Question about GE GSS25LGM Side by Side Refrigerator
Got ice but no water
Icemaker works fine but water dispenser won't work. Would that be the dual water valve outlet not working. Was wondering if the valve can be bad on one side (the water dispenser), but still be good on the ice makers side? Is there any way to check to see if the valve works on both sides?
  • Anonymous Mar 26, 2014
    May tag side by side
  • 237 Answers
It could be the water valve side for the dispenser. So a coupleproblems can be had with this description. 1. The electricsolenoid for the valve is bad so it doesn't open the valve. 2.The valve itself could be bad so the solenoid opens it but nothingflows. 3. The water line could be frozen inside the door so nowater flows. 4. The dispensor switch is bad or the plastic holderthat holds the switch is bad so the switch fell out of its properposition. 5. The circuit board is bad.
Easy way to check is to pull out the fridge and take the water line offthat valve by pressing down on the little ring around the line whilepulling up on the line (tube thing). It should pull out easily(to reinsert just push the tubing back in without holding the littlering down, it goes in by itself and self-seals). With the tubeout of the solenoid valve have someone operate the water dispensorlever and see if water shoots in your face ha ha. Read further ifyou're testing by yourself...
You can also do the same test from the front underside where the tubinghas a coupling just under the door hinge area (so you can take the dooroff without cutting the tubing). Pull the lower skirt off the front ofthe refer and you should see the tubing and little coupling, it worksthe same, push down on the ring area and pull the tubing out. That way you don't have to move the fridge and can operate thedispensor lever yourself to see if water flows out the disconnectedcoupling. If water flows then the valve/switch/circuit board areworking fine of course and your tubing is frozen at the door. You willneed to defrost the tubing somehow, usually means a hairdryer blowingup into the dispensor area or turning off the whole refer and leavingthe door open for a day.
If nothing happens (no water still) then you need to check if thesolenoid is working electrically. Pull the fridge out and pullthe wire plug off the icemaker valve and put the wire plug from thedispensor valve on the icemaker valve. Watch inside the icemaker andpush the door dispensor lever, if water flows into the icemaker thenthe electrical door switch/circuit board is OK and the problem islikely the solenoid valve to the dispensor is bad or a frozen line inthe door still. You get the idea, you can swap wires/valves andeven tubing (if their the same size) around till you logically find thepart not working. Remember in troubleshooting you're not reallytrying to find the broken part... you're trying to find ALL the otherparts are working, which by process of elimination will lead you to thelast part that ISN'T working.
If you are comfortable with electrical troubleshooting using amultimeter you can check for 110 vac at the plugs when the switch ispress also but that depends on your tools and skill level, etc.
See this link for a diagram of that door assy and the parts involved.
Typically I'd be suspicious of the valve itself being bad or thecircuit board, next on the list is the switch, and last would be thefrozen line.
Good luck and let me know what you end up finding!
If nothing happens then you are down to either the circuit board is bad or the switch is bad.
http://tinyurl.com/5upeab
Posted on Dec 15, 2008
Icemaker will not make, cold water works fine, have changed inside filter nd outside filter I added before I knew there was one inside
Refrigerators with both ice and water dispensers have a dual port electric water inlet valve. This inlet valve is the plastic part usually on the back of the refrigerator where the house water supply connects to. This dual valve has 2 electric coils that open to let water in depending on if you want water to a glass or if the icemaker needs to fill with water. Your problem seems to be the half that fills the icemaker may be bad. The valve comes as 1 complete part for both water and ice.
May 09, 2015 | Refrigerators
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
How do i fix ice maker
Could be 2 different problems. Inlet water valve is a dual valve (2 halves). 1 half feeds water to the door dispenser, the other half fills the icemaker. The icemaker half could be bad or blocked up with sediment causing a no fill situation. 2nd problem could be the icemaker itself which sends power to the inlet valve when it needs filled. Usually the inlet valve fails first but you need to test and see.
Apr 14, 2015 | Refrigerators
Ice maker is not working and soft ice is forming around the area where the opening of the ice dispenser
Most of the time where they are making ice at the fill tube point the icemaker water valve in the back of the unit is leaking / dripping water past the valve / diaphram seat and it will have to be replaced. You can prove this by turning off the icemaker and then pulling the tube off the back of the unit and placing it into a bucket over night. If your sure the icemaker is off and there is water in the bucket the next morning the water valve is bad.
Now as for that ice in the icemaker fill tube... you can use a hand held hair dryer to defrost it once you change the water valve. I just changed my own water valve on a maytag less than 2 weeks ago that was doing the same thing. (Ice in fill hole and tube) It is working like a champ now.
A GE replacement dual outlet water valve:
http://www.appliancepartspros.com/Appliance-Parts/GE-Dual-water-inlet-valve-kit-item-number-AP3672839.aspx
(Make sure to use your model number when seeking the correct replacement see "useable on model list" bottom of the page)
Thanks for choosing FixYa.
Kelly
Aug 29, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Icemaker not working
The ice maker valve is a dual one. with 2 solenoids. One solenoid operates the water and the other the ice maker. So if the water works that don't mean the ice maker supply is ok. The ice maker itself controls the flow of water. So if the water valve is ok then the ice maker is faulty. I have repair photos HERE
Feb 14, 2010 | Refrigerators
No water at the dispenser
the water reservoir located in the refrig. compartment behind the drawers may be frozen,if nt the water inlet valve may be at fault.it is a dual valve system one side for the icemaker the other for the dispensor
Jan 18, 2010 | Frigidaire FRS3R5EMB Side by Side...
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
Maytag side by side fridge water dispenser not working
there are two water inlet valves on the back of refrigerator, one for icemaker the other for water in door. the valve for the water inlet is plugged or the soelinoid coil is bad. replace faulty valve, usually about 20 to 30 greenbacks at the appliance parts store
Apr 09, 2009 | Maytag MFI2568AE Side by Side French Door...
Icemaker does not make ice after first harvest.
theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker
verify the water supply to the valve first, second verify valve to icemaker works(unit has dual valve at rear bottom of fridge, switch plugs, then press water dispenser and see if icemaker fill with water ) if fills icemaker is bad , if not valve is bad. replace one or the other.
Mar 28, 2008 | Refrigerators
GE GSS25LGM Side by Side Refrigerator Logo
324 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
