Question about Libec LS-55 Aluminum Tripod System - consists of: H55 Fluid Head, T58 1-Stage Tripod, SP-1 On-Ground...
Libec servo kit for SONY PMW EX1
I want to use tilt / zoom servo of libec for SONY PMW EX1 with standard fujinon and canon lense. please guide me
Sony PMW EX1 doesn't power on
there are many tiny fuses on the circuit board any of it may be open,replace it.
Jun 11, 2018 | Sony Video Cameras
My Sony pmw ex1 cameras view finder and lcd is not working due to my EVF board Wich is on handle is dameged
sir,
Hence it is a prestige model of Sony, the spare parts of this model is available everywhere, can change it easily.
Jan 22, 2016 | Sony PMW-EX3 High Definition Camcorder
ServiceNavi-EX password
Password is : kaguya
Have a good day.
Mar 25, 2013 | Sony Pmw-ex1 Xdcam Hd Camcorder Ex-1
How to disarm Fujinon SRD-92B Zoom Rate Demand
Remove end plate. Remove rate control knob and pot. Loosen up three set screws on housing, center zoom control, and slide entire assembly out the end of the housing. Where will you find a replacement spring?
Feb 28, 2013 | Fujinon Inc SRD-92B Zoom Rate Demand with...
Looking for the UNIT PRISM BLOCK for the Sony PMW EX1
Hola Carlos!
Look at Sony Part Catalog. Enter A1539606A at the top of the page and click Search.
Saudades de Israel,
Pelu.
Apr 06, 2010 | Sony PMWEX1UC Camcorder
When trying to import XDCAM (SD) clips into Final Cut Pro, the xdcam transfer software is first coming up with the error - ERROR SCANNING DEVICE - The mediapro.xml file cannot be found. This is most likely...
The Sony XDCAM EX series camcorder including Sony PMW-EX1, Sony PMW-EX1R, Sony PMW-EX3 and Sony PMW-350. For FCP users who are facing the same issue to import Sony XDCAM EX MP4 to FCP X, there are 2 solutions for you to fix the problems.
The first solution is using third-party Sony XDCAM Transfer software. Prior to importing Sony XDCAM EX MP4 with with XDCAM Transfer, you may use the Sony XDCAM EX Clip Browse to first copy the SxS-based media to local storage. Then you can ingest MPEG-4 wrapped XDCAM-EX media to QuickTime-wrapped media with XDCAM Transfer application on your scratch disk. Then you can simply choose the XDCAM EX Easy Setup that corresponds to your footage and edit as you would with any other native format in Final Cut Pro.
If the first solution is too complicated for you or you encounter some unsolvable problem when adopting the first method. A much simple but reliable alternative solution is recommended to you. You can use a third-party application to transcode Sony XDCAM EX MP4 to FCP X best native compatible editing codec -Apple Prores, which is specially developed by Apple for fast and fluid post-production editing workflow in Final Cut Pro X.
http://www.multipelife.com/transcode-xdcam-ex-to-prores-for-fcp-x.html
Apr 12, 2017 | Sony Televison & Video
Tamron 28-300mm lens
Many zoom lenses of this length, and even shorter have the problem whereby the lens either extends or retracts under its own weight depending on whether the camera is pointing up or down. I had a Canon 28-105mm lens with this problem. More expensive lenses have zoom locks to prevent this from happening. $225 sound like a good price to me!
Sep 28, 2007 | Tamron 28-300mm f/3.5-6.3 DI XR for Canon
Photography Logo
77 people viewed this question
Top Libec Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Libec Photography Expert? Answer questions, earn points and help others
