Question about HP LaserJet 4mv Printer
I can only print by manually feeding in each page -HP 4MV Printer
I have a HP LaserJet 4MV printer. Although it's an old printer, I really haven't used it very much over the years. About a year ago, it stopped printing automatically using paper from the tray. The paper is loaded correctly in the tray, but each time I try to print from the tray, it registers a "Jam". There really is no jam, but it "thinks" there's a jam. I've examined the tray, removed it, replaced it over and over, but the problem persists. I've removed part of the paper from the tray and even replaced the paper, but it doesn't help. Automatic printing from the tray just doesn't work anymore. Now the only way I can print is by manually feeding pages one at a time. Obviously, this is quite inconventient. Is there some kind of "sensor" in the tray? If so, where is it? Do you have any idea why my printer is registering a "jam" when there is no paper jam? The paper doesn't even move in the tray at all.
    Genius:
  • 1,605 Answers
Good old 4MV.
paper jam is just the way the printer i stelling you "something" wrong with paper feed".
you need to locate a "4MV repair kit" , they are not cheap. but, if you wan to keep the printer, it is worth it.
http://www.fixyourownprinter.com/kits/hp/K78 cost of the ket is $50
includes Instruction CD rollers, and other repairable parts.
Posted on Dec 15, 2008
2 Suggested Answers
  • 14 Answers
SOURCE: HP LaserJet 4MV
You could remove the fuser, turn the machine off, and wait an hour. It may reset the error. However, if the error still persists, it will be a parts replacement of the fuser, low voltage power supply, or the DC controller. 90% it is the fuser. Good luck.
Posted on Apr 23, 2010
Hp 4mv
You probably need to replace the paper feed rollers, which are no longer available from HP...
Mar 25, 2014 | HP LaserJet 4mv Printer
4mv won't pick up paper
The feed rollers need to be replaced. The squeak is the worn rollers sliding over the edge of the paper.
All printed are black all page
Is the printer installed locally or on network?
You may start by checking if the installed driver is correct.
Mar 15, 2010 | HP LaserJet 4mv Printer
Can't get my HP LaserJet 4MV to print. It printed yesterday but now it says "Printer not responding. The printer is on and I have checked all cables. Help
Can you perform a test print? Try this:
To print a Test Menu page
Press On Line] to take the printer off line.
2 Press [Menu] repeatedly until TEST MENU appears.
3 Press [Item] repeatedly until PS CONFIG PAGE (or another PS test page)
appears.
4 Press [Enter] to print the page. The page will print in less than one minute.
5 Press [On Line] to place the printer back on line.
Did the printer print? If so, you may have either an nterface or cable problem.
Oct 23, 2009 | Office Equipment & Supplies
Paper jam in HP Laserjet 4V
remove the cassette you can see two or 3 roller down the printer clean that roller and try.....
Oct 07, 2009 | HP LaserJet 4mv Printer
HP 4MV Printr and ip address
Scroll through the menus until you get to the I/O section. I don't think vista supports the HP 4MV
Mar 12, 2009 | HP LaserJet 4mv Printer
Repair Kit for HP 4MV Printer - Pick Up Rollers
The ruber tyres on the pick rollers can harden with age, even if you are not using it. Try applying gum turpentine to rubber tyre with Q tip. This is used to keep a printer picking up untill replacemant rollers can be fitted.
Dec 15, 2008 | HP LaserJet 1020 Printer
HP Laser Jet 4p printer problem - will not print continuously
Go to the printer setting's and make sure that the printer paper feed are not set into a Manual feed.
Thanks,
Feb 27, 2008 | HP LaserJet 4p Printer
HP LaserJet 4mv Printer Logo
271 people viewed this question
Clive
Clive
