Question about Dell Dimension 4600 PC Desktop
Monitor randomly goes to sleep
I just got a new computer a week ago. It was working fine for three days then all of a sudden the monitor went to sleep while I was playing World of Warcraft. I let it sit and started it back up and it worked for about 10 min then the same problem occured. I always have to let it sit for about 10 min before i can try getting it going again. Now its to the point of going to sleep when im just at my desktop. Also, when this does happen the computar sound freezes and it loops the same part over and over. So, I think the computer is also freezing, I'm clueless as to what to do so any suggestions.
  • mattm2233 Dec 15, 2008
    I dont really remember to be honest, do you think reinstalling windows and everything on it might do the trick?
  • Greg Wilkins
    Greg Wilkins May 11, 2010
    did you happen to download a program just before this happened? Sounds like a software conflict
    Problem Solver:
  • 16 Answers
Sounds like it may be a backlight issue. Try using another monitor if possible and see if the same issue occurs. If it does, then it's the backlight in the monitor. If it's not this, it could be as bibleman01 mentioned a software conflict or an issue with the graphics controller failing.
Posted on Dec 15, 2008
My display screen goes on and off
I find sleep mode nothing but trouble, eventually corrupts window files over extended use, go into power options, go to stand by and select never and click apply, next go to hibernate "top right" and click, make sure the check box is clear, if not! remove check and click apply and restart your laptop.
Apr 04, 2012 | Sony VAIO Computers & Internet
I just added a LCD monitor to my eMachines ET1331G desktop computer. Everything worked fine until I left it on for a day. The computer went into sleep mode and now I can't get it to wake up. I've trie
You should be able to just press the main system unit power button to wake up your 'sleeping' computer which will then resume your Windows desktop and bring you back to the Login panel if you have a password set for your account.
Dec 29, 2011 | eMachines D Computers & Internet
My HP W1907 monitor works fine until I try to play The Sims 3 game. I play for several minutes or hours and the monitor shows the message that it is going to sleep and the light on the monitor goes...
Hi there. I had the same problem months ago when I try to play high end games like Sims 3 my monitor goes into power saving mode. I tried to check every possible causes of the problem. It could be that your computer is overheating try to clean your computer and check if your fans still works. Second it could me your power supply malfunctioning, maybe it does not meet the required power to make your game work. Last cause is your video card malfunctioning, what I did is to just buy a new video card and it works.
If you do not have spare power supply or video card you can go to a computer repair shop for them to check the possible problem that causes it to go into power saving mode. It can also save you money before you can buy a new one.
Hope this helps, Have a good day!
Oct 03, 2010 | HP w1907 LCD Monitor
Gateway FPD2185W Monnitor Goes to sleep and won't wake up.
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Corporate Computer
Over 21 years of computer and printer support/repair
Jul 13, 2009 | Computers & Internet
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Jan 31, 2009 | HP 2025 20.1" Flat Panel LCD Monitor
Monitor is black. Press power on monitor/screen shows for 1 sec
You will need a new monitor screen. I have had two screens go on me recently and what you describes normally happens
Dec 10, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Dell LCD monitor quickly goes sleep, on, off over and over
I would recommend that you try it on another computer to see if you are able to reproduce the results. If that is the case you should look at any new drivers, software or updates that have been installed. If the issue continues with another PC, it sounds as though the monitor's power supply is possibly failing. in that case I would suggest you simply replace the whole monitor. Unless you are not shy with a soldering iron. ;) good luck!
Nov 19, 2008 | Dell E197FP LCD Monitor
Monitor going to sleep at startup
try changing the video card of your computer..
Aug 27, 2008 | HP vs19 (Silver) 19" LCD Monitor
Monitor goes black but green light still on.
The problem with the Mag lt916s is that it is made with cheap capacitors. If you are interesnted it is a cheap and easy fix. Open it up, which is the hardest part. And replace the six 470uf 105 degree 25v capacitors and maybe even the smaller 220uf one next to them. You will see a bump on the top of bad capacitors most of the time. There are some videos to watch on Youtube showing you how to make the repair.
Good luck
Dec 27, 2007 | Computers & Internet
Dell Dimension 4600 PC Desktop Logo
244 people viewed this question
Alun Cox
