Question about Beko 24 in. D3731F Free-standing Dishwasher
Pump run when i switch on the dish washer, the pump starts running?
    President:
  • 1,462 Answers
Which pump? drain pump or main pump?
Posted on Mar 20, 2007
Cycle starts, but does not fill with water
When I start a new cycle, I first hear the pump run to empty out all remaining water, and after that I hear the motor run for the regular washing cycle, but there is no water in the dishwasher. After a few minutes, the cycle stops, and the washer claims the dishes are 'clean'. When I try starting a new cycle over and over again, about one in 20 times, the cycle will run normally with water. But then the next time, the problem starts all over again. Once a cycle starts correctly, everything works fine, including the rinsing.
Jan 11, 2013 | Bosch SHX5AL02UC Dishwasher
I HAVE A BOSCH DISH WASHER SGS43A32GB/01 WHICH APEARS TO FLOOD NEAR THE END OF CYCLE
check base for leaks or holes. This is a very thin sheet of stainless steel that gets easily punched if some heave shart or pointed cutlery is falling onto it. also check proper operation of float switch underneath it.
Feb 01, 2012 | Dishwashers
Not cleaning dishes properly
Hi and welcome to FixYa. I am Kelly.
Dirty dishes post cycle are a sign of draining problems however this is a list of what it could be.
1. A partially clogged drain
2. The timer motor is not functioning properly
3. A broken or worn pump impeller
Here is what you need to do:
Check your entire drain system. Start at the final outlet and work your way backward to the motor pump connection on the dishwasher.
Suspected areas are.
a. The sink connection outlet is clogged (this can be inside a garbage disposal.
b. The air-gap is clogged in the very top part of the air-gap (Usually located on the back of the sink and is around 3 inches tall) Remove the cover, unscrew the top nut and check under the horse shoe bend inside the plastic top for obstructions. Clean as needed)
c. There is debris on top of the the motor pump housing blocking the inlet drain. (This would be inside the housing of the lower wash arm on the very bottom)
d. The motor pump outlet drain port is partially blocked. (only accessable from the motor pump exit hole after drain hose removal.)
A partially blocked inlet tub drain to the motor pump would also explain your soap dispenser problem. Additionally you would have spotted dishes post cycle.
When the drain is partially blocked some models use the float level switch in the tub to control the advancement of the timer. If the water does not drain the motor pump continues to run and run and the cycle does not advance until the tub is drained and the float switch senses same. i.e extended cycle
Thanks for using FixYa.
Kelly
Apr 27, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
My dishwasher doesn't clean my dishes anymore and sometimes it doesnt dry them. it is a quiet partner 1 and it is about 2 years old.
It sounds like the water pump on the dish washer has gone out. A dish washer works (much like a clothes washer) by filling up the washer with a set amount of water, then through circulation, pumps the water up through the various spray nozzels. If the water pump is worn and not making enough pressure, the spray won't get the job done. Depending upon make/model, it may be cheaper to replace the water pump.
Run an empty dishwasher load with a bowl of white vinegar on the bottom shelf. As the dishwasher runs the cycle, the vinegar is slowly disbursed and cleans the dishwasher.
Mar 02, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
The dish washer runs but does not pump the water out sounds like the pump is runing and nothing seems to be plugged
Dec 31, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dish washer runs and drains water only. I turn it on and you can here the drain pump running. But it just keeps trying to drain ut won't go into the fill cycle
it sounds like the re-lay switch on the pump is stuck and therefore only pumping inthe one direction.
some pumps come with re-lay switch built-in and orthers with it seprate less hassel not built -in.
P
Aug 07, 2009 | Dishwashers
Dish Washer soap does not dispense during wash
You don;t list the make and model number or its aproximate age.
The simpelest cause is switching to an ultra-cheap dry detergent. Recommed you use a name brand powder (like Electrosol or Cascade) Never use gel or tablets, ever.
Check all spray arms for blockages. Now is a good time to remove the filter (non trivial but do-able on most dishwashers.)
Clean empty dishwasher by filling a bowl or large cup with white vinegar and placing it in the dish rack. Run a short cycle with no detergent added. You may need to repeat.
If problems persist, the pump motor is probably failing. Schedule a service call or consider replacement of DW. Good Luck!
Mar 29, 2009 | Dishwashers
Drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Dishwasher problems
The washer may be attempting to run dry. Many times on these washers, a person may open the washer and then go to another load. The washer gets stuck with a dry pump until the timer tells water fill valve to open. Easy test. Start on regular cycle ,slowly advance the timer. it will click until you here the fill start and water will fill until.....
Jul 06, 2008 | GE Dishwashers
Beko 24 in. D3731F Free-standing Dishwasher Logo
167 people viewed this question
Top Beko Dishwashers Experts
Eric Taylor
Marvin
Marvin
Paul Carew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
