Question about Mitsubishi VS-45603 45" Rear Projection Television
Only Picture in Picture Works...????
This tv is about 8 or 9 years old, it's a Mitsubishi, RP. It has worked fine since we've had it, we got it from some friends, but all of a sudden one day the whole picture stopped working and now only picture in picture works. The sound is fine, and the menu will come onto the whole screen. What gives? Model #vs-45603 Serial # 105809
Its possible some of the surface mount capactors has failed on the pip board is so the unit will need to be replace or repaired.
Posted on Oct 28, 2007
I have a mitsubishi tv model wd 60638 I changed the lamp. Tv works fine for about 20 minutes then I start to smell like something is burning then picture starts to flicker, what could could cause this
You have a bad connector in the lamp. Stop running the TV immediately and contact the company you purchased the lamp from. this is common in older DLP tvs but not in one 5 years old unless you have a lot of hours on it. the connector can crack and arc inside the plug and then melt and smell terrible. It usually very repairable if you can get a ballast for it. the plug is part of the ballast.
Aug 28, 2015 | Mitsubishi WD-60638 DLP TV
TV loses picture
Sounds like your picture tube or bulb is going out. It depends on what kind of tv ( rp, lcd, plasma) it could also be a component issue.
Nov 22, 2013 | Televison & Video
WD-52725 Picture Quality Problem
sounds like a possible issue with the Optical light engine itself.
Nov 28, 2012 | Mitsubishi WD-52725 52". Rear Projection...
This TV is about 8 years old. Everything works,
Replace the CRT coolant if its a phillips. Or if a sony it may need to have the CRT drive adjusted for the Blue
Jun 19, 2010 | Televison & Video
TV works fine for a while, then the picture disappears.
I would just replace the TV, the parts are not going to be made to repair this. The set is just to old.
May 12, 2017 | Mitsubishi VS-5077/78 TV
Sometimes sound but no picture
HHMMMMMMM. 12 error code is no fault code. This is very old set with a reputation of dumping it's memory setting for no particular reason. The board need is no longer available and if it was requires extensive setup. Very costly to repair. Replace the set. Very old. Tubes probably weakening.
Apr 25, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi ws- 55807 clicking sound
My tv was working fine until now 8-9-08, it would not come on. The timer light comes on and goes off immediately.
Jul 20, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Jul 09, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Televison & Video Logo
157 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
