Question about Vizio L37 Television
Vizio L32 hdtv10a..
My tv won't turn on. The orange light is on - will not turn green and go on. Have tried disconnecting from power, using remote, manually hitting on button.
I ordered and replaced the main board part 3632 0012 0395.... and nothing.. Screen is still black. Do I need to reset anything?
Could it be the inverter? If so which one main or slave
Unplug the power source from wall wait a couple of seconds and hold the power down on tv and plug tv back to power outlet. it should turn on. sometimes it takes a few trys.
PardyTyme
I’m happy to assist further over the phone at https://www.6ya.com/expert/pardeep_b57c4da2b93daf62
Posted on Mar 10, 2013
  • 2,336 Answers
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
Posted on Dec 15, 2008
  • Jaime Hernandez Dec 15, 2008
    If the light on the front of the TV supposed to turn blue when the TV is operating normally, the amber light indicates that there is a problem inside the TV circuitry.
    In any case if the back light inverter is the problem, the TV will still show the blue light but no video. The video will be in the screen background very dark and to be able to see it, you might have to shine the light from a flash light near the screen and look at the screen from a 45 degrees angle. If you have a dark video, then is your main back light inverter board is defective.
My VIZIO vx32L/hdtv10a remote only lets me change channels. No volume up/down or power on/off function either
If your audio is being routed through a home theater system then you will not get vol control through the remote for the TV. You will have to use the home theater remote.
Feb 22, 2015 | Vizio L32 32 in. LCD HDTV
Vizio L32 Not terning on orange led lights on
3320-0032-0150. Question - is this board in other 32" LCDs? I see the entire LCD all over EBay w/cracked displays for CHEAP biggrin.gif (since the LCDs are so pricey the unit is parts only). Thanks again! cheak out them on ebay try new board
Feb 08, 2008 | Vizio L32 32 in. LCD HDTV
No picture no sound on a Vizio HDTV10A. The green light comes on then turns to amber after a couple of seconds
your Main board went bad, common issue with these units. Need to be replaced, in tv land it called main board in computer world mother board. your unit has only two boards power board and that is good cause you get a amber to green to amber led. good luck Vizio field tech
Feb 01, 2013 | Vizio 32" l32 hdtv 10a high definition...
Vizio TV 2006 vx32Lhdtv doesnt work.
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make sure the backlight still works. I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine. I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272 2174 or it was 3632 0212 0150. Check your circuit and see if any of those numbers match up.
Jan 19, 2010 | Vizio L32 32 in. LCD HDTV
My tv won't turn on. The orange light is on - will not turn green and go on. Have tried disconnecting from power, using remote, manually hitting on button. Vizio L32 hdtv10a
Look at the power supply, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
I have the same model for my bed room, my power supply blew up beyond repair, had to buy a used one, now the LCD controller board is going bad when it gets hot. Not a very good TV.
Dec 01, 2009 | Vizio L37 Television
Only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Dec 30, 2008 | Vizio L32 32 in. LCD HDTV
Only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Dec 29, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 HDTV - Blew Out, No Power
Yes, I do in home warranty work on vizeo, it sounds like you need a power board and perhaps a main board. The power board is what pooped.
I’m happy to assist further over the phone at https://www.6ya.com/expert/lou_afa492c634393790
Nov 13, 2008 | Vizio L32 32 in. LCD HDTV
No power -- TV will not turn on
This could be the power supply baord / Bad Caps/ They will be puffed up..
Or if the inverter board is bad** Inverter board lights the backlights.
Oct 30, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L37 Television Logo
858 people viewed this question
Top Vizio Televison & Video Experts
Steve Allison
Steve Allison
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
