Question about Casio Parts Cash Register PC Desktop
Anyone know what error code e94 on a casio cr120b & how to fix
We have a error code e94 and dont know how to resolve this
  • toniwild Dec 15, 2008
    thanks sent it to a friend who may understand what you said lol , dumb blonde here ! thankyou
E94 errors - paper jam can be cleared by removing battery back-up and replacing them. The error appears to be retained in the memory.
Posted on Feb 08, 2009
    Problem Solver:
  • 8 Answers
Error:
No data transmission from the central unit to the console
Cause:
- Interruption or accidental ground in the cable between central unit and console
- 5 V supply of the computer in the central unit is missing
- 5 V supply is too low
- Computer module is defective
Elimination / Solution:
- Check wiring to the console (in case of accidental ground, replace console electronics, too).
- Check connection to the power unit
- Exchange the LMI main board
- Replace console electronics or LMI main board
- Replace processor board
- Eliminate the source of interferences by inverse diodes or varistors.
Posted on Dec 15, 2008
How do i get E94 code to clear and use casio E94 without printer paper?
Usually you have to fix the printer problem. Most Casios test the printer at turn on and won't go further if it is faulty. This stops you losing any print outs
Sep 25, 2017 | Retail Supplies
I have an error code of E94 on my intex portable spa what does it mean?
If alarm code E94 is displayed on the control panel, it means the water temperature is too low. If alarm code E94 appears, unplug and plug back in the GFCI/RCD and test the GFCI/RCD to restart the system when the spa water temperature is higher than 39?F (4?C).
Jan 25, 2016 | Intex Pool & Spa
Model EWF1048W. Won't start. What does error e94 indicate?
E94 - Washing cycle configuration error.
Incongruence of configuration values at the switching on of the appliance. Check that all the connectors are inserted correctly.
Possible configuration error. Replace the circuit board.
Dado
Dec 12, 2015 | Electrolux Washing Machines
Error code e94 till not working
It is a paper jam error remove the printer top and manually remove the paper jam. Pull out the receipt paper and manually remove any paper debris from the roller then reinsert receipt paper this should resolve your problem
Apr 19, 2013 | Retail Supplies
E94 errorwhat is this
google it loads of errors and answers there. just write e94 error in google search bar hope this helps.
Mar 22, 2013 | Casio Parts Cash Register PC Desktop
Electrolux time manager 7kg washing machine keeps stopping mid cycle and has an error code E94
E94 means: "Console control problem. Replace control board."
However fault codes are not absolutes. They simply tell a service person where to look for a problem. For example, if i was a service man and i had a control board like yours on the truck i would switch it out first to see if it solved the problem. If it did i would charge you for the part and labor and be on my way, even if it was just a loose wire or connector that was causing the problem. Or if i was a washer warranty rep and the machine was under warranty and you said you were getting an E94 fault code i'd ship you a control board and consider the problem solved.
I am not a service man or a warranty rep so my advice is to wiggle the wires going to the control board. Also, disconnect then reconnect any plastic conectors you see. Let me know.
Jan 30, 2013 | Electrolux Washing Machines
I have an E94 error on Casio 140CR but dont have paper jam
i have problem with casio 140 cr. E94 how to solve this problem
Jun 08, 2012 | Casio 140CR Cash Register
Sir good evening i have cash regester casio 160cr.Error code is e94 pls help how i can run my cash regester thanks.
I suggest you to reset your equipment.Here is how:
Remove AA batteries and unplug register from wall for 15 minutes.
Two more options;
Option #1:
To print the transaction details before clearing the journal memory:
VERY IMPORTANT: Do not interrupt once printing begins or the journal will not be cleared.
1. Make sure the paper is full in the register.
2. Turn to Z mode.
3. Hit the RC key until the screen displays "E94".
4. Hit Cash Amount Tender.
Once the printing is completed, the journal is cleared and the register is ready for use.
Option #2:
To clear the journal memory WITHOUT printing the transaction details:
1. Turn to Z mode
2. Hit RC key until the screen displays "E94 Clear"
3. Hit Cash Amount Tender
Nov 27, 2010 | Casio Parts Cash Register PC Desktop
We have an error showing - E94 and we cannot get any keys to ring or open the cash drawer. How can I fix this?
This sounds like a Casio. E94 refers to printer failure. Check to make sure their is nothing jamming the printer. Remove the paper/ ink cartridge etc, then turn off at wall. Turn key to REG. Turn on at wall
Casio cash register operating / user / programming manuals here: http://the-checkout-tech.com/cashregisters.php
Aug 04, 2010 | Casio Parts Cash Register PC Desktop
On the screen there is a E94 error messagage on the Casio P260 cash register . How can I correct this error and reopen the cash register.
E94 is a printer error. Open the printer and make sure nothing is jammed in it.Remove the paper roll. Look for old pieces of paper stuck in the gears etc. ----------------------------------------------------------------------------------------------
If anyone needs a Casio PCR-260 manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio2.php
Jun 16, 2010 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
1,529 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
tomferryman
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
