Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Thermostat Wiring: W2? E? Where to connect?
I am replacing an old mechanical White-Rodgers thermostat with a digital 5-2 day programmable one from Honeywell (Model # 6300B). The wires I have coming out of the wall are connected to R, G, Y, O, W2, and E. Pretty self-explanatory: just match the wires to the new thermostat. But the new Honeywell thermostat doesn't have a W2 or E terminal.
Based on the diagram I have on the installation manual--
C or X, B wires, do not connect
G or F wires, connect to G
W or W1, H, O/B wires connect to W O/B
--unused terminal in between--
Y or Y1, M wires connect to Y
R or RH, 4, V connect to R
Rc or R connect to Rc
I have a fully electric system: 2-stage heat, single-stage cooling. Voltage at the thermostat is 24v
I want to think that W2 can just go to W and E stays disconnected. But before I do anything, I just want to make sure. Thanks for the help in advance
  • 1 more comment
  • sonikku10 Dec 15, 2008
    Sorry, forgot part of the model number--
    RTH6300B
    After doing a bit of reading, I thought I might give you the wire colors to the (old thermostat) terminals, too, just in case:
    R - red
    G - green
    Y- yellow
    O - blue
    W2 - white
    E - black
  • Anonymous Mar 31, 2014
    I have two wires. Very old not marked at all.
  • 61 Answers
You have a heat pump. You need a thermostat for "Heat pump with Electric back-up heat". Make sure the 'stat has either an "aux" (auxilliary heat) or an "E"(Emergency heat) terminal. The wiring instructions will be provided with the thermostat.
Posted on Dec 16, 2008
  • 96 Answers
R connects to RC/RH there should be a jumper between them , G connect to green , Y connect to Yellow , Blue wire to O/B , White wire to AUX , Black to E , and a jumper wire from AUX to E
Posted on Dec 15, 2008
Wiring instruction for a White Rodgers 1F78 non-programable thermostat.
The White-Rogers 1F78 thermostat is a single stage 5/2 day programmable thermostat. Home Depot has the manuals for one model of this thermostat, 1F78-151, on the product page: https://www.homedepot.com/p/White-Rodgers-Single-Stage-Digital-5-2-Day-Programmable-Thermostat-1F78-151/202771121 . The wiring diagrams are in the Installation manual. The direct link to this manual is https://www.homedepot.com/catalog/pdfimages/f9/f955280d-67a2-4502-bb94-4975cd857c0b.pdf . Emerson Climate also has the wiring diagram here: http://www.emersonclimate.com/Documents/White-Rodgers/instruction_sheets/0037-6615.pdf .
If you have a different White-Rodgers 1F78 thermostat, check for the manual at Emerson Climate by starting at http://climate.emerson.com/en-us/products/thermostats/thermostat-manuals . Click on the Enter Model Number button and start typing in the model in the search box. I found a number of models with 1F78 listed. After selecting a specific model, I found a link to the installation guide on the left side of the page, below the search box. (Note: the manual link was above the Suggested Replacement header for the models that I checked.)
I hope this helps.
Dec 15, 2017 | White Rodgers Home Security
My White Rodgers 1F78 programmable thermostat shows a constant room temperature of 83-84 in the afternoon, but I set it at 77 throughout the whole day and night. Should I get a new one?
It sounds like the temp sensor is defective in the T-stat. I would replace it, get the newer programmable ones, they are very reliable and very cheap to buy online.
Sep 21, 2016 | WHITE-RODGERS DIV 1F78-151 White 70 Series...
Need help understanding how to wire a new programmeable thermostat. I currently have a White Rodgers 1F73 model (non-programmeable) connected. I am confused with the instructions on how to connect the...
the black wire is your common wire, you need to program your thermostat, in the advance mode, to tell the t-stat if your heat pump reversing valve is energized on cooling or heating, is the orange wire connected to your t-stat.= w2/o/b
Dec 20, 2014 | Honeywell Heating & Cooling
How do I replace an old White Rodgers thermostat with new honeywell TH5220
The Orange wire for the reversing valve and used with a Heat Pump
If you have a heat pump, then yes. If you have a gas furnace then no. If you have a HP and the reversing valve is not connected, then you might just be using the emergency electric heat strips. :-o
Jul 21, 2014 | Honeywell Th5220d1003 Non-programmable...
W and W2 wiring on old thermostat...where do they go on the new thermostat?
It depends on the equipment you are connecting the thermostat to. If you have a heat pump, the thermostat must be wired differently than if you have separate heating and cooling equipment. If you have a two-stage or modulating furnace (or boiler), the w and w2 wires will conect for heating, and the y and g wires will connect to the air conditioner. Naturally, some configuring must be done with the new thermostat so that it acts correctly. w-w2-wiring-old-thermostat-go-new-u40lsvyytnuesyuv3fbafhtd-1-0.jpg
please mark this answer helpful.
Feb 22, 2013 | Honeywell RTH6400D 5-1-1-Day Programmable...
I am trying to replace my old thermostat with a programmable one, but the wiring diagram on the new one does not incorporate all of the wires that are currently attached. Please help.
The existing connections are O, R, Y, G, C, E, W2. Yes you will need a thermostat designed for the electric heater coils as indicated by the E terminal. The W2 could indicate a second stage cooling compressor.
Mar 05, 2011 | Honeywell CT87B ROUND HEATING&COOLING...
I just bought a Honeywell 5.2 Day RTH2300B Programmable thermostat to replace my old mercury thermostat for my gas fireplace. When I took of old thermostat it only has two wires. A white wire and a black...
I just installed a Honeywell 5.2 Day RTH2310B Programmable thermostat and I had to deal with the same situation: 2 wires, one white one black. After reading the edvice in one of the blog, the solution that worked for me was: BLACK ON Rc terminal and WHITE on W terminal. My furnace is running fine now. Hope it helps.
Dec 06, 2010 | Honeywell Focus 6300B 5-2 Days...
Replacing 9420 robertshaw hooking up 6300B honeywell. I have a wire (W2) i don't know what to do with?
If you have a single stage furnace, you do not need that wire....if you have a two stage, then you cannot use that thermostat because it will not do 2 stage...
heatman101
Apr 28, 2010 | Honeywell Focus 6300B 5-2 Days...
Heating & Cooling Logo
8,703 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
