Question about RCA L32W11 32 in. HD-Ready LCD Television
The price of getting fix
How much is it gonna cost me to get lamp in my rca tv fix or it could be the ballast and the power supply could've failed i just want to no whats the price of getting fix thank u
  • 103 Answers
Very expensive The lamp is part of the lcd assy 1000.00 plus to fix
Posted on Mar 22, 2007
Geha 285 eca
1, the lamp ballast is failing
2,the mother board is failing
3,check the fans, if every fan is running
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD
chip,color wheel,motherboard,powersupply,ballast... with high quality and
competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Mar 19, 2014 | InFocus Office Equipment & Supplies
CANON PROJECTOR LV-S4 POWER SUPPLY UNIT
power supply for S4 ,Unit price is USD65
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
skype:lampdeng
Feb 15, 2014 | Canon LV-LP12 Projector Lamp for LV-S1,...
Power supply
it seems that there ate 3 reasons for it
1,the lamp is failing
2,the lamp ballast is failing
3,the motherboard is failing
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color
price.
have a nice day!
Jan 29, 2014 | ViewSonic PJD6251 Projector
Dlp lamps burn out quickly
you may have an issue with the ballast module for this DLP tv, that module has the two large red wires that connect to the lamp socket. check the 47MFD 450V capacitor on this module. If swollen replace the part, but also check the large electrolytic capacitors, two of them on the power supply module, where you power cord attaches, one or both of these may be damaged if the 47 MFD on the ballast module has failed.
You will need soldering skills for this repair.
If the fans are ladden with dust, this could also cause premature lamp failure, these lamps require clear ventilation, overheating is the enemy!
jotvguy
Mar 05, 2013 | Samsung Televison & Video
SAMSUNG TV HL-85687W picture is dim
(Please check your model number - it appears to be incorrect, I believe it's HL-S5687W)
1) How old is the lamp? (how many hours on it)
2) Is the lamp an original equipment lamp, or aftermarket?
It's either the Lamp itself (it's not common for a sudden reduction in brightness), -or- the Lamp Ballast has gone bad. This is the power source for the Lamp, and although they usually die completely when they do go, sometimes they will act just as you have described... they fail into a "low power" mode.
If the lamp IS an original mfr lamp, and if it's nowhere close to being near "end of life", then I'd say it's likely the Ballast.
Prices for the original Samsung lamp run around $100 onamazon and others.
The Ballast p/n BP47-00037A has a cost of around $50 to $100 online.
Google those p/n in "Shopping"
The Ballast can be replaced without great knowledge, but will require some dis-assembly, and CARE.
WARNING - Dangerous, and even lethal voltages are present inside your TV set. Do not attempt this unless you are trained in these kinds of repairs. Leave the TV unplugged for several hours (or preferably a full day) before attempting such repairs.
Jan 12, 2013 | Samsung HL Televison & Video
I have sound on my tv but no picture
This sounds like the back-lights have quit working. This is made up with an inverter (ballast) and fluorescent lamps. I want you to try something. In a very dark room turn the tv on and watch what happens to the screen. There is three things that can happen. first the screen will stay completely black. This means the inverter never fired, and this is usually a failed inverter, but sometimes the power supply may fail. there is also a rare time the main module never outputted the signal to activate the inverter, but this is rare because you can hear the audio. So obviously the main is working at least 90%. The second thing that can happen is the screen will light for a split second then go black. This usually means that you have a bad lamp. These lamps are physically locate inside the LCD panel, and the replacement cost exceeds the price of a new unit. You may even see a dark area in the screen. The slight glow will not be uniformly lit through out the screen. Finally the last thing you may see is the screen has a slight glow. This means the back-lights work, but the video portion isn't showing. This usually means the driver board (T-con) has failed. This is probably not available separately, so you must replace the panel to fix it. And like before, the replacement cost exceeds the price of a new unit. One more thing to do when the set is on and in the very dark room if the screen is black, point a very intense flashlight into the screen. Put the flashlight against the lcd screen and see that you have video moving around the glow of the flashlight.
Sep 12, 2012 | RCA 22LA45RQD LCD TV/DVD Combo
I have a Sanyo plc-xt25 LCD Projector and when I plug my ac cord in, the fans turn on but no lamp comes on. I changed the lamp and still no picture. What do I do?
Every projector lamp is equipped with ballast. The problem area is ballast. Either the ballast is not getting DC supply or the lamp turn ON signal from the projector main board or the ballast is faulty. Remove the lamp. Connect the projector to the mains supply. Check the voltage at the lamp connector inside the projector without turning it ON. It should be around 65 volts A/C. (Warning: Multimeter will get damaged if the projector power is turned ON due to generation of high voltage) If you find this 65 volts then it confirms that it has DC supply & the ballast is functioning. The ballast receives the the turn ON signal from microcontroller through opto-coupler on the ballast. The ballast opto-coupler can be checked by providing external 5V DC supply between pin 3 (+ve) & 4 (-ve) in turn switches ON the lamp. If this works then there is no problem with your lamp & ballast. The problem lies with the main board. If this does not solve your problem then give me the feedback.
Aug 04, 2011 | Sanyo PLC-XT25 LCD Projector
RCA M50WH72S Replaced bulb and ballast. TV comes on with good video for about 5 seconds, then off with good audio, front power light blinks 5 times. After a few minutes the video comes back on and repeats...
Check capacitors cp624, cp647 1000uf@35v each. They are in the power supply. Can be seen with bulge on the top. Seems to be a common problem with this model RCA.
Jun 07, 2011 | RCA HDLP50W151 50" Rear Projection HDTV
I have a infocus IN35 that at 100 hours burnt out a bulb. Thinking that it was just a bulb problem I bought a new bulb and it lasted 20 minutes. a t.v.repair shop said its probably the ballast that is the...
It is not a common problem. Ballasts rarely need repairs. Have you reset the lamp hours to zero after installing new bulb? If, yes to confirm about ballast please ask the TV repair shop man whether previously he had repaired any DLP projector. There is lot of difference in technology of DLP projector & TV (except DLP Projection TV). The problem could be in the projector main board. The lamp lights after getting Lamp ON signal from the projector main board. As the lamp ignites the ballast sends the signal of Lamp Lit. If the projector board senses that any blower/exhaust fan or colour wheel is not running then it will send a signal to Switch OFF the lamp. If you are tech-savvy then do as follows to check about lamp & ballast. Remove 5 pin connector from the projector. Connect projector to mains supply. Get a 5V DC power supply. Connect +ve to pin 3 & -ve to pin 4 of the ballast connector from this supply. The lamp should light. If it does not light then there is problem in the ballast (if the lamp is new). To give a chance you can check it for your lamp which lasted 20 minutes. Generally ballasts are made by OSRAM. You can get the ballast from OSRAM dealer. You will need the part number for that. Take out the ballast, it is there on it.
Apr 14, 2011 | InFocus IN35 Projector
Replace lamp on 50' rca dlp and still no working.
Before replacing the Ballast I would look at the power-supply and see if you notice any of the electrolytic capacitors tops being bubbled. It is not uncommon for the capacitors to go bad as the lamp draws more current as it ages and fails. If you do see capacity's bubbled, Replace them or have them replaced and the set will probably work fine afterwards.
Hope this helps,
Skyassoc
Jun 28, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
RCA L32W11 32 in. HD-Ready LCD Television Logo
60 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
