Question about Apple MacBook Pro Notebook
MacBook Pro 17"
The bottom of the computer case gets extremely hot after running a short period of time
  • JDTec
    JDTec May 11, 2010
    The unit has 2 fans on the bottom, check to see it there are working.
    Problem Solver:
  • 5 Answers
I'd check the activity monitor...(in utilities short cut shift apple A). See if anything is causing a problem.
Select all processes at the top
If you sort by the CPU column and something is running at a really high percentage then that's where your problem lies. First of all I'd Quit that process and then look for incompatibility issues with your current OS version (under about this mac)
My printer driver caused all sort of problems and caused over heating mac and very short battery life.
Posted on Feb 28, 2009
  • 4 Answers
Hi, The Macbook Pro does get hot when running intensive apps.
I have been using the following great product to cool it down some:
http://www.bluelounge.com/coolfeet.php
It's easy to transport and does offer some relief
Best regards,
Thomas
Posted on Feb 24, 2009
    Sergeant:
  • Apple Expert
  • 250 Answers
THis is normal. It is based on the amount of CPU being used. If you are running a lot of apps or CPU intensive apps then it will run hot. If you use Cmd-space and type 'activity' you will select Activity Monitor from the list. In there you can see what is using the most CPU. (get back to me if you need more info on using this app). Playing videos uses quite a lot of cpu for decompression. Playing music doesnt. Check also howmany widgets you have open by pressing F12. Close them down by holding the alt key and clicking the x in the top left corner of each.
This should help you reduce the heat a bit. Also think of getting somthing like the iLap. I use this myself (using it right now infact) and it's pretty good.
All the best
Sean
PiDigital
Posted on Dec 18, 2008
How to change battery on macbook pro
For most recent macbook pro's all you will need a small phillips head screwdriver to take the bottom of the casing off and unscrew the battery. Below is a link to a simple, quick instructional video: How To Replace the Battery in Macbook Pro 13 Unibody
Sep 08, 2014 | Apple MacBook Pro Laptop Computer with...
MacBook Pro 17 inch thermal paste
you can use any standard thermal paste on the macbook pro, however the processor is soldered to the board.
Jan 27, 2014 | Apple 17" MacBook Pro Laptop Computer...
Factory reset without cd
you will need to purchase a cd from apple and reformat the mac.
Jan 09, 2014 | Apple Macbook Pro 17 - White Carbon Fiber...
Macbook 7.1 overheats
Take it to a trusted computer dealer and have them replace the thermal paste between your heatsink and your processor. Also, make sure to blow out your fins that blow the hot air out and pull the cool air in. This should resolve the overheating issue.
Apr 25, 2017 | Harman Kardon Computers & Internet
I have 2007 suzuki intruder the front spark plug was replaced 3 times due to intermitant spark.Each time i check the spark plug no spark then replace the plug then spark then runs for short period the No 1...
Fouling of the spark plug makes the exhaust extremely hot due to the burning of the fuel mixture inside the exhaust pipe and the spark plug end turn to black, fouling of the spark plug may be due to too rich fuel mixture check the correct setting of the air valve.
Jul 10, 2011 | 2001 Suzuki VL 250 Intruder LC
I have a Macbook Pro, 17". I've gone to the
Sadly, there is nothing you can do short of installing a third-party popup blocker. The Safari blocker does work, however advertisers are always finding ways around current blocker programs and it's hard for any one blocker to keep up with every new trick.
Apr 14, 2011 | Apple Mac OS X
Dell Inspiron 1525 Hard drive
There is a trick to getting an overheated and damaged hard drive to run for a short period of time, maybe enough to get your data off of it. Place the damaged hard drive in a tupperware bowl with a lid. Get a can of refrigerant from an auto parts store, wear gloves....open the refrigerant with the attached hose and direct the refrigerant into the bowl keeping as much in there as possible. This will freeze the bearings and in a lot of cases allow the device to work for short period of time. This of course will not work if the problem is a damaged read/write head or controller card.
Sep 01, 2009 | Dell Inspiron 1525 Notebook
My MacBook Pro MB766LL/A
First of all, do a "Software Update". There may be a firmware update for the laptop since it was manufactured.
Also the macbook pro does run hot, especially if you are doing anything cpu extensive. You could launch Activity Monitor and see if some process is hogging the cpu.
I have an antec cooling pad under my macbook pro. This helps a lot.
Mar 26, 2009 | Apple MacBook Pro Laptop Computer with...
Apple MacBook Pro Notebook Logo
118 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
