Question about Dryers
Gas dryer not heating
Had a load in the dryer yesterday and now its not heating. Starts rotates just no heat.
    Problem Solver:
  • 7 Answers
So, your clothes dryer won't produce heat. There are a number of possibilities for this problem. The first thing we must determine is the type of dryer we are servicing. There are only two types; Gas or electric.
If your dryer is electric, meaning it uses electricity instead of flame to produce heat, step one is to verify that the breaker to the dryer's electrical circuit is fully on. Since electric dryers require 240 volts to run, their circuit is run through a dual breaker switch. Sometimes only one half of the breaker switch will be off or fail which will supply enough power to make your dryer tumble but not enough for it to produce heat. Pop the breaker to your dryer off and on again and then see if the dryer will now produce heat. If it does, then have the breaker replaced. If it doesn't, you can verify that the dryer outlet is fully powered by testing it with a volt meter, You can learn how to use a volt meter here. If the outlet is fully powered then the problem definitely rests within the dryer.
Let's next deal with the failure common to both types.
You will need a continuity tester for this process. Directions for how to use a continuity tester can be found here.
After you have removed the power from your dryer and shut off the gas, you will also need to access the internal workings of your dryer. Directions for achieving access, specific to your brand, can be found here.
Most dryers have a thermal fuse located in the exhaust path. Depending on your dryer, the fuse will be found toward the front or the rear of your unit. Generally, if there is a removable back on your dryer then that is where you will find the fuse.
The two most commons thermal fuses you might find are shown in Figure 1. They are each roughly 1" in size. You will notice that the contact points are easily spotted for a continuity test.
In older units and some electrically heated units you will find a series of thermal fuses, looking like small tin cans, at various points along the heater assembly. These will also need to be tested before you can rule out thermal fuses as your problem. If any of the thermal fuses fails the continuity test, then it needs to be replaced. You can find reputable parts dealers at the top of this page.
Posted on Dec 17, 2008
Dryer not heating
sounds like a faulty pc board starts heating and then their is no power going from board have come across loads of times
Apr 09, 2014 | Maytag Neptune MDG5500AW Gas Dryer
Hiow old is my Kenmore Dryer 110 62952 100 It has heat; starts to dry; then stops. Sometimes it finishes drying a load and sometimes not.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 16, 2011 | Kenmore 62802 Electric Dryer
Whirlpool Gas Dryer Model #LGR7648KQ0 has no heat - I cleaned out the vent (it was pretty well clogged!) and then replaced the Fixed highlimit thermostat, the thermal fuse and the dryer cycling thermostat...
The problem is the dryer coils are failing. They tend to fail as they heat up. There is a video at http://appliancehelponline.com/gdryertroublevideo.html this will walk you thru checking them. They are inexpensive and easy to replace.
May 26, 2010 | Whirlpool Dryers
I have LG DLE2101W just installed yesterday. It
I found your manual and learned yours is a GAS dryer... the FIRST check is to be SURE the gas valve to your dryer is OPEN.
There is a Troubleshooting section, but NOTHING about no heat?
Know that LOW gas pressure CAN be a issue too!
I did find this:
"If the dryer no longer heats then the heating element may have failed, but it is not the most common cause. The most common cause for a dryer to stop heating is a blown thermal fuse."
The SECOND Link will be VERY helpful...
More help?
Cause 1 Thermal Fuse
Cause 2 Gas Valve Solenoid
Cause 3 Igniter
LG DLE2101W Support Manuals Warranty More LG
LG Dryer Not Heating
Thermostat
IGNITER
Dec 24, 2017 | LG Dryers
Dryer drum is rotating but no heat is present
If electric then the thermostat or the heating element has failed.
If gas: First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Oct 23, 2009 | Dryers
No heat in dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
98uit
Feb 05, 2009 | Maytag Neptune MLE2000A Front Load Stacked...
Whirlpool Imperial seventy dryer does not heat up
If there is a copper line feeding gas to it, PULL THE DRYER WAY FROM THE WALL AND TURN THE GAS OFF AT THE VALVE IMMEDIATELY!
Natural gas and copper do not mix, and the copper line will corrode from the inside out.
Now, on to the problem, it's very likely the timer has failed IF it does not rotate all the way through the drying cycle. If it does, and the clothes do not heat up, then reply back what you are experiencing and I will give you move help.
Jan 24, 2009 | Dryers
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Dryer starts, then stops, no heat
Need model # and brand
Dec 31, 2007 | Dryers
Dryers Logo
338 people viewed this question
Top Dryers Experts
Marvin
Marvin
