
2helpful
I have the klipsch sub-10 subwoofer, making noise after use
it sounds like the sub is rubbing in the voice coil.
put the speaker in upside down to what it was before.
sometimes that extra bit of downward pull is enough to offset the error.
There are speaker reconing experts out there but it is cheaper to replace the sub itself.
the sub can be replaced for sure.
2helpful
High Pitch Noise Coming Out Of My Subs?
sounds like it could be a warning sound that indicates either a short or a bad connection and is tripping the safety warning. check all speaker terminal connections and connections on the amp to make sure there is nothing loose or touching
2answers
Klipsch ksw subwoofer wont power on
The power supply switching transistors are likely fried. Dangerous high voltages involved. I would remove the plate and send it to Klipsch for repair.
Klipsch subwoofer
its all about impedance matching...did you check to see that the new yamahas would drive from the system, before installing them? sounds like you will need to possibly add a matching transformer or other device on this one.
Top Klipsch Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Klipsch Audio Player and Recorder Expert? Answer questions, earn points and help others
