Question about HP Color LaserJet 3500 Printer
HP LaserJet 1200 series
I replaced the transfer roller and the fuser in an HP LaserJet 1200 printer and it shows a flashing orange light. Before I replaced any of these things, it still had that flashing orange light. There is no paper in it, no paper jam, i tried two other toner cartridges and still same orange blinking light. I turn it off and turn it back on it goes through the check through then stops and orange light comes on. What else could I check? Remember, it did this even BEFORE i replaced the transfer roller and fuser assembly. Please help!
    Novelist:
  • 125 Answers
Hi vgde2004: Here are some things to check.
1. The printer is in manual feed mode.
Possible solution: Change the manual feed setting in "printer properties"
2. The door is open,the media is out,the toner cartridge is installed incorrectly,or the paper is jammed. Check paper path.
3.Fan error
Solution:
1. Check fan cables for looseness.
2. Replace fan assembly
Posted on Jan 09, 2009
Identical smudges 3 inch spacing
3 inches is approximately 70 or so mm so i would say you have a bad drum on your toner
27mm - charge roller - Replace toner
75mm - Photosensitive Drum - Replace toner
34mm - Developing Roller - Replace toner
39mm - Transfer roller - clean/replace transfer roller
57mm - Fuser Film - Replace Fuser
56mm - Pressure Roller - Replace Fuser
Oct 06, 2014 | HP LaserJet Pro P1102W Printer
Hpllaser jet 1200 paper stuck in the back I had try to pull it but I can barely see it there, i can't see it from the front
You might use a tweezers and try to pull out the paper. The paper is stuck by a sensor, and if you can clear that sensor, the machine will start up, and transport the rest of the paper out. Be carefull and try not to hurt the fusing rollers, while picking with the tweezers.
If it's no good, you have to disassemble
the fuser-unit and remove the paper, or in worst case, replace the fuser unit..
May 10, 2012 | HP LaserJet 1200n Printer
Hi there our yeelow light is flashing on HP 1200 Series printer what do you think is the problem?
There can be a number of reasons for this. If you turn the printer off, disconnect the printer cable and then power back on, does the yellow light still come on? Or does it come on after you send a job to it?
If light comes on after send job then it may be the paper pickup roller is dirty and or worn. Take the toner cartridge out and check.
If the light comes on after powering up then you may have a paper jam in the fuser area. That is situated just before where the paper exits. The panels on this printer come off easily. You need to take the rear panel off and shine a torch in the fuser/heat roller area and see if there is any jammed paper.
May 20, 2011 | HP LaserJet 1200 Printer
What does the HP LaserJet 2100 Series Maintenance Kit includes?
HP LaserJet 2100 120-volt maintenance kit, includes fuser roller assembly, transfer roller assembly, tray 1 & 2 pickup rollers and tray 1 & 2 separation pads.
Aug 12, 2010 | Canon Office Equipment & Supplies
I have a HP laserjet 4P. The print was coming out
You need to replace your transfer roller. Might as well do a complete maintenance kit.(Rollers, Fuser and Transfer Roller)
Nov 08, 2009 | HP LaserJet 4p Printer
From the printer indicator,the printer is requesting for transfer fuser kit. the percentage is low,down to 0%. What is transfer fuser kit?
GENUINE HP COLOR LASERJET 2600 MAINTENANCE KIT - Kit Includes: 120V(220v) Fuser Unit, Tray 2 Paper Pickup Roller (D-Shaped Roller), Tray 2 Separation Pad Assembly - Includes The Spring Loaded Separation Pad In Holder Assembly - Genuine HP Part
Oct 21, 2009 | HP Color LaserJet 2600n Printer
Vertical dots down center of paper HP 1320 printer
If the pattern repeats down the feed path of the paper, then a roller is causing it. The toner cartridge replaces the transfer drum, the fuser roller remains in the printer. Since your old cartridge does not show this problem the fuser roller sounds to be fine. Return the recently purchased toner for a replacment, you should be fine. If not then a proper cleaning by a certified technician would be in order.
Aug 26, 2009 | HP LaserJet 1320 Printer
Attention Light Is Rapidly Blinking Orange
sorry I got it, usually you may try:
1) check all paper road no paper inside include the area betweem input tray and cartridge unit the area wetween cartridge and fuser unit and output tray.
2) check 4 sensor input sensor near the input tray roller, marging sensor between input roller and cartridge unit, cartridge sensor at oneside of cartridge unit body, fuser sensor near fuser roller. usually need to clean or adjustment the position.
3) check input roller and cartridge unit and fuser unit at running condition when the power on.
anyone nothing running show error light blink, also show the hardware trouble if all sensors are normal.
Dec 24, 2008 | HP LaserJet 1300 Printer
HP LASERJET 4 PAPER JAM 13
Rollers do not turn on!
Rollers are driven by a motor.
How is the printer telling you this information? (does the PC give an error, or the printer flash lights)
Does the paper make it out of the machine?
Is this "Rollers in the Back" the Fuser Unit?
is The Fuser unit is going bad,
if you open the back top cover, where it gets real hot, where the paper exit's, you should see two rollers, one orange, one either brown or black.. if that orange roller is damaged, has crease's, or covered with black toner, if the paper jams here alott, you probably need a new fuser unit. there is a pm kit available which includes the fuser and rollers, transfer, etc, which this site might have
http://www.all-laser.com/cgi-bin/webc.cgi/Menu_HP_maint.html
Oct 23, 2008 | HP LaserJet 4 plus Printer
Printer
You need to replace the fuser, here is an example of replacement part
HP Fuser for LaserJet 5000
These are instructions for replacement:
HP laserjet 5000 fuser instructions
Apr 24, 2008 | HP LaserJet 5000 Printer
HP Color LaserJet 3500 Printer Logo
572 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
