Question about Vivitar ViviCam 3785 Digital Camera
When i try to view my pictures a memory error comes up.
The camera is a Vivicam 3785
  • 446 Answers
Most likely the memory you are using is either corrupted or not damaged, try using a diferent one similar to the SD card you are using...
cheers
Posted on Dec 15, 2008
How do I clear the internal memory?
This should do it - this comes from the manual Formatting will do what you want.
Formatting an SD Memory Card or Internal Memory This utility formats the internal memory (or memory card) and erases all stored images and data. 1. Press the button to turn on your ViviCam 3785. 2. Press the MODE button twice to enter [ ] Playback mode. Then press the button to enter the Playback menu. 3. Select [Delete] by using the / buttons, and press the button. 4. Select [Format ] by using the / buttons, and press the button. 5. If you want to format your SD memory card or the internal memory choose [OK] by pressing / buttons, then press the button to confirm.  To cancel the action, select [Cancel] instead.  [No Image] pops up after the SD memory card or internal memory has been formatted. Note:  Be sure the SD memory card is properly inserted into the camera before formatting it.  To format the internal memory, be sure to remove your SD memory card first.  Formatting will erase all information (even unrelated , non-camera data) from the memory/card.  For complete compatibility, be sure NOT to select FAT 32 as the file system when you format the SD card in your computer. Memory cards formatted in FAT 32 file system will not be recognized by this ViviCam 3785.
Jun 16, 2011 | Vivitar ViviCam 3785 Digital Camera
I have recently bought a usb cord for my vivicam 3785 and my computer cannot locate nor can i download my pictures to the computer.What should I do?
Are you try other usb port? then, it is your camera can functinally plug and play? if that camera came with software, try install first before use it.
try this driver:
Driver vivicam 3785
May 10, 2011 | Vivitar ViviCam 3785 Digital Camera
How do I format an SD card for a Vivicam 3785?
You can format the SD card in your ViviCam 3785.
This utility formats the internal memory (or memory card) and erases all stored images and data. Make sure your SD card is in the unlocked position.
2. Press the MODE button twice to enter Playback mode. Then press
3. Select [Delete] by using the up/down arrow buttons, and press the OK button.
4. Select [Format ] by using the up/down arrow buttons, and press the OK button.
[OK] by pressing up/down arrow buttons, then press the OK button to confirm.
has been formatted.
If you need a manual for your camera you can download a free PDF at
http://www.retrevo.com/support/Vivitar-3785-Digital-Cameras-manual/id/200ag818/t/2/
Please rate this solution. Thanks.
Jan 15, 2010 | Vivitar ViviCam 3785 Digital Camera
Can i use a 2 gig sd card in the vivicam 3785
Manual says that camera only supports up to 512MB. Just tried it with a 2GB card now--gives a "Card Full" error.
Oct 12, 2009 | Vivitar ViviCam 3785 Digital Camera
Controls on the back of camera
Most probably find a Vivitar Vivicam 3785 manual here. Just send them a search request.
Apr 20, 2009 | Vivitar ViviCam 3785 Digital Camera
Pictures cant be viewed says no image-then wont take pics says card full?
try the memory card in a card reader and plug it into a computer. see if the computer can detect the card and the contents in it. if it does detect it then that means there is a problem with the camera not recognizing the card or files in it. if it does not detect it in the computer that means the memory card of the camera is the one having problems.
Jun 09, 2008 | Vivitar ViviCam 3785 Digital Camera
Instruction manual Needed
you can download the full manual free of charge at this link http://www.manualnguide.com/download/manual-guide/vivitar-vivicam-3785-digital
-camera-users-manual.html, then click view/download and it will download and open up in adobe as a .pdf file.
Jan 29, 2008 | Vivitar ViviCam 3785 Digital Camera
Vivitar - ViviCam 3785
your mega pix arent that great, get a new camera
Nov 13, 2007 | Vivitar ViviCam 3785 Digital Camera
Memory Error
I had the same problem but fixed it by following the camera's directions to re-format the SD memory. You will lose all pictures on the memory card so remember to first save your pictures to your computer. Good luck.
Nov 16, 2006 | Vivitar ViviCam 3785 Digital Camera
Vivitar ViviCam 3785 Digital Camera Logo
65 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
