Question about GE JBP24 QuickClean Electric Kitchen Range
JBP26 Oven broil and bake do not work and the oven light is flash
There are no error messages and clock works fine but neither the broil nor bake elements work. Can you help?
  • jflivorno Dec 15, 2008
    The oven light is flashing.
  • Anonymous Apr 15, 2009
    I have the same problem as stated above. My problem began with the failure of the bake element. I replaced it after finding a faulty connector on wire. The new element failed as well and now both the broil and bake elements are not working. I have a GE JBP79 self-cleaning electric range.
I have GE cooking range model # JBP26 0D1AD OR JBP26 OD1AD, the serial # SM255256 G, Please let me know the manufacture year of this range.
Posted on May 22, 2010
  • 107 Answers
If you have 240Volts to the range and BOTH elements don't work, it sounds like the L2 OUT relay on the oven control is bad. Bake and Broil share this line and this problem is not un-common. Make sure you have proper incoming voltage first. Turn breaker off and back on to make sure both poles are set.
Posted on Mar 14, 2009
My bake or broil will not work but my stovetop works fine, as well as the clock and oven light.
Does the oven indicator light come on when you turn the oven on? Does the baking element or the broil element work by themselves but just don't work together? If nothing at all works did they stop working at the same time? Need to know to troubleshoot. Please reply with more info.
Feb 16, 2011 | Frigidaire FEF336BC Electric Kitchen Range
KENMORE ELECTRIC RANGE 95032. EVERYTHING WORKS BUT OVEN DOES NOT HEAT.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 25, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
My gas oven, Super Capacity 465 the oven nor broiler light. The stove top works fine.
Hello there
Please read the entire solution i have provided below ok
It won't bake or broil If neither the oven nor the broiler heats, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)," push the knob in and try heating the oven and broiler again. If they still don't work properly, you probably have a defect in the thermostat, selector switch, or common wiring. Note... If the oven doesn't have a separate bake/broil/etc. selector switch, the problem is often with the thermostat. It's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem with either of these, call a qualified appliance repair technician.
Sep 28, 2010 | Whirlpool GS460 Gas Kitchen Range
The oven doesn't turn on in the bake cycle
oven doesn't come in broil but the broil should . the bake should in bake . but if it does work in self clean then your oven is ok and its the clock ( erc) that has failed . some times there is a code in the display stating the problem. but ist loks like a clock failure . **** ..
Dec 23, 2009 | Amana AGR5735QDS Gas Kitchen Range
Won't bake, but all else works
Swap the broil and bake ignitors(they are both the same) see if the bake works. If the oven bake works then you need only replace the ignitor. If it does not then I would say you should check the valve for continuity. If open, bad gas valve. If continuity is detected, bad oven control.
Dec 22, 2008 | Kitchen Ranges
Err on display when I try to set the bake temperature
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
or try doing this
1. Turn the clock selector knob to OFF
2. “Tweak” the oven control by turning the clock selector knob slightly to the left (counter clockwise). This may stop the flashing message/beeping and clear the display window.
Nov 12, 2008 | GE Profile JTP18 Electric Single Oven
Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
Hello stevefer
Welcome.
You said, Your Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
First,
1.What is the Model Number and the year of your wall oven?
2.Did the oven light up and display with any error codes?
3. Did you try to turn the breaker off for 5 minutes to see if this will reset the system?
Perhaps the heating element is failing and may need to be replaced.
I will be able to better assist you when you reply with this information.
Waiting your response.
Huuum
Oct 16, 2008 | Kitchen Ranges
Thermador 30" Dual-Fuel Range 0FF error
I am quoting above because I really need help. "When I push any of the function buttons on the oven console (Timer, Bake, Broil, Clock) the display shows 0FF in red next to the clock. The oven will not turn on and the timer will not work. I can not find any troubleshooting information on this problem. The oven is a model RDDS30V. Any help would be greatly appreciated!"
Apr 17, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
Nov 29, 2007 | Whirlpool RF262LXS Kitchen Range
Jennair range
f-5 means the clock/oven control is bad. the only way to fix this is to replace the oven control
Nov 26, 2007 | Jenn-Air SCE30600 Slide-In Electric...
GE JBP24 QuickClean Electric Kitchen Range Logo
681 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
