Question about Lexmark Office Equipment & Supplies
I HAVE SOFTWARE INSTALLED FOR MY LEXMARK X4210 BUT CAN FIND NO SETUP SHEET TO ENABLE ME TO COPY PAPER DOCUMENTS AND PRINT THEM. COULD YOU EMAIL ME ONE PLEASE?
    Sergeant:
  • 320 Answers
Thanks for choosing fixya.com
There is usually a button on the top of the scanner/printer that will say "Copy" This will scan the document then print it out. You can also open the software that came with the printer that you have installed and it should have a "scan" option. This will allow you to first scan the document, modify it or save to your computer, then re-print it.
You may also be able to download a pdf version of the manual from www.lesmark.com
Hope this helps out.
Jei
Posted on Dec 15, 2008
How do I reduce a page being copied?
scan a copy to pc documents , save to word , use photo shop and reduce in size
print page and then re-scan
Sep 17, 2017 | Office Equipment & Supplies
When I print colored squars show up in the background
Update your printer firmware http://bit.ly/JqfYcG
After successfully updating your printer, run the Deep Clean Printhead function on your printer.Press the Setup button > Maintenance > Deep Clean Printhead.
If you're still having problem, please scan and email us a test page (Setup button > Maintenance > Print Test Page) to LxkListens@Lexmark.com.
Jun 04, 2012 | Lexmark Intuition S505 Wireless All-in-One...
I have a lexmark x6570 printer it will not print on both sides of the paper anymore it use to print on one side then pull the paper back in as use the other side
Please follow steps below on how to print 2-sided on your printer:
Printing on both sides of the paper (duplexing) automatically:
  1. Press printmastert_76.jpg.
  2. With a document open, click File > Print.
  3. Click Properties, Preferences, Options, or Setup.
  4. Click the Print Layout tab
  5. From the Duplexing area, select Use Printer Settings from the drop-down box.
  6. Make sure the printmastert_77.jpg light is on.
  7. Click OK to close any printer software dialogs that are open.
Printing on both sides of the paper (duplexing) manually:
  1. With a document open, click File > Print.
  2. Click Properties, Preferences, Options or Setup.
  3. Click the Print Layout tab.
  4. From the Duplexing area, select Manual from the drop-down box.
  5. Select the Print manual duplex instructions check box.
  6. Press Start.
  7. The printer prints the odd-numbered pages and the instruction sheet, which describes how to flip and reload the paper.
  8. Following the instruction sheet, flip and reload the paper with the printed side facing away from you.
  9. The printer then prints the even-numbered pages on the reverse sides of the odd-numbered pages, completing the two-sided sheets.
Note:
  • printmastert_78.jpg button is not functional with a Macintosh operating system. You can print two-sided documents with a Macintosh operating system by using the settings in the Two-Sided menu of the Print dialog.
  • Automatic two-sided printing (duplexing) works only with plain paper in letter and A4 sizes. If you want to print two-sided documents on another size or type of paper, use the manual duplexing method.
  • To return to single-sided printing, make sure the printmastert_79.jpg light is not on.
Aug 31, 2011 | Lexmark X6570 InkJet Printer
My printer will not print any documents, it does print a test page, when I select print the paper is ejected. I have re installed the software.
Try to print a self test page from the printer directly using the below steps....
  1. Make sure the printer is loaded with plain, white paper. Remove any special or colored paper.
  2. Press Setup on the front panel of the product.
  3. Press 1 , to select Print Report , then 5 , to select Self Test .After you have the report printed, check for 4 horizontal color bars in that report, the first color should be the the black one, if the black one is missing, issue seems to be with black cartridge, that may be the reason the printer spits out blank paper, try to replace the black cartridge and then copy if it copies or not.
Sep 26, 2009 | HP PSC 2210 All-In-One InkJet Printer
Failing to print using LemarkZ2300.
go in touch with lexmark help line or send email and tell them ur problem...i am sure they will help u
Apr 19, 2009 | Lexmark X2600 InkJet Printer
Won't print
The printe will not scan or print. When I fax documents it is recieved witha balck shadow in teh background. I get error 2200 when I try to print or scan.
Apr 03, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I WANT TO ACTIVATE MY SCAN AND THEN PRINT ON MY LEXMARK X4210 AND I FIND NO SETUP SHEET. COULD YOU EMAIL ME ONE?
as u see u r not giving me the model but i will give u this link, choose ur model and download manual and quick guides.
click here.
please do rate this post as good as u can so i can help others.
good luck.
Dec 15, 2008 | Office Equipment & Supplies
HP 6200 without telling it to print, feeds and jams continually
I already encounter that problem lately. when you print your documents, the only response of the printer is paper jam. feed and jam.
try this tip if acceptable of your situation now.
only to do is copy your documents by edit button and then select all or highlight all that your going to print and then right to copy
and then, open a new documents page set up if needed.
and then print it without saving your file because that already save.
Dec 05, 2008 | HP Officejet 6200 All-In-One InkJet...
Printer printing very small
You are using Internet Explorer 7 and it automatically tries to fit the whole page in a sheet of paper.
Go to Page Setup and DISABLE Shrink To Fit
You might want to ENABLE the Background to print the lovely images
Nov 25, 2008 | Office Equipment & Supplies
53 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
