Question about Borland Turbo C++ Suite 1.0 (TCB0000WWFS180) for PC
How to open jpg file using turbo c - Borland Turbo C++ Suite 1.0 (TCB0000WWFS180) for PC
  • Anonymous Dec 17, 2008
    i also tried a lot opening any image file (say .jpg,etc) but could not find any relevant header file for dat... plz suggest ..
    thanx
    Guru:
  • 1,894 Answers
I dont think you can.. try SQL
Posted on Dec 16, 2008
Select a directory specification
then introduce the linker with the .jpeg(joint photographics experts group)
and now save the .jpeg file in the BIN
Posted on Dec 28, 2008
How do I open files attached to E Mails PDF or JPG
On most browsers, double-click on the file name will allow you to download and save the file which can then be open with appropriate 'default' application program (e.g. you need to have a PDF viewer such as Adobe PDF reader and Graphic JPG viewer such as MS Paint installed).
Sep 23, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Tip
How to hide files in a jpg photo
1) Take two files -
one which you want to hide and another will be the jpg image(of any size and dimension)to hide that file
If you want to hide multiple files in one jpeg image, just zip them into one file
2) To make the process easy, Copy the above two files to the C:
3) Now open the command prompt (Go to start, Click "RUN" and type "cmd").
4) get to the root by typing cd\ or you can give the path name where the files are located
5) Now type the following command:
copy /b imagename.jpg + filetohide.ext new_image.jpg
6) Now a new file new_image.jpg will be created
7) Double click on the file and it will open the image which you used to hide the secret file
8) To access the hidden file simply change the extension from jpg to orignal extension of the hidden file,
Example: I took an image filename "myphoto.jpg"
I wanted to hide some important word documents so I zipped all the word files and created a zip file "word.zip"
Then copied both "myphoto.jpg" and "word.zip" to c:
Opened the command prompt
Typed the command: copy /b myphoto.jpg + word.zip new_image.jpg
Now I have a new file "new_image.jpg" in C:
When I double click on the new file it shows me the image of "myphoto.jpg"
If I change the extension of new_image.jpg to new_image.zip I can extract the contents of the .zip file
ENJOY !
ENJOY !
on Dec 03, 2009 | Computers & Internet
Internet photos download as bitmaps instead of jpg's
First open Microsoft Paint by going to Start, All Programs, Accessories and then Paint
Now open the BMP file in Paint. Now all you have to do to save the file in JPG format is to simple do a Save As. Change the File Type drop down menu to JPG and click Save
Jun 11, 2010 | Compaq Presario 5000 PC Desktop
I don't want photoshop to launch when I open a pdf or a jpg
Well, here's the simple steps, Right-click on any jpg/jpeg file, select "properties" click "change" and select "Windows Picture and Fax Viewer" "Ok" "Apply" "Ok". Sometimes you'll need to browse the application, but in your case, i hope "windows picture and fax viewer" is right there. Same thing with the pdf, but you'll only need to open a pdf reader like "Adobe Reader" or "Fixit Reader". Good luck. Thank you for using FixYa.
Jun 08, 2010 | Adobe Photoshop CS2 for PC
When i click on my JPEG pics they wont open
such jpg files need the original software when they were modified into a jpg format. like an adobe jpg or a corel draw jpg wont open in paint until the respective software is installed.
secondly jpg file has a header file and check sum , if the header file is missing or destroyed by a virus or already there is a virus on ones system the jpg files have to be isolated and treated for antivirus which reapirs the file and seperates the virus from the header maintaining the integrity of the file.try to isolate one jpg file and run a scan for virus on another computer, if the file gets repaired use the antivirus to repair your files
Sep 19, 2009 | Computers & Internet
To open a jpg file
Jpg is a picture file and can be open with almost any photo program,Just right click,open with,and choose your photo program or windows picture and fax viewer,or even windows paint.
May 03, 2009 | HP Computers & Internet
How to convert jpg into ms word 2003
Hi there.
Open a new word document, go to the jpg you want to add to word, right click on the jpg and copy, go back to the newly created word document and right click and paste, the jpg will insert itself in the word document.
Good luck and thanks for using FixYa!!
Mar 16, 2009 | Microsoft Computers & Internet
Trying to open Jpeg file and says sorry cannot open. Help please to solve this.
Right click on your jpg file, select OPEN WITH,
and select the desired program to open your pictures with
now, there must be a check box at bottom saying:
always use this program to open this kind of file
check it, and click ok.
not it should open your jpg file.
Feb 23, 2009 | Microsoft Picture It! Digital Image Pro...
Problem in opening picture files
Its possible that you installed a graphic program that upon install it changed the extension of your picture files. An example would be photoshop, This program could change your JPG files to PSD format upon install.
