I cant find it
SOURCE: replace the alternator on a 97 isuzu rodeo
from Yahoo answers
The alternator is located on the passenger side of the motor at the bottom. There is a bracket attached to the motor and the alternator. You need not take the bracket off to remove the alternator. Two bolts hold the alternator to the bracket. One bolt is on the front top of the alternator and one bolt is located on the bottom front of the alternator. The bottom front bolt is attached to the tension adjustment for the alternator. Loosen the tension screw then remove the bolt going through the tension adjustment. After you loosen the top, front bolt, the alternator should be loose enough to move side to side. Remove the top, front bolt. Now you must disconnect the alternator from the power supply. Behind the alternator is a screw with a wire attached via nut. Remove this wire. Nextly there is a series of wires with a plug on the end. It is plugged into the side of the alternator. Uplug this item. You can also access both of these from the passenger side front tire well. Something to consider is that remanufactured alternators in Rodeo's as well as the Honda Passport (which has the same engine as the Rodeo) do not work and the problem(s) associated with a bad alternator,ie; not charging, no fan blower, battery light and brake light on, still exsist after replacing alternator with reman. Use a factory original alternator if possible. It will cost a little more than a reman but will most likely save you a lot of time and headache!
Hope this helps you out!!
L
SOURCE: the location of the ecm fuse on 98 isuzu rodeo
ECM fuese are located in the fusebox in the engine compartment-left sidefacing the vehicle.
SOURCE: where is the Vacuum Solenoid Valve located on 97' isuzu rodeo 4x4
yes,drivers side front axle tube.
