Question about Crosley CDE6000 Electric Dryer
Dryer wont start
I had a flood in my basement & my dryer hasnt worked since
  • Crosley Master
  • 19,396 Answers
In the lower part of the dryer you have wirings, the motor, and often also an elecronic module, that also works at 120V, if water had reached one of this parts while the dryer was hooked to powe, it must have caused a short.
The appliance must be taken apart by a repairman, and the part that has shorted, replaced or repaired.
Posted on Dec 15, 2008
Neptune mce8000ay
probably threw a breaker wich is a very good thing dry up water and make sure dryer unit is not wet any where unde it or maybe from some condesation depending on where you live could be more or less however it may be the water some how caused the problem??thats all i have with the info you have given sorry but hope it helps
Oct 07, 2013 | Dryers
Hello, my dryer got wet due to my basement flooding and it starts, but no heat.
It is highly risky to use any electric appliance even after the removal of flood water. Before using it you need to make sure that it is not wet from either inside or outside. Even a single drop of water can cause a short circuit at you home and can also lead to unfortunate event. In such case you need to search for a company like http://floodfixer.com/ that dries wet basements to ensure your safety. Professionals can bring your valuable possessions back to its original position and make them ready for reuse.
Sep 12, 2011 | Hotpoint NBXR333GGWW Gas Dryer
GE Gas Dryer DDG8280SAMWW runs, but does not heat. We had a minor basement flood (thank you, Hurricane Irene!) with about 4" or so around the dryer. We do not hear the "whoosh" that would...
Sorry to hear about the flooded basement ..here in Virginia i only had a couple trees down and power go off for 12 hrs but no flooded basement.
Their is no way to clean/clear the igniter persay..gotta check and see what shorted out due to the flood...this tip i wrote explains what to check on gas dryers when they dont heat. http://www.fixya.com/support/r10293028-gas_dryer_not_heating
Good luck i hope this help you to figure out why your dryer isnt heating,
GENE
Aug 31, 2011 | GE Dryers
Basement flooded,Dryer runs but wont heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 26, 2011 | Frigidaire GLGR341AS Gas Dryer
My basement got flooded and my kenmore elite now don't want to start
you have a bad motor,i live in boston and we had some floods here,every dryer i checked that got wet needed new motors,the washers were fine,check with a meter to see if power is going to motor,if it is and it's not starting you know it's the motor.good luck.the motors are easy to change out yourself
Oct 12, 2010 | Kenmore 63942 Dryer
My Roper dryer worked fine until my basement flooded about 6 inches of water on floor. Now my dryer just hums when I try to start the dryer. The heat does come on. When I spin the drum and hold in the door...
It sounds like the motor was damaged in the flood. You may be able to salvage it by spraying both ends of the motor shaft with penetrating oil several times moving it in between, but you may not be able to salvage it.
Dec 30, 2009 | Roper REX4634KQ Electric Dryer
Dryer wet due to flooded basement
if it was p[lugged in you might have to replace the circuit board,, they can conduit electricity from one circuit to the other in water
Apr 30, 2009 | Kenmore 62602 Electric Dryer
Whirpool Mod WGD5300SQ0
How much water did you have in the basement? Back in June we had flooding in the area, and the my recommendation to everyone has been to replace any appliance that was under any water.
If the motor was under water, wires or the gas valves, these components will corroded and could cause you future safety concerns.
Jul 26, 2008 | Whirlpool GGQ8831L Gas Dryer
Crosley CDE6000 Electric Dryer Logo
83 people viewed this question
Top Crosley Dryers Experts
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