You can download a software program that can convert your pictures from the PSD ext. to JPEG. Once such program is (Easy Graphic Converter), It is Free... Another excellent program is Graphic Workshop. I think that one is trial but it has a time limit.
If you don't want to go that route you can go into your file ext. settings and change it to where a jpg file will be opened with another program other than PhotoShop. This might solve your problem.
To get to this screen, you can go into ( My Documents ) click on ( tools) at the top on the menu bar. Then click on ( Folder Options ). From there click in ( File Types ). Then find your JPG ext.
and it will tell you what program opens your jpg files. If it says CS3, change it to something else like WIndows Picture and Fax Viewer or something else.
Joe < Data Miner >
Oct 29, 2008 | Computers & Internet
Open Questions:
how to write c/ c++ sourcecode for Merkle-Hellman Knapsack Public Key Cryptosystem ??? In this problem you will implement the Merkle-Hellman Knapsack cryptosystem. The encryption and decryption algorithms are based on solving a knapsack problem. The knapsack problem consists of finding a way to select some of the items to be packed such that their sum (the amount of space they take up) exactly equals the knapsack capacity (the target). Formally the knapsack problem is as follows: Given a set S = {a1, a2, ..., an} and a target sum T, where each ai >= 0, is there a selection vector V={v1,v2,...,vn} each of whose elements is 0 or 1, such that (ai*vi) = T. The idea behind Merkle-Hellman scheme is to encode a binary message as a solution to a knapsack problem reducing the cipher text to the target sum obtained by adding terms corresponding to 1s in the plaintext. That is, blocks of plain text are converted to knapsack sums by adding into the sum the terms that match with 1bits in the plaintext as shown below: Plaintext: 1 0 1 0 0 1 Knapsack: 1 2 5 9 20 43 Cipher text: 49 Plaintext: 0 1 1 0 1 0 Knapsack: 1 2 5 9 20 43 Cipher text: 27 The receiver will have to use the cipher text (the target sum) to recover the plaintext. A knapsack problem is said to be ``easy'' if {missing}. The solution for the easy knapsack problem is straightforward, and can be achieved in O(n).Furthermore, there exists a way for transforming an easy knapsack set S into a non-easy knapsack H simply by multiplying the elements of S by w mod n where w and n are well chosen integers. Formally the terms of H are: hi = (w*si) mod n. For example if S = {1, 2, 4, 9}, w = 15, and n = 17 then H = {15, 13, 9, 6}. Encryption algorithm (executed by the sender) H is called the public key and is made public by the receiver Choose w and 1. n such that n > max(S) and n is prime, and w < n. Construct H from S, w, and n. Sender uses H to encipher blocks of m bits P0 = [p1, p2...pm], P1 = [pm+1, pm+2...p2m] and so forth (m is the number of terms in H), as follows: Ti = Pi*H = (pj*hj). Thus T0 = P0*H, T1 = P1*H and so on. Ti are then transmitted to the receiver via a reliable channel. 1. Decryption algorithm (executed by the receiver) The tuple (S, n, w) is called the private key and is kept secret by the receiver Use w and n to compute w-1 where w-1*w = 1 mod n. if n is prime then w-1 = w (n-2) mod n 2. Compute Ai = w-1*Ti mod n 3. Find Pi by solving Ai = Pi*S Input file The input consists of N test cases. The number of them (N) is given on the first line of the input file. Each test case begins with a line containing a plaintext to be encrypted. The second line contains the number of elements (m) in the knapsack S that show in the third line. The knapsack elements are positive integers separated by space. The fourth line of each text case contains n and w in this order separated by space. Output file Print exactly 3 lines for each test case. The first line should contain the encrypted values of the plaintext of the set separated by space. The second line should contain the plaintext obtained by applying the decryption algorithm to the plaintext, preceded by `Recovered plain text: '. The third line should contain the value of w-1 Sample Input 2 Salaam! 4 1 2 4 9 17 15 hello there? 4 1 2 4 9 19 7 Sample Output 29 25 22 16 22 28 22 16 22 16 22 44 9 16 0 24 Recovered plain text: Salaam! 8 23 7 23 20 23 21 23 21 23 36 9 0 29 14 23 7 23 20 29 9 23 20 15 36 0 16 Recovered plain text: hello there? 11
Feb 24, 2009 | Borland Turbo C++ Suite 1.0...
Borland Turbo C++ Suite 1.0 (TCB0000WWFS180) for PC Logo
390 people viewed this question
Top Borland Computers & Internet Experts
Tony
Yoav Shilon
Yoav Shilon
Are you a Borland Computer and Internet Expert? Answer questions, earn points and help others
