Question about Hitachi Deskstar 7K250 80GB (hds722580vlat20) 80 GB Hard Drive
My harddisk doesn't turn on...
Hello: I have a big problem with this device. On past tuesday I was playing with hdparm settings, I was working on debian etch O.S. Then I turned off Pc and I didn't notice nothing unusual. When I turned on pc again (an hours later) the harddisk didn't turn on and the bios didn't recognize it correctly. It's like the harddrive haven't power. I also checked the connectors and these are ok. I don't know what happened, but somebody said to me with a low-level formatting I could fix the problem. Is it true??? Here is the harddisk specifications: Manufacturer: Hitachi Type: Deskstar model: HDS722580VLAT20 Cap.: 80gb Thanks in advance Pd: Excuse me by my english but I`m from chile and I`m studying english. Thanks Thanks in advance
  • Francisco Mac-Evoy Mar 19, 2007
    Hello:
    I've cleared BIOS (With the jumpers in the motherboard. But I didn't try with the battery) and this didn't work, but there's something strange. When the system starts and tries to recognize the drives, appears the serial number: V320A63A instead of HDS722580VLAT20.
    Thanks in advance
  • 53 Answers
Then again you could try to re-set the bios to default factory settings and re-boot. pull cmos battery for about 1 minute re-install battery and re-boot. then discuss catastrophic failure.:-)
Posted on Mar 19, 2007
We call them in the industry Death Stars! I have had several just die on me! If the drive does not show in the BIOS then you can't do a low level format! All the ones that have died on me have burnt out components on there circuit boards. Way to small for me to solder! So they were thrown away!
Iphone won't detect bluetooth
It's probably not the speaker, your phone is not recognizing the device. This is the link How to troubleshoot Bluetooth Connections from Apple:
http://support.apple.com/kb/TS4562
Dec 25, 2013 | Brookstone Big Blue Live Wireless...
Sir,i have install 3 sata hdd on my motherboard gigabyte 945 GCM-S2L 1. 160gb 2. 500gb 3. 1 tb. my pc many times hangs on bootup and freezes then i disconnect the cable to turn off. how to fix that...
Do extensive diagnostic tests:
1. Set BIOS to default settings and do not use overclock settings, check.
2. Memory test, download ISO image, burn it onto cd and boot from it.
If memory fails after several hours testing: Replace memory
3. Flash the latest (original)[beta] BIOS version.
4. Connect just one (1) harddisk and test for longer time. *
5. Add second harddisk and test for longer time. *
6. Add third harddisk and test for longer time. *
* If connecting or adding harddisk leads to freezes, exchange that harddisk and retest.
Sep 25, 2011 | Gigabyte GA-945GCM-s2C socket LGA775...
I am trying to download the netflix app on the nintendo wii from the wii shop channel online and I keep getting the error code:204965
There may be a problem with your connection on the Wii. I would try erasing the connection on the Wii and starting over. If that still doesn't work, when is the last time you updated?
The Wii may not be able to use the wireless it has because of the broadcast channel from the router. You would need to go into the routers settings and change the channel to either 1 or 11. The default is usually 6 but that tends to be weak. Retry the connection.
Jun 09, 2011 | Video Game Consoles & Games
I cant play music on my mp3
hello,
make sure you have music files in your device..if none,
plug in your device to a computer then copy and paste the music files to your device..then select play all in your device settings..
goodluck!!
Feb 25, 2011 | Audio Players & Recorders
Computer wont turn on
First open cpu cabinet then pull cmos cell from motherbord for 10 minutes.
Refix RAM memory.
Reattch ATX power connector to motherbord.
Reattch power cable and SATA or ide cable to harddisk.
Clean dust from all parts of motherbord.
Open processor fan and processor.
Then reattch both.
Make sure motherbord is not ground with cabinet.
When you power up the computer press F1 or F2 or "del" key then enter in bios .
Make sure in bios your harddisk is detected.
If not then change SATA or IDE cable of harddisk.
Then check .Go to boot menu nof bios then set first boot device as your harddisk.Then save settings and exit.
Let me know if you need further assistance.Thanks.
Nov 21, 2009 | HP Compaq Presario S5200NX (DM173A#ABA) PC...
Format Problem???
hello!
Try running it on win XP ,you have to install win XP on your pc or any other program to access the harddisk .
good luck
Oct 06, 2009 | Western Digital My Book Essential Edition...
Harddisk not detected in disk management but recognized in bios
Does it show in the devices? If it is, check and see if it is disabled. If not, check the jumper settings on both drives, and check your bios settings.
Sep 02, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
Hello, My Harddisk is 6months old seagate.It was working fine b4 4-5hrs and now i turned on my computer it says No Bootable Device Detected -- Insert boot disk Press any key.My HDD is also not...
Seems like the harddisk is broken, and it's not really fixable... The good news, however, is that after 6 months the warranty should still be acxtive, so you can send it back to Seagate and get a new one. I hope this answers your question, Yannick.
Jun 09, 2009 | Toshiba A75-S125 Satellite Notebook
Big white square appears when playing a DVD.
Check your Closed Caption settings. Either turn it off or change it to text 1.
Sep 16, 2008 | Mitsubishi WD-52628 52" Projection HDTV
My PSP keeps turning itself off
same thing with me i bought little big planet saturday and on tuesday i woke up and i wanted to play it and it started loading then it froze then 30 secs late it cuts off then i thought it was the game then i got the same on again and same thing p.s it only happens with little big planet
May 16, 2008 | Video Game Consoles & Games
Hitachi Deskstar 7K250 80GB (hds722580vlat20) 80 GB Hard Drive Logo
697 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
