Question about Motorola Mobility RAZR V3
Buzzin in the earpiece
There is buzzing in the earpiece and you can feel the vibration? What can it be and is it hazardous?
    Brigadier General:
  • 7,752 Answers
Yes it is hazardous and you should take the phone and have the ear-piece replaced.
Posted on Dec 26, 2008
When shower is activated can hear buzzing noise.I removed shover head arm and use only unrestricted hose.Buzzin do not stop.Then entire valve was replaced but with new one and problem still exist.
It sounds like the washer on the integral stop my have come loose and is fluttering. Remove the handle and faceplate. You may see a screwdriver slot on either side of the main valve. Tighten one of the screwdriver stops all the way down and turn the water on. If you still get the buzzing, open that side and close the other one. Now turn the water on again. If the buzzing stops and you do this, then I was right. If after going through the steps you still have a buzzing I don't have a clue
Dec 10, 2015 | Moen Home
I have GMC Envoy 2004 model. since few days i have notice that if i drive in a speed more than 100 KMPH, there is a slight vibration. please advise what could be the reason...
possibly a bad u-joint. Sometimes a u joint will feel ok but if it is too tight it can cause a vibration. you will need to remove the shaft to feel if a joint is too tight and binding. Or you have a tire out of balance. Usually a driveline vibration is more of a buzzing high frequency type of vibration the kind that puts your foot to sleep and a tire is more of a wheel speed vibration which is a lower frequency vibration.
May 02, 2011 | 2004 GMC Envoy
When pushing on gas pedal buzzing sound seems to go away
with engine running?? assuming noise is under hood here is one possible cause. sometimes pcv valve will make a buzzing noise as the little ball in there flaps around when spring gets weak. locate your pcv valve and feel it if this is noise you will feel the hose vibrating and if so replace valve
May 20, 2010 | 1999 Chevrolet Silverado 1500
Has buzzing sound when you plug it up
i
If you hear like whirling sound and vibration on the TV,it looks like the color wheel bearing is loosing balance and is hitting the housing unit,the color wheel spins @ 5000 rpm you will definitely notice when is going off i have this link that i found i hope it helps http://guides.fixyourdlp.com/samsung/bp96-01579a.php?click=52978 it's not your TV model but at least you will have and idea of what you need to look for.
good luck
Nov 10, 2009 | Samsung HCL4715W 47" Rear Projection...
Hazard light switch clicks all the time very fast?
You need to replace the flasher relay. I am not familiar with the Saturn Vue, but the flasher unit is usually located either under the dash adjacent to the steering column or fuse block. I would look under the dash while the flashers are on. If the relay is bad you should be able to locate it by the clicking sound that it will be making. A replacement unit can be purchased at an autoparts store. Take the old one with you for reference. Hope this helped and best wishes.
Aug 31, 2009 | Saturn Vue Cars & Trucks
Speakers work fine. But left earpiece has low vibration.
I had exactly the same problem. They will give you a new pair for $100, even if it has been longer than a year... Here is a link to my blog post...
http://riajournal.com/ria/index.php/2009/04/25/bose-gets-5-stars-in-my-book-for-their-qc3-headphones/
Mar 29, 2009 | Bose QuietComfort 3 Acoustic Noise...
A buzz nosie every time i plug in the t.v
COULD BE AN OLD ELECTROLYTIC CAPACITOR IN THE POWER SUPPLY
Nov 04, 2007 | RCA P52937 52" Rear Projection Television
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
