Need to know what codes mean
SOURCE: I have a diagnostic code
p1811 means=Replace Pressure Control Solenoid Valve Assembly. Its a common problem with saturn transmissions.
SOURCE: 99 Saturn with trouble code P0341
cam position code ,ingnition coil for 1&4 plug,probably fail plug wires or corrosion at coil and plug wires. could also be cracked 1or4 sparkplug.
SOURCE: I have a 2001 saturn L100 that has a code of
EGR Valve is on the intake manifold on the right side rear by the shock tower. It's round, has a base similar to a diamond shape, and has a steel tube leading up to it's base area on the back of the rear intake manifold. You can take it off and clean it out with throttle body cleaner, and clean the tube, but I've never seen one plugged. If it's indeed bad then I'd replace it and get a new gasket. If you're not sure how to check it then you should reask and clarify that.
BTW... just because there's a code doesn't mean the valve is broken. Could be an electrical issue. Again, check and clarify please.
SOURCE: What does code P1133 mean: 98 Saturn SW2?
hi this site will have your answer..hope this helps
http://www.saturnfans.com/forums/showthread.php?t=136348
just click link
SOURCE: 2003 saturn vue trouble code p1599
P1599 IS A STALLING ISSUE COULD BE BAD GAS / BAD FUELPUMP DIRTY FUEL FILTER
DISCONNECT BATTERY AND SEE IF THE LIGHT COMES ON AGAIN
U2107 HAS SOMETHING TO DO WITH THE COMPUTER LOOSING POWER AT THE BODY MOUNTS CHECK CABLES AND GROUND STRAP
