Samsung LE15S5 LCD TV. Sound but no picture although can see the menu and Ceefax text
SOURCE: lcd tv no picture
I took mine back and they replaced it! Problem solved!
Posted on Jan 12, 2008
moto34
  • 155 Answers
SOURCE: Samsung LCD Tv
Try this:
Access menu service by press on your command, with your TV OFF:
INFO + MENU + MUTE + POWER ON
Then you should get access to Service Menu.
The last item says: RESET
This will do a reset to the TV.
Make no harm.
WARNING: If when on service menu you feel tempted to "screw" on anything FIRST take note on ALL you change! You can compromise the TV ...
Posted on May 03, 2008
  • 21 Answers
SOURCE: Samsung LNT4042HX LCD -unit powers
It seem to be light bulb problem to me, good luck
Posted on Sep 19, 2008
quang123
  • 107 Answers
SOURCE: HI, I HAVE A 3
Sound like you had problem with LCD screen or back lighr defected in any case it would not worth to repair it . But 2 thing you can check, when you said it turn off by itself is it the green LED still on or red if is red is LCD panel or inverter it come with LCD panel if is green is back neon light depend where are you some of repair shop can replace only the back light for you under $80.00
I hope it can help you make up your might
Cheers
Posted on Nov 30, 2008
  • 53 Answers
SOURCE: Samsung LCD tv wont turn on
what the full model number of your tv?
the clicking sound is the result of a faulty power supply, some capacitors(blown heads) on the power supply for the output voltage rail of the mains board need to be replaced.
pls rate me!
Posted on Mar 20, 2009
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
Samsung flat screen tv no picture sound only, I have checked all connections and remote still same problem.
The T con board is faulty. It is the board with flat ribbon cables going to the bottom of the screen. It is not hard to replace this board. You can get one from here:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Jan 01, 2016 | Samsung Televison & Video
My lcd tv screen is all dark although i can see movements and the sound is loud and clear. i am also trying to go to menu the problem is the texts cannot be seen. how do i fix this?
If you see a very faint image the set may use backlights that provide the light source--typical on many LCD sets----if they do not come on or are very weak either the voltage source or the actual backlights may be the issue---to confirm this Google the model number with "specs" to see if it has the lights or not. I bet it does.
Nov 04, 2012 | Televison & Video
HI, MY TV PCL5415R, HAVE SOUND BUT NO PICTURES SHOW ONLY BIG BLACK SQUARE
Set would seem to be either in PIP (picture in picture multiple mode) or the black box might be the TEXT feature which is found in the closed caption menu.
Nov 04, 2012 | Samsung PCL5415R TV
I have sound but no picture.
go to the tv menu and disable the text function
May 20, 2012 | Vizio 42 in. LCD TV
How do I reset my tv to factory settings. samsung 32 inch LA32R81WDx/xSA
On a different Samsung TV, there is a Picture Reset in the Picture Menu on the OSD. (It's at the bottom of the list.) Similarly the sound reset is in the Sound menu. There is no global reset. (If your Samsung TV's OSD menus are different try under the Support menu.)
I hope this helps.
Aug 05, 2010 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Samsung LCD -no picture/sound from any input source-Cable,DVD,PS3
Use the menu button in the front screen of your tv.Maybe your remote control need a battery.
Jul 24, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
HI, I HAVE A 3 YEAR OLD SAMSUNG LE15S5 LCD TV THAT TURNS ITSELF OFF, BUT THEN RETURNS TO NORMAL A FEW DAYS LATER. I HAD IT REPAIRED LAST YEAR UNDER THE GUARANTEE WHEN IT DID THE SAME THING. I WAS NOT TOLD...
Cheers
Nov 30, 2008 | Televison & Video
Sound
First I would check the cable from the ariel to the tv and all connections in between.
May 15, 2008 | Samsung LW26A33W 26 in. HD-Ready LCD...
Samsung LCD Tv
Try this:
Make no harm.
Apr 13, 2008 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Televison & Video Logo
536 people viewed this question
Top Televison & Video Experts
