Question about Kenmore Elite 45986 Front Load Washer
Washer only works on spin cycle
My kenmore elite washer only works on the spin cycle. The light on the display do not work for the type of wash cycle you wandt to select. Nothing happens when tehy are pushed it only seems to work on the spin cycle. I can not change the water tempeture setting either it is always on cold/cold. I have tried unpluging the machine and replugging it to try to reset it.
  • 67 Answers
Sounds like u need a new control panel
Posted on Mar 20, 2007
Kenmore elite washer
hi
unfortunately the programmer is faulty
Dec 31, 2017 | Kenmore Washing Machines
UL in digital display coming on during wash cycle. When washer is spinning during wash cycle it is very loud and the washer moves. We have had it repaired a couple of times. It will work for several...
Hi
Thanks for using FixYa. ULis displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 27, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Control Locked light on
Hi
Thanks for using FixYa. To unlock the controls you’ll need to press and hold the DRAIN/SPIN button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 11, 2010 | Kenmore Elite 45986 Front Load Washer
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
Machine will not switch to drain and spin cycle
If you take the front off in the lower right you will find a pump motor that controls the drain flow. This may defective. Use a shop vac to empty the water in washer if needs be. But remove and test this pump.
Apr 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite spin cycle squeals
The clutch/transmission has failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 14, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite H3 control buttons - some work some don't
The diagnostic function will not help you if your user interface board (UIB) is acting up because to put into diagnostic you have to select drain spin, then the no spin option, and hit the prewash button 4 times.
It sounds like your UIB is the problem.
Jan 01, 2009 | Kenmore 42822 Front Load Washer
I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
Kernmore elite He3t
Well there is one of two control boards that is malfunctioning, most common is the Machine (or Main) control board, there is also a display pc board in the control panel, but i have had few problems with that control. Unfortunately the main board is $300.
Sep 04, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
313 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
