Question about Kenmore 24032\24036 Top Load Washer
Lent on clothes
I bought this washier used, but the clothes have more lent when they come out the washier then when they went in...any ideas as to what to do?
Kenmore 80 series # 20872 990
  • Kenmore Master
  • 5,568 Answers
Not familiar with this model but it sounds like too little water is being used (small, medium, large load) or a rinse cycle is being skipped.
With enough water and normal rinse cycles, the lint should be suspended and pumped down the drain. If this is happening with every load, then it isn't working properly.
Posted on Dec 15, 2008
My Kenmore washer does not have a lent trap ,so where does the lent go ?
The lint goes out with the drain water, most of it. The rest of the lint gets attached to your clothes. If you have a much older machine, you will see gray streaks of stuff sticking to your clothes, sheets, etc...and that's the lint.
Sep 21, 2012 | Refrigerators
Keep getting a "lens obstruction"
I recomend follow these step
1.- clean the side of lents circular side
2.- Turn OFF the camera and softly push the lents
3. Softly pull the lent while Turn ON the camera
I hope you resolve the problem
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 19, 2011 | GE X5 Digital Camera
I have a whirlpool model# Ler4634pq0 electric dryer. Heats ok, takes 3 cycles to dry clothes. Cleaned vent hose, cleaned internal duct system, cleaned lent screen, and holes inside drum. Any ideas?
If you 've done all of that and it still doesn't dry properly, you may have a faulty limit switch. These limits switches are usually down by the burner assembly and not much bigger than a quarter with generally 2 wires going to them. Very easy to replace once you find it. Unplug the dryer before you work on it.
Apr 12, 2011 | Whirlpool Dryers
Washier problems
Check pump belt or restriction or kinked hose
Oct 21, 2009 | Maytag PAV2300 Top Load Washer
Oil coming in the bottom of my washing machine tub.
Yor drum bearings are faulty and nee replaced Quite an expesive repair
Sep 27, 2009 | Whirlpool LSN1000LW Top Load Washer
I have a maytag washier and it is working but it makes a lot of noise -it sounds like jam Model number is MAV2755AWW Serial number is 27422854JT
Your Maytag washer may vibrate or make some noise during normal operation. If vibration and noise are excessive, however, you'll need to troubleshoot the problem. The two main reasons for such an issue are overloading and nonlevel installation. Overloading can be corrected by putting less clothing into the washer before you run a cycle. It can be corrected mid-cycle by removing clothing articles from the washer mid-cycle. It's also very important that you make sure that your washer is located on a firm, completely level surface. Otherwise it may create severe vibration and noise, possibly even enough to damage the machine or nearby items.
Sep 01, 2009 | Maytag Washing Machines
Dryer has heat..but very low temp , takes forever
Make sure that your vent pipe is completely clear of excess lent. It will not dry properly if the venting is not running freely. If the unit is cleared of lent, inside and out, the only other possibility is the thermostat is not reading correctly.
Apr 11, 2009 | Dryers
Kenmore 24032\24036 Top Load Washer Logo
178 people viewed this question
Sal De
fordexpert
Robert Rankin
