Scooter goes forward and batteries take full charge. Won't reverse
SOURCE: Pride Victory 3 electric motor will not engage the wheels.
no its definatly the kerosine mix in the fuel tank
SOURCE: Pride Celibrity 3 wheel electric scooter. The motor isn't working
the click is the electric brakes releasing , most likly the problem you are having is the brushes in the motor may be shot cheap easy fix on each side of the motor there should be what looks like a flat head screw those are the brush covers remove them and check them replace as need , otherwise the motor may be shot
SOURCE: when you turn on key
Hello and Welcome to FixYa!
Well, that could be due to multiple reasons, you need to double check each possibility one by one to rectify the problem.
Make sure that the charger is working properly and the batteries are properly charged and aren't showing fake charging. The battery(ies) are capable of storing charge efficiently.
Also do make sure, that the gears mechanism that converts electrical to rotational mechanical energy are working properly, and there is no obstacle in there movement nor the braking mechanism is blocking the movement.
Hope, now you get a wider picture on how to tackle with the scenario. Kindly do perform the general test and do let me know, what you found. Hoping to hear from you soon.
Have a nice day,
Concerned.
SOURCE: My Pride Jazzy Jet 2
Are you comfortable working on the electronic cable / connector?
Check the temperature charger's by hand. It should be warm to the touch when power on.
Since you has the unit plug in for days,it should be warm to the touch.
You will need to has a volt meter to check the voltage output on PIN 1 and 2.
Remove the power cord from the outlet.
Inspect the 3 small pins on the XLR (ROUND connector) to the scooter.
Make sure the 3 pins are not damage.
Open the metal 3 pins connector by sliding it back on the cord.
Check for loose connection on the solder tabs.
There should be total of 3 solid solder connections these tabs.
Close up the connector.
Check the connect on the scooter end.
The 3 pins must be clean and able to make the connection.
Please post more information and result on reply.
