Question about ViewSonic N4251w 42 in. LCD Television
This is for a Model N4251w. There is a streak in the picture that is not on the surface. It looks like apaint brush made a streak of approximately 8 inches and 1 .5 inches wide....it looks like a paint brush mark. Any suggestions. It's not under warranty.
  • amytroiano Dec 31, 2008
    I have 1 streak down mine also and I'm starting to get a second streak.
Mine does it also. These things are ****
Posted on Aug 02, 2010
    Scholar:
  • 118 Answers
I just answeres the same question, it's the screen burnt in from something being on too long, or it could also be the T.V. being so old that the plasma gases aren't controlled anymore. They run off of gases, so either it's burnt or the gases are bad.
Posted on Jan 29, 2009
Trying to remove the Hunter Stratford II 52" ceiling fan. The canopy ring rotates approximately 1/4 turn but does not release.
http://www.hunterfan.com/uploadedfiles/Support/Owner_Manuals/41803.pdf
Page 8 of the model 20761 Hunter ceiling fan shows how to remove the canopy trim ring. Ours had double stick tape holding the brushed nickel to a plastic trim ring. Dropped it, then squeezed the plastic ring.
Sep 19, 2011 | Hunter 20761 52'' The Stratford II Brushed...
Cannon D1150 I have a crease down the middle of the page as well as faint black ink. How do I correct this. this happens on envelopes as well.
this sounds to me as toner cartridge fault.
Remove the crg and look at drum surface for streaks. If the streaks are on drum surface, replace drum ( toner ) cartridge if not the problem is in fixing assy.
Hope that helps!
Aug 23, 2011 | Canon imageCLASS D1150 All-In-One Laser...
Need apaint code for yamaha fz6 black
Look @ colorrite.com for your bike...........I'm not seeing the black on that bike
Nov 29, 2009 | 2005 Yamaha FZ6 Fazer
Playback problem
do u see these streaks in lcd as well during rec or just in output
and also first try cleaning the head with head cleaning cassette if it helps otherwise ur problem is this see the link just call JVC for free repairs for CCD Sensors u get streaks blackouts and dsicolored picture when CCD goes Bad no problem it is a known problem just call them in ur region they will arrange for free repairs and pls rate me FIXYA for help
http://www.jvc.co.uk/template.php?page=100102
Apr 11, 2009 | JVC GRD250 MiniDV Digital Camcorder
Blue Streak at bottom on LCD TV screen
Most likely being your television being on something too long and now it's burnt in, you can leave a non-moving object on your T.V. too long, the channel icons are okay because of the commercials. There's really nothing you can do now.
Jan 29, 2009 | ViewSonic N4251w 42 in. LCD Television
Finish on "stainless steel" door is deteriorating
Refrigerator was sold as 'stainless steel', but is not, a magnet won't stick to it.
There are many different alloys that are called 'stainless' steel but all of them have some chrome, some nickel and some steel. Depending on the strength of the magnet and the specific alloy, it may or may not adhere. Generally, the higher chrome and nickel content, the less magnetic it will be.
I think that the brushed surface of your fridge was coated with a kind of clear-coat to prevent fingerprints from adhereing to the brushed surface and that clear-coat is now missing in the areas of concern.
The only cure for tha would be the wholesale removal of the doors and the remaining clear finish and then respraying it with a quality clear finsh.
Ain't progress grand?
We considered all stainless stuff for our new home a couple of years ago, decided we liked black better and now hate that too.
Dec 10, 2008 | KitchenAid (KSRD22FKST) Side by Side...
pulled main board and reseat conector in the board right in the middle of the set. set is runing for two hours, keep you posted.
Oct 30, 2008 | ViewSonic N4251w 42 in. LCD Television
Blue Streaks
Try removing the printhead (cartridges first, careful where you put them, they'll make a mess) then clean the print surface with a window cleaner and cotton swabs.
There may just be deposits on the surface and this is not far from the paper surface.
Aug 15, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Black streaks on printout page
It sounds like excess toner has built up in or around the imaging drum. I would *carefully* remove the toner and drum (can be messy) and use some canned air to clean the inside out. If you are still getting these streaks, it might be time to get a new drum (DR 400) as you are supposed to replace the drum every 6 to 8 times you change the toner cartridge.
Aug 22, 2007 | Brother HL 1440 Laser Printer
ViewSonic N4251w 42 in. LCD Television Logo
178 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
