Question about Norelco T770 Beard Trimmer
I have a Norelco Accuvac T770 trimmer that will not hold a charge
Since there is no other option than to use the rechargable battery I cannot use the trimmer. This trimmer has not had much use and is only a couple years old. Is there a repair service that can fix it without cost to me?
  • 2 more comments
  • yoyoma1 Feb 12, 2009
    Great report. I have the same problem; maybe I can do a similar solution. Thanks.
  • Anonymous Feb 26, 2009
    i has the same problem shaver little by little stopped staying charged. thanks for the info i disassembled my shaver already now im going to radio shack for the rechargable batterys
    thank again im sure it going to work
  • Sean Pipkin May 07, 2012
    I had the same problem, I ordered a new battery from shaver outlet.com for $8.99 price included shipping. The battery came soldered together with tabs, so all I had to do was solder the battery post tabs to the circuit board. Easy fix for little money!
  • dick cory Jul 13, 2012
    GREAT! But how do you OPEN the t770 shaver??
I did everything possible to find help as I did not accept the answer from Norelco. They told me that there is no way to change the battery except by a qualified repair shop. I made them admit that they basically made a consumable device so they can get you to buy new shavers in the future - in so many words.
I finally pried the thing open as carefully as I could. Once opened, you will find 2 batteries glued together. They are Ni-Cd 2,4 volt - 600 mAh batteries. Looking all over, the only store that helped me was Battery Plus. There are stores all over the country storeloc
.aspx">http://www.batteriesplus.com/t-storeloc.aspx .
They sold me two 1.2v 1000mAh batteries for $3.50 each. For another $5 they spot welded them together with tabs for soldering the 2 wires on.
Okay, after getting the new batteries, I went back to my old batteries and slowly pried the tabs of the top. They pretty much snap off as they are only slightly tap welded on.
I then took out my model soldering gun and with a little patience, soldered the two wires on to the new leads on the new batteries.
Within minutes, I had the thing put back together and charging. It works great and now I can tell all of those who said it can't be done - or those who wanted $40 to refurbish it, to go scratch - I GOT MY SHAVER BACK!!!!
We all need to learn to stop living in a consumable world. I have a feeling due to the economy we are facing, we will all try to save money in this manner.
Good Luck!!!
Posted on Dec 30, 2008
    GREAT! But how do you OPEN the t770 shaver?? ANYONE!!
  • Howard Mosoff
    Howard Mosoff Apr 22, 2014
    Sorry took so long to see that I had a response and a question. FORCE! That's what you need unfortunately to open this thing up. But be careful as you can break it. You need to push down where the joints meet and use a little screw driver to pry it open. Anyway, update. After I lost the battery life again, I looked around and swa a new Norelco vacuum model. I broke down and bought it and it is even better then the original. You can use the newer one with just electric if the battery dies. It's their best model yet. Thank you Norelco. You saved face with me.
A cordless phone battery works perfectly as a replacement on the T770. I used a battery for a Sony BT-T50, Ultralast # UL950. Just need to cut off the plug and solder the wires to the main board.
Posted on Mar 28, 2009
I followed the advise of hmosoff, only I took the battery and the PC board to Batteriesplus. They had the batteries and did all the work for the cost of the batteries. My trimmer lives again!
Posted on Jul 03, 2009
I basically followed hmosoff's solution once I got the trimmer open. I ordered a 2.4V 800mAh NiCd battery pack w solder tabs (should look like the trimmer's installed batteries) from an online battery dealer (Interstate Batteries) for $10.48 w S/H. I cut the wires from the trimmer's main board where they attached to the old battery pack's tab. I stripped a little insulation from the ends of the wires and soldered them to the replacement battery pack's tabs. After reassembling the trimmer, it's like new, and I look forward to using it for many more years.
Posted on Sep 20, 2010
  • Chris Rompot Jul 13, 2012
    To open its case, I very gently and gradually pried the halves apart with small flat headed screwdrivers starting at the end where the recharger plugs in. In doing so, I broke one of the plastic tabs that hold case together. However, I managed to get it completely apart without snapping any of the other three (if I remember the number correctly). This year I replaced the batteries a second time and managed to gently pry the case apart again using small screwdrivers without any trouble or more broken tabs. The ease of re-opening the case might have been due to the tab broken off the first time.
I just spent 10 minutes replacing the batteries with regular AA (not the best environmental solution but feels a heck of a lot better than buying a whole new shaver). With a little tape you can do it, too.
Posted on Feb 15, 2009
Disassembled the beard trimmer, and took the board with batteries to BatteriesPlus...they replaced the batteries and did all the soldering work for $15.99, plus tax...less than half the cost of a new trimmer.
