Question about IBM ThinkPad T40 2373 Notebook
Wont auto play any disc
Cannot load a disc put 1 in green light flashes then stops
    Sergeant:
  • 320 Answers
First off thanks for choosing fixya.com
It could be that "autoplay" has been disabled. Here are some steps to enable autoplay.
  1. Double click on the My Computer icon on your Desktop until it opens.
  2. Then gently click on your CD / DVD Rom Drive just until it becomes highlighted.
  3. Then click on the word File, which is contained in your top tool bar area.
  4. This will pull down a menu for you to now click on Properties.
  5. Then click on the Auto Play tab at the top of the screen.
  6. You can adjust settings for Music CDs, Music Files, Pictures, Video Files and Mixed Content.
  7. Now select a multimedia types by using the pull down arrow to the right with your mouse.
  8. Then for each multimedia type, use your mouse to encircle the Select an action to perform: option.
  9. To disable that multimedia type, click on the Take no action icon at the bottom of the screen.
  10. Now click on the Apply button at the bottom of the screen to save your changes.
  11. Continue in the above fashion for each multimedia type, choosing the Take no action option.
  12. And ensure that you click on the Apply button at the bottom of the screen to save your changes.
  13. Once all options have been set, then click on OK button to exit the CD Drive Properties window.
  14. Repeat the above procedure on any additional CD Rom Drives you have in your system.
  15. Note: If you feel you have made a mistake, you can click on the Restore Defaults icon at any time.
You can also double click "My Computer" then click the drive letter the cd/dvd is in. If nothing still happens it may be a failing or broken cd/dvd drive. Ensure that the cd's are clean and free of any major scratches.
Hope this helps you out
Jei.
Posted on Dec 15, 2008
We can't get the factory 6 disc cd player to load more than 1 disc. What is the sequence for loading additional discs?
The following is the owner's manual for your 2004 Dodge Neon:
http://www.dodge.com/en/owners/manuals/index.html?year=2004&nameplate=Neon
P.99 describes how to load discs:
1. Select and press any numbered button without an illuminated light above it.
2. Insert the CD while the light above the chosen button is flashing and the two lights on either side of the slot are illuminated.
3. Upon insertion, the CD will begin to play, and both the button light and the lights in the corner of the loading slot will illuminate.
4. Repeat the process for loading any additional CDs. The CD playe rwill stop while additional CDs are loaded.
Playing Discs
The radio will show the CD number, the CD track number, and the Track Time Elapsed while the radio is in the CD mode. IF more than one CD is loaded in the changer, the changer will automatically play the next disc after playing the last track of the current disc.
Wow, that's a lot of typing.
I didn't know the 2004 Dodge Neon had such a nice changer.
Good luck.
Jul 04, 2010 | 2004 Dodge Neon
My ps3 won't load the discs...
Hi, if it wont load your icons and freezes before your xmb, put it into safemode and try restoring the filing system. to get it into safemode...
hold down the power button while the console is in standby. the light will go from red to green.it will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
Thanks and take
Apr 19, 2010 | Sony Playstation 3 (PS3) Console
Just recently my ps3 wont play any games or dvd. It loads up everything as normal but whem you put in disc it jusy goes to a blank screen until you remove the disc. yellow ang green light will flash while...
it sounds like your laser is gone you can replace it if you have any knolage of opening a ps3 there are loads of videos of how to do this on youtube i my self had the same problem its not that hard to fix
Jan 06, 2010 | Sony Playstation 3 (PS3) Console
Arcade umplugged volume 1 wont play
i think iv had this one you put disc in then when its loaded goto arcade menu and i think the games are there rather then reading from disc
May 09, 2009 | Microsoft Arcade Unplugged Volume 1 for...
Ps3 wont play discs
to me it sounds like your lens are messed up, try getting a dvd cleaner and use it on your ps3 man
Apr 10, 2009 | Sony Playstation 3 (PS3) Console
It just wont work
If you have 3 red lights on the ring you have what they call RROD or red ring of death. Bottom right would be hardware failure.
DVD Drive failure most common problem, this ranges from dirty disk error (DDE) message to inoperable drive door, skipping in movies, slow load time or no load or the call customer service errors 10, 11, and 12. To replace the drive it will have to be reflashed.
Feb 18, 2009 | Microsoft Xbox 360 Console
My ps3 won't load any games
Mar 11, 2008 | Sony Playstation 3 (PS3) Console
Ps2
you say it wont turn back on but it has power.
is the light red ( stand by )
or do you have green and blue lights
Did it fall????
try cleaning the disk and the lens
you can also run the auto diagnosis..
HERE'S HOW
Auto-Diagnosis (PlayStation 2 system) 1. Turn on the system without a disc inside. 2. Once at the Main Menu, press the triangle button to enter the Version Information Screen. 3. Highlight the "Console" option, and then press the triangle button again. 4. Next, press the X button, highlight "On", and then press the X button once more. 5. Now press the circle button twice to return to the Main Menu. 6. Press the eject button on the front of the console, and insert a disc. 7. Now close the disc tray, but DO NOT reset the system. 8. Highlight the Browser option from the Main Menu, and then press the X button. 9. In the Browser, an icon of the disc should appear on the screen. Highlight this icon, and then press the X button to read the disc. 10. If the auto-diagnosis is successful, the disc should load properly at this point. NOTE: The auto-diagnosis feature will return to "Off" the next time a disc is inserted.
the above is a copyright of the PS2 user guide
Dec 29, 2007 | Sony PlayStation 2 (PS2) Console
Cant play anything on it
I had the same problem, After googling for a few minutes I found the reset procedure for this player.
1. Turn it on.
2. Eject any disk you have in there and close the tray.
3. Hold down the "STOP" button on the player (not remote) until the green light flashes red and the system reboots.
4. Insert disk and enjoy.
This worked for me... mileage may vary.
Aug 29, 2007 | Cyberhome CH-DVD 300 DVD Player
IBM ThinkPad T40 2373 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
