Question about GE 5.8 Cu. Ft. Extra-Large Capacity Gas Dryer
My dryer will not get hot
It comes on and gas is flowing but it will not get hot.
    Sergeant:
    Novelist:
  • 327 Answers
My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Posted on Dec 15, 2008
  • 446 Answers
The heating element is defective
System wont ignite. chgd filter & batteries in thermostat
Does the igniter get hot? If it does, then there is a problem with the gas control, that is, the gas won't come on for some reason. Generally, the gas won't come on if the igniter fails (for safety reasons), so are you sure there is gas flowing? You would hear the cycle start, that is the lighter, and even air flow, but if the gas doesn't come on during that time, the system shuts down in a few seconds.
Nov 30, 2015 | Heating & Cooling
Junkers gas geysers not heating water much
between 60 and 75 degrees c as any hotter will scald you. Have the gas specialist check it out as it may not be getting enough gas flow to the burner either a badly adjusted regulator or a blockage in the gas tap or line.. You control the temp by the amount of water coming out of the tap as you found out when you attempted to restrict the water flow.
May 29, 2013 | Water Heaters
I have a rinnai R53 natural gas tankless water heater. we are having a very difficult time finding someone who knows how to work on these. Our problems include: having to rely on turning on one trusty...
The issue is the flow sensor, if the faucets are restricted (like showers heads) then there is not enough flow to trip the sensor. This could also be related to pipe size and water pressure.
Mar 31, 2017 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Magic chef oven with uniburners oven will not light. igniter gets red hot but seems like no gas coming at all. burners on top work fine.
Since the bake burner does glow yet no flame that means that the igniter is weak and should replaced...the way the igniter works is that it comes on and get very hot where upon getting hot it draws a certain amount of amperage which will allow the gas valve to open resulting in a flame. The igniter is indeed coming on yet its not getting hot enough to draw the proper amp drqaw to open the gas valve...by replacing it with a new fresh igniter it will draw the correct amprage and let the gas flow.
GENE
Oct 02, 2011 | Magic Chef Ovens
Lower burner in oven will not light the ignighter does go on broiler works
GENE
Oct 02, 2011 | KitchenAid KGST307 Gas Kitchen Range
Maytag oven will not heat, no gas flow. Broiler works, clock and timer works.
You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
The hot surface igniter will not come on - check igniter with a ohm meter, you should have continuity through the glow bar, the glow bar can also crack = new igniter time. The glow bar comes on but the main burner will not light - you should have an amp probe to check properly, but often this is a hot surface igniter problem. The hot surface igniter often looses it's ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface igniter. The hot surface igniter can also quit part way through cooking , in other words the oven may cycle a couple of times and then it just sits there with the red glow from the igniter. See this service sheet for the proper way and amp readings for the hot surface igniter system. Hot surface igniters do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas with out the oven working. Yes, your glow bar igniter can glow orange-red and still be bad!! How a common gas valve works - click here.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 13, 2011 | Maytag Microwave Ovens
Our rheem pronto tankless rutg-74xp red light will come home indicating hot water and stay on about 2 minutes and then turns off we have turned off and back on and let water run for 5 minutes and will come...
Before calling service technician, open following link for Rheem troubleshooting resources.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
List of causes MIGHT include one of following:
Bad household circuit breaker that powers electronics, or loose wire inside outlet where tankless plugs in.
Tankless fuses and control board.
Water flow rate too low. Minimum .8 gallon required (depending on model)
Tankless inlet filter clogged.
Household aerators clogged at faucets.
Crossover at single-handled faucet
If installed, there can be crossover at mixing valve.
Faulty household check valve, including check valve on re-circulation system if that system is installed.
Restriction in household water line, such as clog at elbow.
Unequal pressure in household hot and cold lines, caused by restriction in hot line. When single-handled faucet turns on, the cold water pressure is higher so hot does not flow and tankless will not turn on.
Loose wire connection inside tankless.
Unit temperature set too high.
Unit temperature set too low.
Water temperature is very hot coming out of tap, so more cold is added, but that reduces amount of hot water flow, so tankless turns off because flow rate is too low.
On some tankless, if water is preheated by solar or other indirect source, the burner will not activate.
High mineral content in water > delime tankless yearly
Misaligned temperature sensor
Low gas pressure. Wrong type of gas. Undersized gas line.
Too many faucets on at same time.
Faulty tankless water valve. Water valve stuck.
Fluctuating household water pressure, for example MUD and PUD district water pressure problems or water well pressure.
Faulty household pressure reducing/regulating valve if installed.
Faulty household pressure tank, if installed -or- pressure tank needs to be installed.
Apr 24, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Will not lite. Glow plug comes on but gas does
check current draw on glow plug if less than 4 amps replace you need more than 4 amps to open bi metal strip for gas to flow over time the material boils off reducing resistance even if it is red hot... you want cake,,,REPLACE IT
Aug 14, 2009 | Dryers
No hot water flowing thru faucets
check the temp setting on hot water heater
if it is electric and 2 elements one could be out
You will have to take a multi meter and check continuity on elements
Purchase new element and replace
if it is gas increase tem
Jan 09, 2009 | Samyang Phoenix Faucet Shower Valve
Oven
the igniter is not getting hot enough. It can get hot enough to allow gas to flow but not quite enough to ignite the gas. It is an easy fix. The igniter is usually under the floor of the oven.
Aug 27, 2008 | DCS RGS-305 Professional Gas Kitchen Range
GE 5.8 Cu. Ft. Extra-Large Capacity Gas Dryer Logo
346 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