Posted on Feb 16, 2012
I thought my batteries wouldn't charge so I followed hmosoff's instructions but it turned out to be the switch. Regardless, I bypassed the batteries and the switch with wires to where the charger hooks up and used an adjustable adapter that I have for my camera using the 3 volt setting. Since I don't have a switch, I turn it on and off by plugging in or unplugging the cord at the base of the trimmer. It works great! never had this kind of power using batteries!.
I used a meter to compare the voltage on the batteries that came with the shaver and rechargable batteries from my camera and they are the same so I think almost any AA rechargable batteries would work.
Posted on Aug 18, 2009
I have an T770 beard & mustache trimmer, which has
It sounds like the battery is dead and needs replaced. Replacement battery type can be found on shaveroutlet.com at the link below
http://shaveroutlet.com/shaver-battery-pack-for-most-shavers-p-211.html
Sep 30, 2014 | Health & Beauty
Battery will not hold charge
Go to Wal-Mart Electronics dept. and buy a DR9576 Digital Camera battery pack for $14.00, then pry at the seam between the front and back parts of the razor after removing the trim head, dust collector cup, and beard rake assembly from the top of the trimmer and separate the two halfs of the razor. This should allow you to easily remove the battery holder-circuit board-charger plug assembly and pull outthe battery pack which consists of two NiCad batteries which are glued together so as to have opposite polarities next to each other. Carefully using a flat blade jewelers screwdriver, pry the metal tabs off of each end of the batteries and take the DR9576 battery pack which is already joined together in the same configuration and place the flat bar tab onto the end of the pack. Hold the battery holder with the wired side of it facing down, and carefully insert the end of the battery pack you just set the bar style tab onto in the end that has the charging plug closest to it so as to have the plastic "springs"
holding the metal shorting tab {flat bar tab} up against the battery pack. When you do this, be sure to align the battery pack so as to have the other end positive terminal lined up with the red wire with the metal tab on it. As you insert this end of the battery pack into the holder, insert the metal tabs with the wires on them in between the batteries and the plastic holder so that they are pinched up against the ends of the batteries. If you did this right and didn't let the tabs fall out of place, you now have replaced the old batteries with a pack with almost twice the storage capacity as the originals had. Reassemble the razor in the reverse order that you took it apart in and plug the charger into the razor for approximately 36 hours for the initial charge. Also these batteries are NiMH which do not suffer from battery memory which means that they do not have to be nearly dead before they can be recharged in the future. your trimmer should now be fully functioning after complete charge for the first time and should give you years more service while holding the charge for in incredibly long time. Congratulations!!!
May 11, 2011 | Norelco T770 Beard Trimmer
NEED TO KNOW HOW TO OPEN NORELCO T770 ACCUVAC TO REPLACE BATTERIES
Mar 20, 2011 | Norelco T770 Beard Trimmer
How to remove rechargeable battery for norelco 7864
hi minglim, welocme to the forum!
    Replacing a Norelco Shaver Battery Things You'll Need:Torx screwdriver set Rechargeable Ni-Cd AA battery 1)Slide up the sideburns trimmer on the shaver .2)Try the various torx head screwdriver sizes to find the fit for the two screws holding the top of the back shaver cover on. Unscrew the two screws that are under the sideburns trimmer that hold the back of the shaver on. On some Norelco shavers, the back will now slide off if you apply downward pressure on the shaver's back. Other Norelco shavers have one or two torx screws on the base of the back cover on the shaver; if so, unscrew them also. Place the screws in a safe place. 3)Take the back cover off the shaver. Some shavers may have a strap fastening the battery down. Unfasten the strap if there is one. Take out the battery. 4)Replace the old battery with a new rechargeable Ni-Cd AA battery. Re-fasten the battery holding strap if there was one. 5)Replace the back shaver cover and re-screw in all the torx screws,
May 20, 2010 | Norelco 7800XLCC Electric Shaver
How do I change the Battery in My Norelco T3000 Beard Trimer
Remove Phillips head screw at bottom of trimmer. Separate body in two being careful to notice how on/off switch is assembled. Unsolder the ni-cad battery from circuit board. Install new ni-cad battery of the same physical size that has solder tabs on it and solder it to the circuit board. I used a ni-hi (nickle metel hydride) instead of ni-cad which had different charging requirements so I limit charge time to no more than 16 hours for a discharged battery. It had been working fine for over a year. Don't forget to apply a few drops of light oil to the cutting blades to extend cutting life. Replacement blades are about $30.00
Jul 06, 2009 | Norelco T770 Beard Trimmer
I just got done doing the same thing
Can the charger charge your NiMH batteries? I was thinking of doing the same thing, but didn't think the NiCd charger would be able to charge the NiMH.
Norelco T770 Beard Trimmer Logo
6,087 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
